Just go to https://play.google.com/apps/testing/tv.mrmc.mrmc to join/leave testing.
When reporting issues, please include debuglog
3.9.7 Beta
- jellyfin: do not mark jellyfin as library item
- MediaService: add year to sort mathod
- jellyfin: default to HTTP
- retry caching the image if it fails
- fix playback of file item that was not scanned in a library and default select action is INFO
- capitalize home strings
- reload RA and in progress items on home after "OnStop"
- jellyfin: more fixes
- opacity: sync github version to makefile
- add Dialog.SetAutoClose(windowID,timeout)
- emby/jellyfin: fallback for season thumbs
- bump script.plex
- CHG: [droid;AT] backport kodi delay calculation
Testing MrMC 3.9.7 for Google Play
kamil66
Re: Testing MrMC 3.9.7 for Google Play
beta
BillyBudapest
Uh, yeah I gathered.
Not sure what your point was posting a screenshot of the extensions page.
Where can I see a change log please?
Per another thread I see there are 'tweakings to the audio synchonization backported from Kodi' and a first bug report that the PVR add-ons was left out. Again. That bug definitely affects me since I use Tvheadend.
I gather another build without that omission will be coming pretty soon....
We are all over the place with this, can we stick to one thread please?
New build with pvr is coming soon
Testing on shield tv here.
I'm not getting any bitstream anymore. Still works just fine with the Plex app.
Also, the doctor sleep.ts test file that helped davilla fix a problem with some DV video not showing up now plays worse than it did. The video glitches in and out for about the first half of the file. This doesn't happen with the Plex app.
log is 8YXF0
log is 8YXF0
- koying
Hi.
Is this new in the latest beta from today?
- timstephens24
I was getting passthrough yesterday and today with the new beta.
I just updated again today, still no passthrough. log is f4kqx
- koying
Would you have enabled "Boost Center", recently?
That forces transcoding to AC3.
Anyway, you should at least have transcoded AC3.
Could you enable the "Audio" debug setting and redo a test please.
ugh. it was the "boost voice channel" setting. I'd changed that a couple weeks ago for a video with really crappy audio and I figured it only applied if passthrough was off.koying wrote: 28 May 2020, 19:10 Would you have enabled "Boost Center", recently?
But, here's the boost voice channel setting on and audio component debugging on so that you can figure out why it's not transcoding to AC3. log is 6BQ4l (or is that an I ??)
I ran the playback on that dr. sleep video which is still very glitchy in and out (the video keeps flashing to black or something) the fist 1/3 of the video. No problems playing it in Plex.
