Adding BOTH movie and TV sources
Glenbo
Post by Glenbo »
Hi
I have been using Kodi on an android box for a few years and I have recently installed MRMC on my iPad in order to access my video library on my NAS. However, I am experiencing an issue where I can add either movies or tv sources but cannot add both.
Once I have added one source (either movies or TV and set appropriate content) MRMC Will not give me the option to add a further source.
Once the initial library has been successfully scanned (either my movies or TV folder) there does not appear to be an option available to scan a further folder to the library.
I have selected ‘Files’ and ‘Library’ in the Video submenu but this only shows the initial library that I have created (either movies or TV shows) and does not offer a further ‘add files’ option.
I expect that I am missing something but would greatly appreciate some guidance.
Thanks 😀
Re: Adding BOTH movie and TV sources
this should be it, Videos -> FIles -> Add Videos.. -> FInd Folder and set content
Glenbo
Post by Glenbo »
Thanks for your quick response amet. :)
Unfortunately, once I have added the initial library (either movies or TV) the ‘add files’ option disappears (screen shots below) so I am unable to add a second video type.
Any ideas on how I can correct this?
