Amber skin doesn't save custom backgrounds after restart
Troysc
Post by Troysc »
Hello there,
Is it known that the amber skin doesn't save my custom backgrounds I set in settings, when I restart MrMC?
Thanks for your help.
Regards,
Troysc
Itzme1234
Re: Amber skin doesn't save custom backgrounds after restart
Post by Itzme1234 »
My backgrounds are still there using 2.7-1
Troysc
Post by Troysc »
weird...mine loses them, they are on a samba share...:/ any possible solutions?
Works fine here as well...
Let look at debuglog when it looses the background, maybe something pops up
Troysc
Post by Troysc »
Alright, looked into it, says after changing the background
16:24:35 T:6143848448   DEBUG: ------ Window Deinit (FileBrowser.xml) ------
16:24:36 T:6141505536   DEBUG: DoWork - took 109 ms to load special://masterprofile/Thumbnails/8/86d81d1c.jpg
Thats the right background. But on restart it loads the default background.
16:20:39 T:6143848448   DEBUG: ------ Window Deinit (Startup.xml) ------
16:20:39 T:6143848448   DEBUG: ------ Window Init (Home.xml) ------
16:20:39 T:6143848448    INFO: Loading skin file: Home.xml, load type: KEEP_IN_MEMORY
16:20:39 T:6154596352   DEBUG: DoWork - took 137 ms to load special://skin/backgrounds/TVShows.jpg
Is the problem cause of "load type: KEEP_IN_MEMORY"? Can I somehow change it to persistence?
boosterbosch
Post by boosterbosch »
had the same problem. Reinstalled MRMC on Apple TV and issue is now resolved.
