smb shares
pirata
smb shares
Post by pirata »
I've been having problems with my shared files for a while where the library wasn't updating, I changed scrapers and it worked for awhile. Now its not seeing my files at all. I uninstalled mrmc and reinstalled, when I try to add my smb file paths i get an error 2: shares not available. I've checked on another app on my at4 and my smb files are working there.
Re: smb shares
pirata wrote: 29 Jun 2017, 22:38 I've been having problems with my shared files for a while where the library wasn't updating, I changed scrapers and it worked for awhile. Now its not seeing my files at all. I uninstalled mrmc and reinstalled, when I try to add my smb file paths i get an error 2: shares not available. I've checked on another app on my at4 and my smb files are working there.
Double check your SMB Client settings to make sure they are identical.
pirata
Re: smb shares
Post by pirata »
It worked after i added my file paths manually.
