SMB doesn't support any more..
whereisjim
Post by whereisjim »
I have 2 NAS at home which contains all different videos, music, photos and etc.
I used to use SMB to connect these NAS, which was fine.
Suddenly, it doesn't support anymore. It won't connect anymore. I tried to connect again but was unable to access it.
Any idea?
Please help.
It's been some months now. I was using other video player, but since I purchased MrMC, I'd like to use this again.
Just updated to TVOS 17 and still has the same issue.
whereisjim
Re: SMB doesn't support any more..
I just tried to uninstall from Apple TV and installed again.
But still SMB doesn't work at all.
Any help?
eazytv
Post by eazytv »
Pretty sure it is a settings issue, maybe the SMB version, since such basic architecture remained unaltered over the years. Maybe search for " kodi connect nas smb".
dizen07
Post by dizen07 »
The problem is an smb version issue.
I also had the same problem, and when I looked at my NAS settings today,
The minimum SMB setting on my NAS (QNAP) is set to SMB 2.
When I changed it to SMB 1, it reconnected.
Due to security issues in NAS OS, the default setting is SMB 2.
If you are concerned about security, there is no problem using FTP.
