Resume video playback.
Premium
Post by Premium »
MRmC does not remember where i stopped the video playback. Can not resume.
Is this a setting??
Regards
Vetekli
Re: Resume video playback.
Post by Vetekli »
It works for me, sounds like a bug. Either way they will need more details to be able to fix it.
baerwurzl
Post by baerwurzl »
Premium wrote:MRmC does not remember where i stopped the video playback. Can not resume.
Is this a setting??
Regards
When you press the Menu-Button it doenst remember, but if you play Play/Pause and then the Menu-Button it remembers where you stopped.
Premium
Post by Premium »
Is this a setting??
Regards
Thx! Just press play/pause first, then it is working! Should also work if you press menu button?? Bug??
Hansel
Post by Hansel »
Premium wrote: Should also work if you press menu button?? Bug??
Definitely
Vikingsunny
Post by Vikingsunny »
Hi all. The resume playback is not working for me either in any of my video files
I am playing movies from synology NAS added via
uPnP.
I've tried deleting and adding the share but no avail. I've tried pausing the video and then press menu but it starts from the beginning again.
Please help
Edit - it's all good. I figured that I had to connect my synology as a NFS. Cheers. But the other bug still exist if I press menu button then I can't resume. So I have to pause first before exit.
