Plex libraries in alphabetical order?
ajdthomson
Post by ajdthomson » 21 Oct 2018, 09:27
Hi - is there any way to control the order that the Plex libraries show up in MrMC? They seem to be in a random order whereas I want alphanumeric.
Alasdair
Re: Plex libraries in alphabetical order?
Post by amet » 21 Oct 2018, 15:40
Depending on the skin you are using, in opacity it’s the hidden menu on the left on Ariana it’s hidden on top... sort it by title
ajdthomson
Post by ajdthomson » 21 Oct 2018, 15:43
Hi amet - thanks, sorry i don't mean the movies themselves, just the libraries in the main menu. I am using Ariana if it matters.
Post by amet » 21 Oct 2018, 15:46
Ah, it’s pulled from plex server as it is in plex webui... I think ... would need to check
Huberer
Post by Huberer » 22 Mar 2019, 21:02
Hello,
I've the same problem with Plex Server and latest MrMC (ATV 4k). Under PMS I've several libraries (e.g. action, entertainment, documentation,....) and they're sorted in alphabetical order.
Unfortunately they're not like this in MrMC (with Opacity Skin). So it starts with "entertainment", "comedian", "action",...
It's like a random order and not alphabetical.
How can I fix that.
Thanks in advance
