Hide (or disable) certain Plex libraries
adamkex
Post by adamkex » 03 May 2019, 06:19
How do I hide some libraries which are located on the same server?
Ex: I have Movies 1, Movies 2, TV Shows 1, TV Shows 2, and Other. How can I hide or disable the "Other" library to show up in MrMC?
Audiomixer
Re: Hide (or disable) certain Plex libraries
Post by Audiomixer » 03 May 2019, 16:21
Or if one has multiple plex servers on account, is there a way to only show a selected server under movies or TV shows and then hide unwanted libraries such as adamkex describes?
Post by amet » 03 May 2019, 20:54
There is no way to hide certain libraries on the Plex server, there might be a way doing it on the Plex Server by creating a specific home user and selecting only needed libraries
adamkex
Post by adamkex » 08 May 2019, 00:43
Unfortunate, PlexKodiConnect allows me to select which ever libraries I wish to display.
