Just started using the Hue integration and I'm very impressed - what an absolutely great add-on.
However, there are some inconsistencies ... certain files give the 'ambilight' effect when played back but others not, just a steady backlight (green on my Shield, white on my FireTV 4k stick).
I'd heard that the codecs might be to blame - some not supporting the ability to extract colour/luminance data - but it seems to happen even on files that use the same coding (albeit at different resolutions).
eg. Taking two files, this one works to give the 'Ambilight' effect:
Format : Matroska
File size : 319 MiB
Duration : 41 min 59 s
Overall bit rate : 1 062 kb/s
Writing application : HandBrake 1.0.2 2017012200
Writing library : Lavf57.7.2 / Lavf57.7.2
Video
Format : AVC
Format profile : Main@L4
Format settings, CABAC : Yes
Format settings, ReFrames : 4 frames
Codec ID : V_MPEG4/ISO/AVC
Nominal bit rate : 900 kb/s
Width : 720 pixels
Height : 406 pixels
... but this one doesn't:
Format : Matroska
File size : 334 MiB
Overall bit rate : 1 113 kb/s
Video
Format : AVC
Nominal bit rate : 950 kb/s
Width : 960 pixels
Height : 540 pixels
... only real difference is the resolution.
Any ideas why one works and one doesn't?
Hue 'ambilight' mode -some files work, some not
Re: Hue 'ambilight' mode -some files work, some not
It's not codec that encoded the content but which decoder is used to decode and render.Superhans wrote: 03 Dec 2018, 23:11 Just started using the Hue integration and I'm very impressed - what an absolutely great add-on.
Format : Matroska
File size : 319 MiB
Video
Format : AVC
Width : 720 pixels
Height : 406 pixels
Format : Matroska
File size : 334 MiB
Video
Format : AVC
Width : 960 pixels
Height : 540 pixels
Superhans
I was assuming that the decoder used would depend on the codec that was being decoded - does the 960x540 res lead to the invocation of a different decoder than a 720x406 res file would?
A bit annoying if so, as I've started to encode all files for storage on my media NAS as 960x540.
Edit: The Ambilight effect is stunning by the way - great work on that.
Depends on how you have MrMC setup. Look in settings -> video -> accelerationSuperhans wrote: 03 Dec 2018, 23:36 I was assuming that the decoder used would depend on the codec that was being decoded - does the 960x540 res lead to the invocation of a different decoder than a 720x406 res file would?
- koying
Did you enable "Enable capture" in codecs?
Superhans
Yep - that did the trick, thanks!
Now all the files that I tried, work. Was it that hardware decoding kicked in above a certain res ?
- koying
There is a setting regarding using mediacodec surface for SD (width < 800), which I assume was off for you.
Surface needs capture for hue, as you noticed.
