Hello,
trying to search opensubtitles does not show any results, here the logs:
https://pastebin.com/LBfDpJHg
Can you please check?
OpenSubtitles no longer working
Re: OpenSubtitles no longer working
does https://www.opensubtitles.org work for you? seems that website is down, that will prevent us from searching it
the site is up. but they may have changed some things? When I visit it's all a mess and they claim it will be since I use an ad blocker.amet wrote: 30 Jan 2020, 16:39 does https://www.opensubtitles.org work for you? seems that website is down, that will prevent us from searching it
If the site doesn't respond for you then perhaps your ISP or something on your network is blocking it? To prevent "piracy".
edit: I've confirmed that the site is accessible from my network but searching for subtitles in MrMC results in none found for things that should definitely have a match.
joshy123
website also loads fine here, but nothing found using the app
I narrowed it down to https access issues on their api.opensubtitles.org server
We have a fix in but not sure if it will be in 3.9.5 that’s almost ready, we will try.
erJotas
Sorry to bump this thread.
It's not working for me, but even, when I try to access to the website, redirect it to xyz.vip
Any tips?
Cheers!
Any tips?
Cheers!
I just used it, I use it daily and if it’s down I would know immediately
If your browser redirects to the site, then it must be something with your DNS.... try changing dns to 8.8.8.8
erJotas
I'm using cloud flare... I've payed VIP subscription and now it seems it's working.
