Siri Remote
5chrup3
Siri Remote
Post by 5chrup3 »
I’m using the tvheadend htsp plugin, which is working “good” but remote control with Siri Remote is a nightmare! I even wasn’t able to find a way to deactivate the default activated subtitle on the channels - the only way I found out was to use the kodi remote app, which is partially working (channels aren’t loading).
Kodi matrix has a much better integration of Siri Remote - so, could you implement this in MrMC? Or is an update to Kodi 19 based MrMC on the way (with Kodi 19 features of course)?
Greetings 😉
