Please use this ONLY if you have downloaded 2.0.0 (160321.1637), version number can be seen in TestFlight app
changes since 1.5.0 version:
+ bump core to match jarvis
+ bump to AE/17 and friends
+ added skin SIO2
+ added rar
+ added DVD iso/img playback, no VIDEO_TS yet
+ bumped all PVR addons
+ added music visualisations
changes since 2.0.0 (160309.1649) version
+ bump core to match jarvis 16.1 RC2
+ fixed, iOS/tvOS. poke pvr manager when we re-enter foreground
+ fixed, bring back dvd settings
+ pvr handling changes, buffer and friends
+ fixed, tvOS keyboard handling
+ fixed, pvr livetv buffering issue.
+ fixed, calling into smbc_stat with empty strings
+ fixed, nextpvr crashing when response is not ok.
tvOS Testing 2.0.0 (160321.1637)
Re: tvOS Testing 2.0.0 (160321.1637)
@deanjo, this one is for you and anyone else running nextpvr.
I haven't had any more problems with NextPVR after that time it wouldn't set a recording. You saw the logs for that.davilla wrote:@deanjo, this one is for you and anyone else running nextpvr.
This new build seems to work just fine too.
deanjo
Will test when I get home.
deanjo
So far looking good, been running for 40 minutes and still going. Never made it this far with the previous version.
deanjo
Still going, think you have it licked. I'll watch the rest of the night and let you know tomorrow if the issue is still there.
deanjo
Well it is pretty solid, however it still dies occasionally, do not think it is related the previous issue. Is there a way I can put advancesettings.xml in tvOS so that I can adjust the PVR settings so that I can increase the cache levels?
deanjo
May I suggest adding the following pvr settings in the gui that is found in advancedsettings.xml?
<pvr>
<minvideocachelevel>10</minvideocachelevel>
<minaudiocachelevel>10</minaudiocachelevel>
<cacheindvdplayer>true</cacheindvdplayer>
<lingertime>60</lingertime>
</pvr>
None of those are present in the code base anymore except lingertime
MrMC v2.0 uses AE/17 along with player changes.
exactly what are you trying to tweak in response to what effect you see ?
deanjo
I'm trying to increase the buffer before resuming playback. I had this issue with an older version of Kodi where it would start playing for few seconds after buffering, then it would stop, then buffer up again before it gained a steady stream. I'm trying to eliminate the play, pause, play, behaviour.
