Problem accessing NAS after 3.0.4 update
fleksnes
Post by fleksnes »
Hi - after MrMC updated to the latest version this morning accessing my NAS (smb) has become very slow, it now takes ca 45 sec compared to a few seconds before to load the file lists. First it looks like MrMC freezes but then about 45 sec later the files appear.
Anyone else experiencing the same issue or know how to fix this..? I haven't changed anything except doing the MrMC update, and my synology NAS works as normal on my other Kodi machines
Many thanks in advance
Re: Problem accessing NAS after 3.0.4 update
switch the smb client back to using libsbmclient from lisdsm. libdsm is default now.
would like to see a debuglog under libdsm if possible, so we can see what it is doing to cause a slow down.
fleksnes
Post by fleksnes »
davilla wrote: 25 May 2017, 17:43 switch the smb client back to using libsbmclient from lisdsm. libdsm is default now.
Thanks for the quick response, that seems to have fixed it.
Here's the log: https://pastebin.com/XhhJA8v1
bmiddaugh
Post by bmiddaugh »
I'm having essentially the same issue.
When accessing smb nas shares it's tantamount to impossible. I tried the suggestion here. No good.
Bottom line.
This worked before 3.03, it doesn't work now.
A fix is needed in the MRMC software. ASAP.
bmiddaugh wrote: 27 May 2017, 02:15 I'm having essentially the same issue.
Bottom line.
Switching back to libsmbclient from libdsm should revert any issues. If not, need to see a debuglog.
bmiddaugh
Post by bmiddaugh »
Switching back gives error 2 share not available error
bmiddaugh wrote: 27 May 2017, 02:42 Switching back gives error 2 share not available error
force quit and restart MrMC.
bmiddaugh
Post by bmiddaugh »
Debug
Content of MrMC Log
22:48:01 T:6143717376 NOTICE: special://profile/ is mapped to: special://masterprofile/
22:48:01 T:6143717376 NOTICE: -----------------------------------------------------------------------
22:48:01 T:6143717376 NOTICE: Starting MrMC (3.0-4 Git:2017-05-23-62cef79). Platform: TVOS ARM64 64-bit
22:48:01 T:6143717376 NOTICE: Using Release MrMC x64 build
22:48:01 T:6143717376 NOTICE: MrMC compiled May 23 2017 by Clang 8.1.0 (clang-802.0.42) for TVOS ARM64 64-bit version 9.1.0 (90100)
22:48:01 T:6143717376 NOTICE: Running on Apple Inc. AppleTV5,3 with TVOS 10.2.1, kernel: Darwin ARM 64-bit version 16.6.0
22:48:01 T:6143717376 NOTICE: Host CPU: arm64 v8, 2 cores available
22:48:01 T:6143717376 NOTICE: ARM Features: Neon enabled
22:48:01 T:6143717376 NOTICE: special://xbmc/ is mapped to: /private/var/containers/Bundle/Application/8621C321-AD60-44D7-80A9-F75B9CCEC037/MrMC.app/AppData/AppHome
22:48:01 T:6143717376 NOTICE: special://xbmcbin/ is mapped to: /private/var/containers/Bundle/Application/8621C321-AD60-44D7-80A9-F75B9CCEC037/MrMC.app/AppData/AppHome
22:48:01 T:6143717376 NOTICE: special://masterprofile/ is mapped to: /var/mobile/Containers/Data/Application/78CCE6C5-889D-4306-B1A3-07755FBB3912/Library/Caches/home/userdata
22:48:01 T:6143717376 NOTICE: special://home/ is mapped to: /var/mobile/Containers/Data/Application/78CCE6C5-889D-4306-B1A3-07755FBB3912/Library/Caches/home
22:48:01 T:6143717376 NOTICE: special://temp/ is mapped to: /private/var/mobile/Containers/Data/Application/78CCE6C5-889D-4306-B1A3-07755FBB3912/tmp/temp
22:48:01 T:6143717376 NOTICE: special://logs/ is mapped to: /var/mobile/Containers/Data/Application/78CCE6C5-889D-4306-B1A3-07755FBB3912/Library/Caches/logs/
22:48:01 T:6143717376 NOTICE: special://frameworks/ is mapped to: /var/containers/Bundle/Application/8621C321-AD60-44D7-80A9-F75B9CCEC037/MrMC.app/Frameworks
22:48:01 T:6143717376 NOTICE: The executable running is: /var/containers/Bundle/Application/8621C321-AD60-44D7-80A9-F75B9CCEC037/MrMC.app/MrMC
22:48:01 T:6143717376 NOTICE: Local hostname: Living-Room
22:48:01 T:6143717376 NOTICE: Log File is located: special://logs/mrmc.log
22:48:01 T:6143717376 NOTICE: load settings...
