Anyway to hit "O" and get the codex infor + PVR info?!?!
kbaggen
Post by kbaggen »
As topic says, is there a way in MrMC to get the info from hitting "O" on keybard and hence display the Codex info and PVR info etc?!?
Klaus
Re: Anyway to hit "O" and get the codex infor + PVR info?!?!
kbaggen wrote:As topic says, is there a way in MrMC to get the info from hitting "O" on keybard and hence display the Codex info and PVR info etc?!?
Klaus
a) kodi iOS remote
b) jason via http (webserver)
curl -X POST -H "Content-Type: application/json" -d '{"jsonrpc":"2.0","method":"Input.ShowCodec","id":1}' http://192.168.2.94:8080/jsonrpc
of course, use you IP address and not mine :)
kbaggen
Post by kbaggen »
Thanks....got ikt working :-)
