Hi
I saw MrMC got some "LightEffect" Support. Is this Boblight only? I tried to connect to my Hyperion Server running on my RPI but MrMC will freeze. I need to reinstall MrMC again after that, because everytime I start MrMC it will freeze again, since it's trying to connect to hyperion.
So my question: Is Hyperion not supported (yet)? Any change it will be supported in a later version?
Hyperion Support?
Re: Hyperion Support?
we only have boblight setup here, not sure what the changes are needed for Hyperion setup.
if you know whats different, we can certainly look into adding it in
duri03041980
i don't know the difference in accessing it. Maybe somebody else knows more?
duri03041980
I have solved the issue!
I seems I forgot to start the Boblight Server in Hyperion.config.json
/// The configuration of the boblight server which enables the boblight remote interface
/// * port : Port at which the boblight server is started
/// * priority: Priority of the boblight server (Default=900) HINT: lower value result in HIGHER priority!
"boblightServer" :
"port" : 19333,
"priority" : 900
