3.8.0 version, unable to exit slideshow [SOLVED]
amcfarla
I just received the new update today and discovered when in a slide show there is no way to exit. The previous vesion, a back arrow was added to exit a slide show on the screen which it looks like this version removed that back arrow and to ability to exit a slide show. If there is another way to exit a slideshow on this version I am not aware of the way to do it. Thank you.
Re: 3.8.0 version, unable to exit slideshow
2 finger swipe left would do it, I’ll have a look what happened to back button, thanks!
amcfarla
2 finger swipe isn't working for me. It just swipes to an earlier picture or rotates the image. Also I clicked on something that accidentally put this post in a solved status which it isn't solved.amet wrote: 05 Mar 2019, 02:56 2 finger swipe left would do it, I’ll have a look what happened to back button, thanks!
Tested and confirmed, thanks for letting us know.
We will get it fixed for the next release
amcfarla
Workaround is changing the skin back to Opacity which provides the exit arrow.
Re: 3.8.0 version, unable to exit slideshow [SOLVED]
Fixed for next version
amcfarla
Sweet!!! Thanks for the quick response @amet
