just like to get a quick update on two topics:
- When could we expect any new skin added to MrMC ?
Currently Im using amber skin, but really like to use some modern skin like the new kodi standard skin.
- Will it ever be possible to alter remote configs on your own ?
e.g. add or edit keybindings..
Regards,
Markus
MrMC Skins and Remote
Re: MrMC Skins and Remote
viewtopic.php?f=6&t=1265
see system/keymaps/customcontroller.SiriRemote.xml in github. treat it as any typical kodi keymap
Markus23
Ok, new skin is coming soon- nice.
About the keybindings:
I know this file from the 17er kodi version, which could be tested for seven days with free apple dev. account.
But how to get the altered file into MrMC?
In kodi I could use the built-in file manager, haven't looked for in MrMC yet.
you can do the same in MrMC, place new "customcontroller.SiriRemote.xml" somwhere wher filemanager can access it then copy to userdata/keymaps/