22:48:01 T:6143717376 WARNING: CSettingString: unknown options filler "timezonecountries" of "locale.timezonecountry"
22:48:01 T:6143717376 WARNING: CSettingString: unknown options filler "timezones" of "locale.timezone"
22:48:01 T:6143717376 WARNING: CSettingInt: unknown options filler "audiocdactions" of "audiocds.autoaction"
22:48:01 T:6143717376 ERROR: CSetting: missing <control> tag of "videoscreen.vsync"
22:48:01 T:6143717376 WARNING: CSettingGroup: unable to read setting "videoscreen.vsync"
22:48:01 T:6143717376 NOTICE: Found 1 Lists of Devices
22:48:01 T:6143717376 NOTICE: Enumerated DARWINIOS devices:
22:48:01 T:6143717376 NOTICE: Device 1
22:48:01 T:6143717376 NOTICE: m_deviceName : default
22:48:01 T:6143717376 NOTICE: m_displayName : Default
22:48:01 T:6143717376 NOTICE: m_displayNameExtra:
22:48:01 T:6143717376 NOTICE: m_deviceType : AE_DEVTYPE_HDMI
22:48:01 T:6143717376 NOTICE: m_channels : FL,FR,FC,LFE,BL,BR
22:48:01 T:6143717376 NOTICE: m_sampleRates : 44100,48000
22:48:01 T:6143717376 NOTICE: m_dataFormats : AE_FMT_RAW,AE_FMT_S16LE,AE_FMT_FLOAT
22:48:01 T:6143717376 NOTICE: m_streamTypes : STREAM_TYPE_AC3,STREAM_TYPE_EAC3,STREAM_TYPE_DTS_512,STREAM_TYPE_DTS_1024,STREAM_TYPE_DTS_2048,STREAM_TYPE_DTSHD_CORE
22:48:02 T:6143717376 NOTICE: No settings file to load (special://xbmc/system/advancedsettings.xml)
22:48:02 T:6143717376 NOTICE: No settings file to load (special://masterprofile/advancedsettings.xml)
22:48:02 T:6143717376 NOTICE: Default DVD Player: dvdplayer
22:48:02 T:6143717376 NOTICE: Default Video Player: dvdplayer
22:48:02 T:6143717376 NOTICE: Default Audio Player: paplayer
22:48:02 T:6143717376 NOTICE: Enabled debug logging due to GUI setting (2)
22:48:02 T:6143717376 NOTICE: Log level changed to "LOG_LEVEL_DEBUG_FREEMEM"
22:48:02 T:6143717376 NOTICE: CMediaSourceSettings: loading media sources from special://masterprofile/sources.xml
22:48:02 T:6143717376 DEBUG: found key /userdata/sources.xml
22:48:02 T:6143717376 ERROR: CMediaSourceSettings: error loading special://masterprofile/sources.xml: Line 0, Failed to open file
22:48:02 T:6143717376 NOTICE: Loading player core factory settings from special://xbmc/system/playercorefactory.xml.
