Naming a movie filename correctly
Roxpace
Post by Roxpace »
Hi
I have ended up with a problem with the movie Alien (1979), I wanna name it like I do with all other files with quality, audio and such... If I am testing searching at themoviedb.org for Alien (1979).DTS.1080p it doesn't work, it only works with Alien 1 but at once I add any additional data or use year it doesn't work.
Since Kodi/MrMC are using themoviedb.org to add information about the movies I need to find out how to solve this problem.
Looxoor
Re: Naming a movie filename correctly
Post by Looxoor »
Well, as long as the folder that contains the movie is named Alien (1979), it shouldn't matter what the name of the files are.
Don't know if this helps at all.
