Hello
I have download the app and its not working and i cant go anywhere
I did click many time nothing happen and delete the app and download igt again and nothing happen !!
Xs Max app don't work at all !!
- timstephens24
Re: Xs Max app don't work at all !!
It works on my XS Max... maybe a debuglog would help.
Abdulhadikh
The app don’t do anything i get go anywhere so there are noway to debugging!!!
I would like to test anther version to see if the problem is there or not !!!
works here also, what iOS are you running?
what other version?
what other version?
Abdulhadikh
I think may because i use ios 13 beta !
- timstephens24
Works for me on iOS 13.1 beta :p
Abdulhadikh
I use lastest beta 13.0 i dont want ios 13.1 So i delete the beta profile
- timstephens24
Apple Beta’s are notorious for messing stuff up (it’s a beta, so it happens). You should probably update to the GM build that’ll be out today.
Abdulhadikh
After the last update the app is working now