22:48:02 T:6143717376 DEBUG: CPlayerCoreConfig::<ctor>: created player DVDPlayer for core 1
22:48:02 T:6143717376 DEBUG: CPlayerCoreConfig::<ctor>: created player oldmplayercore for core 1
22:48:02 T:6143717376 DEBUG: CPlayerCoreConfig::<ctor>: created player PAPlayer for core 3
22:48:02 T:6143717376 DEBUG: CPlayerSelectionRule::Initialize: creating rule: system rules
22:48:02 T:6143717376 DEBUG: CPlayerSelectionRule::Initialize: creating rule: hdhomerun/mms/udp
22:48:02 T:6143717376 DEBUG: CPlayerSelectionRule::Initialize: creating rule: lastfm/shout
22:48:02 T:6143717376 DEBUG: CPlayerSelectionRule::Initialize: creating rule: rtmp
22:48:02 T:6143717376 DEBUG: CPlayerSelectionRule::Initialize: creating rule: rtsp
22:48:02 T:6143717376 DEBUG: CPlayerSelectionRule::Initialize: creating rule: streams
22:48:02 T:6143717376 DEBUG: CPlayerSelectionRule::Initialize: creating rule: aacp/sdp
22:48:02 T:6143717376 DEBUG: CPlayerSelectionRule::Initialize: creating rule: mp2
22:48:02 T:6143717376 DEBUG: CPlayerSelectionRule::Initialize: creating rule: dvd
22:48:02 T:6143717376 DEBUG: CPlayerSelectionRule::Initialize: creating rule: dvdimage
22:48:02 T:6143717376 DEBUG: CPlayerSelectionRule::Initialize: creating rule: sdp/asf
22:48:02 T:6143717376 DEBUG: CPlayerSelectionRule::Initialize: creating rule: nsv
22:48:02 T:6143717376 DEBUG: CPlayerSelectionRule::Initialize: creating rule: radio
22:48:02 T:6143717376 NOTICE: Loaded playercorefactory configuration
22:48:02 T:6143717376 DEBUG: found key /userdata/playercorefactory.xml
22:48:02 T:6143717376 NOTICE: Loading player core factory settings from special://masterprofile/playercorefactory.xml.
22:48:02 T:6143717376 NOTICE: special://masterprofile/playercorefactory.xml does not exist. Skipping.
22:48:02 T:6143717376 DEBUG: found key /userdata/wakeonlan.xml
22:48:02 T:6143717376 DEBUG: found key /userdata/profiles.xml
22:48:02 T:6143717376 DEBUG: Previous line repeats 1 times.
22:48:02 T:6143717376 DEBUG: NSUSerDefaults: compressed /userdata/profiles.xml from 923 to 324
22:48:02 T:6143717376 DEBUG: found key /userdata/guisettings.xml
22:48:02 T:6143717376 DEBUG: NSUSerDefaults: compressed /userdata/guisettings.xml from 32517 to 6199
22:48:02 T:6143717376 INFO: creating subdirectories
22:48:02 T:6143717376 INFO: userdata folder: special://masterprofile/
22:48:02 T:6143717376 INFO: recording folder:
22:48:02 T:6143717376 INFO: screenshots folder:
22:48:02 T:6144864256 INFO: CActiveAESink::OpenSink - initialize sink
22:48:02 T:6144864256 DEBUG: CActiveAESink::OpenSink - trying to open device DARWINIOS:default
22:48:02 T:6144864256 DEBUG: virtual bool CAESinkDARWINIOS::Initialize(AEAudioFormat &, std::string &): AudioStreamBasicDescription: [lpcm] Mixable Interleaved 2 Channel 32-bit Floating Point LE (48000Hz) pcm
22:48:02 T:6144864256 NOTICE: bool CAAudioUnitSink::setupAudio() setting channels 2
22:48:02 T:6144864256 NOTICE: bool CAAudioUnitSink::setupAudio() setting samplerate 48000.000000
22:48:02 T:6144864256 NOTICE: bool CAAudioUnitSink::setupAudio() setting buffer duration to 0.021333
22:48:02 T:6144864256 NOTICE: bool CAAudioUnitSink::setupAudio() total latency = 0.042708
