I have some opinions about some translations that I think is wrong and some that are missing in the Swedish version.
Is there some way that I can change that myself?
Fix unclear translations in the Swedish version?
Re: Fix unclear translations in the Swedish version?
not in the app, but we could give you access to the translate page where you could edit what you think is wrong
see this for info -> https://forum.mrmc.tv/viewtopic.php?f=26&t=1293
- cotignac
I have now got access to the Swedish translation.
Am I supposed to translate everything - even the items that hasn't got any English text?
well, if there is no English text there is nothing to translate...
use English as base language to translate missing strings to Swedish
- cotignac
I'll give you an example.
The text to the left for item #36293 is "Set the color to be used for the subtitle background." and "Description of setting with label #745 "Background Color"".
The English text to the right says "Empty" and the same for the Swedish text.
Shall I translate this text to Swedish or not?
- cotignac
I have another question.
Is it possible to download and verify the my translations before I confirm that I'm ready and have finished my work?
not sure if this link will work, but try it https://lokalise.co/project/41730241597 ... ang_id=754
below what it looks like:
you look at english on the left and fill in the Swedish translation on the right ... eg "and enter this code -> " is "Empty" meaning that there is no translation.
the purple button on top left is activity, that should show you what changes you made, I can see you made a lot of changes... thanks for that!
yes, "Set the color to be used for the subtitle background" is the default english string, that should get translated.cotignac wrote: 10 Sep 2019, 15:55 I'll give you an example.
