Hello,
I recently switched from SMB to NFS and notice a change in behaviour when starting to play a video.
All my movies are in their own folder, with one video file in them. I'm using mrmc on tvOS.
Before I would just "Enter" the folder and the movie would play.
Now it opens the folder and shows the files inside. I then ned to "Enter" again to start the video.
I tried playing around with the different options for the share (type = movies, movies are in folder = yes, ...)but always get the same result.
Now if I select "Play" on a folder, it does play the video file.
I'm pretty sure that before i could just "Enter" into a folder and it would play immediately.
Can someone explain which options exactly should control this behaviour?
Thanks!
Folder with one video file / Start video directly
whitedogbe
Re: Folder with one video file / Start video directly
If you are accessing the files from Media Sources then you will have to drill down until you select the file to play it.
I suspect you had files loaded in a library before and access them using “Movie” or “Tv Show” from Home Screen
whitedogbe
Hi amet, thanks for the quick reply.
That's correct.
I have marked these media sources as favorite and "add to home screen".
I access them in that way, but that's also what I did before.
I've not changed any settings, I've only changed the sources.
I've checked again and I think I was thrown off by the default view being "icons" instead of the "list" when going into the folder.
Guess my mind was playing tricks on me
But as I already indicated that "each folder contains one movie", is there some other way to achieve this and just start playing? I'll try to remeber to just press play instead
That's correct.
There is no way as far as I can think, if it’s a movie folder “select” will just drill into it and only play video file.
Why not add it into a library?