22:48:02 T:6144864256 NOTICE: bool CAAudioUnitSink::setupAudio() setup audio format: [lpcm] Mixable Interleaved 2 Channel 32-bit Floating Point LE (48000Hz)
22:48:02 T:6144864256 NOTICE: void dumpAVAudioSessionProperties() audio route = HDMIOutput
22:48:02 T:6144864256 NOTICE: void dumpAVAudioSessionProperties() sampleRate 48000.000000
22:48:02 T:6144864256 NOTICE: void dumpAVAudioSessionProperties() outputLatency 0.000042
22:48:02 T:6144864256 NOTICE: void dumpAVAudioSessionProperties() IOBufferDuration 0.021333
22:48:02 T:6144864256 NOTICE: void dumpAVAudioSessionProperties() outputNumberOfChannels 2
22:48:02 T:6144864256 NOTICE: void dumpAVAudioSessionProperties() maximumOutputNumberOfChannels 6
22:48:02 T:6144864256 DEBUG: DumpAudioDescriptions: void dumpAVAudioSessionProperties()
22:48:02 T:6144864256 DEBUG: DumpAudioDescriptions: input count = 0
22:48:02 T:6144864256 DEBUG: DumpAudioDescriptions: output count = 1
22:48:02 T:6144864256 DEBUG: DumpAudioDescriptions : portName, HDMI
22:48:02 T:6144864256 DEBUG: DumpAudioDescriptions: channelLabel, 1
22:48:02 T:6144864256 DEBUG: DumpAudioDescriptions: channelName , HDMI 1
22:48:02 T:6144864256 DEBUG: DumpAudioDescriptions: channelLabel, 2
22:48:02 T:6144864256 DEBUG: DumpAudioDescriptions: channelName , HDMI 2
22:48:02 T:6144864256 DEBUG: CActiveAESink::OpenSink - DARWINIOS Initialized:
22:48:02 T:6144864256 DEBUG: Output Device : Default
22:48:02 T:6144864256 DEBUG: Sample Rate : 48000
22:48:02 T:6144864256 DEBUG: Sample Format : AE_FMT_FLOAT
22:48:02 T:6144864256 DEBUG: Channel Count : 2
22:48:02 T:6144864256 DEBUG: Channel Layout: FL,FR
22:48:02 T:6144864256 DEBUG: Frames : 1024
22:48:02 T:6144864256 DEBUG: Frame Size : 8
22:48:02 T:6144864256 DEBUG: CActiveAESink::GenerateNoise - noiseFactor = 0.000010
22:48:02 T:6143717376 NOTICE: Running database version Addons20
22:48:02 T:6143717376 DEBUG: SECTION:LoadDLL(libcpluff.framework/libcpluff)
22:48:02 T:6143717376 DEBUG: Loading: /var/containers/Bundle/Application/8621C321-AD60-44D7-80A9-F75B9CCEC037/MrMC.app/Frameworks/libcpluff.framework/libcpluff
22:48:02 T:6143717376 INFO: ADDON: cpluff: 'Could not read plug-in directory /var/mobile/Containers/Data/Application/78CCE6C5-889D-4306-B1A3-07755FBB3912/Library/Caches/home/addons: No such file or directory'
22:48:02 T:6143717376 DEBUG: ADDON: cpluff: 'Plug-in resource.language.ca_es has been installed.'
22:48:02 T:6143717376 DEBUG: ADDON: cpluff: 'Plug-in resource.language.az_az has been installed.'
22:48:02 T:6143717376 DEBUG: ADDON: cpluff: 'Plug-in resource.language.mt_mt has been installed.'
22:48:02 T:6143717376 DEBUG: ADDON: cpluff: 'Plug-in resource.language.eo has been installed.'
22:48:02 T:6143717376 DEBUG: ADDON: cpluff: 'Plug-in resource.language.ja_jp has been installed.'
22:48:02 T:6143717376 DEBUG: ADDON: cpluff: 'Plug-in resource.language.vi_vn has been installed.'
22:48:02 T:6143717376 DEBUG: ADDON: cpluff: 'Plug-in resource.images.weathericons.default has been installed.'
22:48:02 T:6143717376 DEBUG: ADDON: cpluff: 'Plug-in resource.language.pl_pl has been installed.'
