I've been spinning my wheels the last week ever since Apple forced a firmware update on my router. I've since rolled that update back, but my system which worked perfectly beforehand, now no longer functions.
My basic setup is:
>AppleTV 4
>Apple Airport Extreme with inbuilt hard-drive
My media resides on the inbuilt hard-drive, and up until now, I've had no issue with connecting to it via this logic:
SMB://Server-ID/USB-Drive/Media-Folder
The disks are locked with a username and password.
I've installed and run "SMB-Up" on my Mac that I control the base station with, but that doesn't seem to effect anything.
The strange thing, is that if I connect my Mac to the network, and attempt to access these disks, there's no issue. Further, if my Mac has recently connected, then the Apple TV/ MrMC is able to connect and everything works.
After time passes, or I shut down the other Mac, files/paths that did work give the follow error:
Error: Operation Timed Out
Remote Share: Couldn't Connect To Network Server
I guess it's either an issue with the Drive going to sleep (and not waking up) - or an issue with authentication. I honestly am at a loss.
Debug Log: FZ5VV.LOG
Cannot Connect to Network Server
Re: Cannot Connect to Network Server
Seems to me that disks are going to sleep, when your Mac is connected it keeps them spinning. Is there a way to keep the disks on? Would WOL addon help there?
grasso325
How would I go about that?
I have Kodi installed on the Mac computer. Should I install something like the below?
https://superrepo.org/kodi/addon/script.advanced.wol/
And then, via Kodi, apply it to the share drive?
And once it's applied to the share-drive, see if my Apple TV functionality returns to normal?
Thanks!
Andrew
Thanks!
Andrew
We have WOL addon included in MrMC, give that a try
grasso325
I enabled the WOL addon, and no luck, unfortunately.
I think it may be something with "SMBUp", some minor adjustment I'm not getting right. That and maybe authentication.
I attempt to connect to the same server via Kodi from the MAC and run into the same errors.
However, when I access the drive via the Network (with username and password), and it mounts on the Mac desktop - then the smb://server/disk/mediafolder works on both Kodi and on MrMC.
I'll report if I figure it out - otherwise, if there are other ideas, please let me know.
grasso325
I was able to use MrMC to watch some media (by mounting the network drive on a separate MAC) - and after the media was complete, the old problem returned.
Perhaps the new log with show what happened/changed?
LOG ID: ULEIE.LOG
LOG ID: ULEIE.LOG
