Increasing number of HEVC/x265 files not playing.
Superhans
Post by Superhans » 09 Jun 2019, 16:52
Finding recently that a lot of HEVC/x265 encoded files that I get down from Usenet are not playing on MrMC.
They still work fine in VLC on the PC and I can recode them in Handbrake to a playable x264 file just fine.
Here's details of an example using the Mediainfo utility.
Format : Matroska
File size : 904 MiB
Duration : 41mn 52s
Overall bit rate : 3 018 Kbps
Writing application : Lavf58.27.102
Writing library : Lavf58.27.102
Video
Format : HEVC
Format profile : Main 10@L4.0
Codec ID : V_MPEGH/ISO/HEVC
Duration : 41mn 52s
Width : 1 920 pixels
Height : 1 080 pixels
Display aspect ratio : 16:9
Frame rate mode : Constant
Frame rate : 29.970 fps
Color space : YUV
Chroma subsampling : 4:2:0
Bit depth : 10 bits
Writing library : Lavc58.51.100 libx265
Default : Yes
Forced : No
DURATION : 00:41:52.743000000
NUMBER_OF_FRAMES : 75306
NUMBER_OF_BYTES : 1546099956
_STATISTICS_WRITING_APP : mkvmerge v24.0.0 ('Beyond The Pale') 64-bit
_STATISTICS_WRITING_DATE_UTC : 2019-06-01 02:56:51
_STATISTICS_TAGS : BPS DURATION NUMBER_OF_FRAMES NUMBER_OF_BYTES
Re: Increasing number of HEVC/x265 files not playing.
Post by amet » 09 Jun 2019, 19:03
And debuglog please
Superhans
Post by Superhans » 09 Jun 2019, 21:52
Pastebin taken from my Shield TV:
https://pastebin.com/UWaAFM5H
However, I also have a FireTV and I noticed that it has just taken an update of MrMC and the exact same file plays on it ..... (previously, it was also failing to play).
Post by davilla » 10 Jun 2019, 00:39
INFO: SMBFile->Open: Unable to open file : 'smb://BRIX-N2807/Video%20Share/TV/Misc/BattleBots.2015.S04E01.1080p.HEVC.x265.mkv'
unix_err:'d' error : 'Permission denied'
21:04:47.986 T:144539628784 ERROR: Open - failed to open source <smb://BRIX-N2807/Video Share/TV/Misc/BattleBots.2015.S04E01.1080p.HEVC.x265.mkv>
It's not a problem playing (decoder), it a file access problem.
Superhans
Post by Superhans » 10 Jun 2019, 21:14
D'oh! Yes, checked the underlying permissions on my native Linux filesystem on the server and owners/permissions were different, hence the differing results when trying to play back, and also why versions of MrMC on the FireTV and Sheild were having different results (one was NFS mount, the other SMB under a guest user).
I'd been copying stuff into a temporary filesystem in order to quickly view it after downloading and hadn't been changing the perms.
Many thanks.