22:48:02 T:6143717376 DEBUG: ADDON: cpluff: 'Plug-in kodi.audiodecoder has been installed.'
22:48:02 T:6143717376 DEBUG: ADDON: cpluff: 'Plug-in resource.language.en_au has been installed.'
22:48:02 T:6143717376 DEBUG: ADDON: cpluff: 'Plug-in resource.language.fr_ca has been installed.'
22:48:02 T:6143717376 DEBUG: ADDON: cpluff: 'Plug-in webinterface.default has been installed.'
22:48:02 T:6143717376 DEBUG: ADDON: cpluff: 'Plug-in pvr.argustv has been installed.'
22:48:02 T:6143717376 DEBUG: ADDON: cpluff: 'Plug-in resource.language.sr_rs has been installed.'
22:48:02 T:6143717376 DEBUG: ADDON: cpluff: 'Plug-in metadata.common.ofdb.de has been installed.'
22:48:02 T:6143717376 DEBUG: ADDON: cpluff: 'Plug-in metadata.themoviedb.org has been installed.'
22:48:02 T:6143717376 DEBUG: ADDON: cpluff: 'Plug-in resource.language.fa_af has been installed.'
22:48:02 T:6143717376 DEBUG: ADDON: cpluff: 'Plug-in skin.sio2 has been installed.'
22:48:02 T:6143717376 DEBUG: ADDON: cpluff: 'Plug-in xbmc.metadata has been installed.'
22:48:02 T:6143717376 DEBUG: ADDON: cpluff: 'Plug-in resource.language.bg_bg has been installed.'
22:48:02 T:6143717376 DEBUG: ADDON: cpluff: 'Plug-in resource.language.hu_hu has been installed.'
22:48:02 T:6143717376 DEBUG: ADDON: cpluff: 'Plug-in pvr.dvblink has been installed.'
22:48:02 T:6143717376 DEBUG: ADDON: cpluff: 'Plug-in resource.language.da_dk has been installed.'
22:48:02 T:6143717376 DEBUG: ADDON: cpluff: 'Plug-in resource.language.mk_mk has been installed.'
22:48:02 T:6143717376 DEBUG: ADDON: cpluff: 'Plug-in resource.language.pt_pt has been installed.'
22:48:02 T:6143717376 DEBUG: ADDON: cpluff: 'Plug-in resource.language.nb_no has been installed.'
22:48:02 T:6143717376 DEBUG: ADDON: cpluff: 'Plug-in resource.language.is_is has been installed.'
22:48:02 T:6143717376 DEBUG: ADDON: cpluff: 'Plug-in resource.language.ms_my has been installed.'
22:48:02 T:6143717376 DEBUG: ADDON: cpluff: 'Plug-in resource.language.sv_se has been installed.'
22:48:02 T:6143717376 DEBUG: ADDON: cpluff: 'Plug-in xbmc.gui has been installed.'
22:48:02 T:6143717376 DEBUG: ADDON: cpluff: 'Plug-in resource.language.ru_ru has been installed.'
22:48:02 T:6143717376 DEBUG: ADDON: cpluff: 'Plug-in resource.language.os_os has been installed.'
22:48:02 T:6143717376 DEBUG: ADDON: cpluff: 'Plug-in metadata.musicvideos.theaudiodb.com has been installed.'
22:48:02 T:6143717376 DEBUG: ADDON: cpluff: 'Plug-in resource.language.es_mx has been installed.'
22:48:02 T:6143717376 DEBUG: ADDON: cpluff: 'Plug-in resource.language.nl_nl has been installed.'
22:48:02 T:6143717376 DEBUG: ADDON: cpluff: 'Plug-in resource.language.ta_in has been installed.'
22:48:02 T:6143717376 DEBUG: ADDON: cpluff: 'Plug-in resource.language.gl_es has been installed.'
22:48:02 T:6143717376 DEBUG: ADDON: cpluff: 'Plug-in pvr.pctv has been installed.'
22:48:02 T:6143717376 DEBUG: ADDON: cpluff: 'Plug-in pvr.iptvsimple has been installed.'
