I just bought MrMC to be used as VDR client (iPad Pro 2018 - thus big resolution) using VNSI. When using Kodi on my mac it works like a charm:
Jun 03 09:57:42 n40l vdr[755]: [771] loading /var/lib/vdr/plugins/vnsiserver/allowed_hosts.conf
Jun 03 09:57:42 n40l vdr[755]: [771] VNSI: Client with ID 8 connected: 192.168.1.32:58893
Jun 03 09:57:42 n40l vdr[755]: [968] VNSI: Welcome client 'XBMC Media Center' with protocol version '10'
Jun 03 09:57:42 n40l vdr[755]: [968] VNSI: LiveStreamer::Close - close
Jun 03 09:57:42 n40l vdr[755]: [968] VNSI: close video input ...
Jun 03 09:57:42 n40l vdr[755]: [968] VNSI: Successfully found following device: 0x12bfa10 (1) for receiving
Jun 03 09:57:42 n40l vdr[755]: [968] VNSI: Successfully switched to channel 4 - arte HD
Jun 03 09:57:42 n40l vdr[755]: [968] VNSI: Started streaming of channel arte HD (timeout 10 seconds)
Jun 03 09:57:42 n40l vdr[755]: [969] device 1 receiver thread started (pid=755, tid=969, prio=high)
Jun 03 09:57:42 n40l vdr[755]: [972] device 1 TS buffer thread started (pid=755, tid=972, prio=high)
Jun 03 09:57:42 n40l vdr[755]: [971] cLiveStreamer stream processor thread started (pid=755, tid=971, prio=high)
Jun 03 09:57:42 n40l vdr[755]: [970] VNSI: VideoInput: no pat/pmt within timeout, falling back to channel pids
Jun 03 09:57:42 n40l vdr[755]: [970] VNSI: Video Input - new pmt, attaching receiver
Jun 03 09:57:42 n40l vdr[755]: [971] VNSI: Created stream for pid=5111 and type=8
Jun 03 09:57:42 n40l vdr[755]: [971] VNSI: Created stream for pid=5116 and type=1
Jun 03 09:57:42 n40l vdr[755]: [971] VNSI: Created stream for pid=5112 and type=2
Jun 03 09:57:42 n40l vdr[755]: [971] VNSI: Created stream for pid=5113 and type=2
Jun 03 09:57:42 n40l vdr[755]: [971] VNSI: Created stream for pid=5117 and type=2
Jun 03 09:57:42 n40l vdr[755]: [971] VNSI: Created stream for pid=5115 and type=9
Jun 03 09:57:42 n40l vdr[755]: [971] VNSI: Created stream for pid=5118 and type=9
Jun 03 09:57:42 n40l vdr[755]: [971] VNSI: Created stream for pid=5119 and type=9
Jun 03 09:57:42 n40l vdr[755]: [971] VNSI: Created stream for pid=5114 and type=11Code: Select all
Jun 03 09:59:37 n40l vdr[755]: [771] loading /var/lib/vdr/plugins/vnsiserver/allowed_hosts.conf
Jun 03 09:59:37 n40l vdr[755]: [771] VNSI: Client with ID 11 connected: 192.168.1.43:53682
Jun 03 09:59:37 n40l vdr[755]: [992] VNSI: Welcome client 'XBMC Media Center' with protocol version '8'
Jun 03 09:59:38 n40l vdr[755]: [992] VNSI: LiveStreamer::Close - close
Jun 03 09:59:38 n40l vdr[755]: [992] VNSI: close video input ...
Jun 03 09:59:38 n40l vdr[755]: [992] VNSI: Successfully found following device: 0x12bfa10 (1) for receiving
Jun 03 09:59:38 n40l vdr[755]: [992] VNSI: Successfully switched to channel 4 - arte HD
Jun 03 09:59:38 n40l vdr[755]: [992] VNSI: Started streaming of channel arte HD (timeout 10 seconds)
Jun 03 09:59:38 n40l vdr[755]: [993] device 1 receiver thread started (pid=755, tid=993, prio=high)
Jun 03 09:59:38 n40l vdr[755]: [996] device 1 TS buffer thread started (pid=755, tid=996, prio=high)
Jun 03 09:59:38 n40l vdr[755]: [995] cLiveStreamer stream processor thread started (pid=755, tid=995, prio=high)
Jun 03 09:59:38 n40l vdr[755]: [994] VNSI: VideoInput: no pat/pmt within timeout, falling back to channel pids
Jun 03 09:59:38 n40l vdr[755]: [994] VNSI: Video Input - new pmt, attaching receiver
Jun 03 09:59:38 n40l vdr[755]: [995] VNSI: Created stream for pid=5111 and type=8
Jun 03 09:59:38 n40l vdr[755]: [995] VNSI: Created stream for pid=5116 and type=1
Jun 03 09:59:38 n40l vdr[755]: [995] VNSI: Created stream for pid=5112 and type=2
Jun 03 09:59:38 n40l vdr[755]: [995] VNSI: Created stream for pid=5113 and type=2
Jun 03 09:59:38 n40l vdr[755]: [995] VNSI: Created stream for pid=5117 and type=2
Jun 03 09:59:38 n40l vdr[755]: [995] VNSI: Created stream for pid=5115 and type=9
Jun 03 09:59:38 n40l vdr[755]: [995] VNSI: Created stream for pid=5118 and type=9
Jun 03 09:59:38 n40l vdr[755]: [995] VNSI: Created stream for pid=5119 and type=9
Jun 03 09:59:38 n40l vdr[755]: [995] VNSI: Created stream for pid=5114 and type=11After some seconds the audio goes silent.
UPDATE: Trying out some more, it seems that this only applies to HD channels. When streaming SD the video starts playing.
On the server side I am running ubuntu 16 with the following versions:
root@n40l:~# vdr --version
vdr (2.2.0/2.2.0) - The Video Disk Recorder
vnsiserver (1.3.1) - VDR-Network-Streaming-Interface (VNSI) Server
epgsearch (1.0.1.beta5) - search the EPG for repeats and more
conflictcheckonly (0.0.1) - Direct access to epgsearch's conflict check menu
epgsearchonly (0.0.1) - Direct access to epgsearch's search menu
quickepgsearch (0.0.1) - Quick search for broadcasts
