tvOS 2.6.3 released
tvOS 2.6.3 released
changes since 2.6.0 release version
- many bugfixes and cosmetics
- fixed, missing rar checks. fixes rar playback
- disable native ios/tvos as3 and eac3 on pvr, use ffmpeg
- disable screensaver if slideshow is playing, tvos/android
- fixed, android behavior when playing audio/video and pushed to background
- fix video playback from Home Shelf
- plex: in progress/recently added selector (Settings -> Library -> Vidoes - > Display In Progress items on home screen)
- plex: playback from HomeShelf, check if we have multiple resolutions for the movie and play selected one
- skin.amber: enable custom backgrounds for Movies/tv shows if only plex is enabled
- skin.amber: fix overlay for watched/unwatched status
- skin.amber: fix static vertical menu setting
- upstream sync. fixed audio glitch when stream changes midflight
- fixed, only update plex clients if playback is stopped
- fixed stutter on tvOS when seeking.
- fixed, a/v syncing, c/p monster
- upstream sync, log failed texture loading
- changed, plex server. cancel curl transfers if thread stop is requested
- upstream sync, ae, passthrough, video renderer and dvdclock
Sanjuro
Re: tvOS 2.6.3 released
Post by Sanjuro »
I updated the following 3 items within about 24 hours:
tvOS (new version out)
MrMC (this version)
Plex (update to server software)
And then MrMC wouldn't connect to my library. Quit the app numerous times (and clicked "clean library") and no luck.
What finally worked was entering my Plex Username and Password in MrMC, instead of (or in addition to) "GDM discovery" being on (which is what worked flawlessly before).
Frustrating at first, but glad it's working now. Perhaps this note will help others who may come across the same issue.
Post by cosmoxl »
Sanjuro wrote:I updated the following 3 items within about 24 hours:
MrMC (this version)
PIN method has always worked for me with GDM discovery off. Anyway, glad you figured it out.