22:48:02 T:6143717376 DEBUG: ADDON: cpluff: 'Plug-in resource.language.ko_kr has been installed.'
22:48:02 T:6143717376 DEBUG: ADDON: cpluff: 'Plug-in pvr.njoy has been installed.'
22:48:02 T:6143717376 DEBUG: ADDON: cpluff: 'Plug-in resource.language.fa_ir has been installed.'
22:48:02 T:6143717376 DEBUG: ADDON: cpluff: 'Plug-in resource.language.uz_uz has been installed.'
22:48:02 T:6143717376 DEBUG: ADDON: cpluff: 'Plug-in metadata.common.movieposterdb.com has been installed.'
22:48:02 T:6143717376 DEBUG: ADDON: cpluff: 'Plug-in resource.language.tg_tj has been installed.'
22:48:02 T:6143717376 DEBUG: ADDON: cpluff: 'Plug-in metadata.common.htbackdrops.com has been installed.'
22:48:02 T:6143717376 DEBUG: ADDON: cpluff: 'Plug-in resource.language.my_mm has been installed.'
22:48:02 T:6143717376 DEBUG: ADDON: cpluff: 'Plug-in metadata.common.port.hu has been installed.'
22:48:02 T:6143717376 DEBUG: ADDON: cpluff: 'Plug-in pvr.dvbviewer has been installed.'
22:48:02 T:6143717376 DEBUG: ADDON: cpluff: 'Plug-in resource.language.en_gb has been installed.'
22:48:02 T:6143717376 DEBUG: ADDON: cpluff: 'Plug-in skin.amber has been installed.'
22:48:02 T:6143717376 DEBUG: ADDON: cpluff: 'Plug-in visualization.spectrum has been installed.'
22:48:02 T:6143717376 DEBUG: ADDON: cpluff: 'Plug-in pvr.stalker has been installed.'
22:48:02 T:6143717376 DEBUG: ADDON: cpluff: 'Plug-in resource.language.hr_hr has been installed.'
22:48:02 T:6143717376 DEBUG: ADDON: cpluff: 'Plug-in resource.language.zh_tw has been installed.'
22:48:02 T:6143717376 DEBUG: ADDON: cpluff: 'Plug-in metadata.common.musicbrainz.org has been installed.'
22:48:02 T:6143717376 DEBUG: ADDON: cpluff: 'Plug-in resource.language.fo_fo has been installed.'
22:48:02 T:6143717376 DEBUG: ADDON: cpluff: 'Plug-in resource.language.zh_cn has been installed.'
22:48:02 T:6143717376 DEBUG: ADDON: cpluff: 'Plug-in metadata.local has been installed.'
22:48:02 T:6143717376 DEBUG: ADDON: cpluff: 'Plug-in xbmc.webinterface has been installed.'
22:48:02 T:6143717376 DEBUG: ADDON: cpluff: 'Plug-in resource.language.ro_ro has been installed.'
22:48:02 T:6143717376 DEBUG: ADDON: cpluff: 'Plug-in resource.language.fi_fi has been installed.'
22:48:02 T:6143717376 DEBUG: ADDON: cpluff: 'Plug-in metadata.common.themoviedb.org has been installed.'
22:48:02 T:6143717376 DEBUG: ADDON: cpluff: 'Plug-in resource.language.de_de has been installed.'
22:48:02 T:6143717376 DEBUG: ADDON: cpluff: 'Plug-in metadata.common.theaudiodb.com has been installed.'
22:48:02 T:6143717376 DEBUG: ADDON: cpluff: 'Plug-in pvr.filmon has been installed.'
22:48:02 T:6143717376 DEBUG: ADDON: cpluff: 'Plug-in resource.language.en_nz has been installed.'
22:48:02 T:6143717376 DEBUG: ADDON: cpluff: 'Plug-in visualization.waveform has been installed.'
22:48:02 T:6143717376 DEBUG: ADDON: cpluff: 'Plug-in resource.language.szl has been installed.'
22:48:02 T:6143717376 DEBUG: ADDON: cpluff: 'Plug-in resource.language.en_us has been installed.'
