Cześć,
1. mam problem z oglądanie filmów 4K, tną się co kawałek, czy jest na to jakaś rada. Jak używam odtwarzacza Nova Video Player to wszystko idzie bardzo dobrze.
2. Czy jest szansa na dodatek Tidal najlepiej z tidal2 bardzo dobry w Kodi.
pozdrawiam RC
Cześć jest z Polski
Re: Cześć jest z Polski
this is English only forum, please try again
Romik2505
Hey,
I had to use a translator
1. I have a problem with watching 4K movies, they cut every piece, if there is any advice. As I use the Nova Video Player, it all goes very well.
2. Is there a chance to add Tidal preferably with tidal2 very good at Kodi.
Best regards RC
Best regards RC
1. debuglog is needed to see why you have issues.
2. we will discuss it internally, but this should really go into requests subform -> https://forum.mrmc.tv/viewforum.php?f=11
Romik2505
did you translate this log?
Romik2505
It’s still partially translated, please pull new debuglog and do not translate it
Romik2505
I glued only the part where the image began to cut and the sound did not go dst.
https://pastebin.com/XJm938GZ
Is it ok now.
Is it ok now.
