Sony XE93: Action Menue taste not work
Scoty43
Post by Scoty43 » 04 Apr 2018, 19:01
Whene i play a Video in MrMc and press the Action Menu button on my remote Control the video is stoping. Therefore I can not check if Dolby Vision is activated. In Kodi 17 i have the same problem. I do not have the problem with Kodi 18 or SPMC. Can you fix this please?
Re: Sony XE93: Action Menue taste not work
Post by davilla » 04 Apr 2018, 21:18
Which platform ? Which remote ? What's 'Action Menu' ?