22:48:02 T:6143717376 DEBUG: ADDON: cpluff: 'Plug-in xbmc.json has been installed.'
22:48:02 T:6143717376 DEBUG: ADDON: cpluff: 'Plug-in resource.language.tr_tr has been installed.'
22:48:02 T:6143717376 DEBUG: ADDON: cpluff: 'Plug-in metadata.common.fanart.tv has been installed.'
22:48:02 T:6143717376 DEBUG: ADDON: cpluff: 'Plug-in xbmc.audioencoder has been installed.'
22:48:02 T:6143717376 DEBUG: ADDON: cpluff: 'Plug-in pvr.vbox has been installed.'
22:48:02 T:6143717376 DEBUG: ADDON: cpluff: 'Plug-in metadata.mymovies.dk has been installed.'
22:48:02 T:6143717376 DEBUG: ADDON: cpluff: 'Plug-in resource.language.id_id has been installed.'
22:48:02 T:6143717376 DEBUG: ADDON: cpluff: 'Plug-in resource.language.pt_br has been installed.'
22:48:02 T:6143717376 DEBUG: ADDON: cpluff: 'Plug-in resource.language.sk_sk has been installed.'
22:48:02 T:6143717376 DEBUG: ADDON: cpluff: 'Plug-in resource.language.th_th has been installed.'
22:48:02 T:6143717376 DEBUG: ADDON: cpluff: 'Plug-in resource.uisounds.mrmc has been installed.'
22:48:02 T:6143717376 DEBUG: ADDON: cpluff: 'Plug-in kodi.guilib has been installed.'
22:48:02 T:6143717376 DEBUG: ADDON: cpluff: 'Plug-in pvr.vdr.vnsi has been installed.'
22:48:02 T:6143717376 DEBUG: ADDON: cpluff: 'Plug-in resource.language.am_et has been installed.'
22:48:02 T:6143717376 DEBUG: ADDON: cpluff: 'Plug-in resource.language.sl_si has been installed.'
22:48:02 T:6143717376 DEBUG: ADDON: cpluff: 'Plug-in screensaver.xbmc.builtin.black has been installed.'
22:48:02 T:6143717376 DEBUG: ADDON: cpluff: 'Plug-in screensaver.xbmc.builtin.system has been installed.'
22:48:02 T:6143717376 DEBUG: ADDON: cpluff: 'Plug-in pvr.mediaportal.tvserver has been installed.'
22:48:02 T:6143717376 DEBUG: ADDON: cpluff: 'Plug-in resource.language.es_ar has been installed.'
22:48:02 T:6143717376 DEBUG: ADDON: cpluff: 'Plug-in resource.language.fr_fr has been installed.'
22:48:02 T:6143717376 DEBUG: ADDON: cpluff: 'Plug-in resource.language.eu_es has been installed.'
22:48:02 T:6143717376 DEBUG: ADDON: cpluff: 'Plug-in resource.language.bs_ba has been installed.'
22:48:02 T:6143717376 DEBUG: ADDON: cpluff: 'Plug-in resource.language.sr_rs@latin has been installed.'
22:48:02 T:6143717376 DEBUG: ADDON: cpluff: 'Plug-in metadata.universal has been installed.'
22:48:02 T:6143717376 DEBUG: ADDON: cpluff: 'Plug-in resource.language.cs_cz has been installed.'
22:48:02 T:6143717376 DEBUG: ADDON: cpluff: 'Plug-in resource.language.mi has been installed.'
22:48:02 T:6143717376 DEBUG: ADDON: cpluff: 'Plug-in screensaver.xbmc.builtin.dim has been installed.'
22:48:02 T:6143717376 DEBUG: ADDON: cpluff: 'Plug-in skin.mrmc has been installed.'
22:48:02 T:6143717376 DEBUG: ADDON: cpluff: 'Plug-in resource.language.el_gr has been installed.'
22:48:02 T:6143717376 DEBUG: ADDON: cpluff: 'Plug-in resource.language.hi_in has been installed.'
22:48:02 T:6143717376 DEBUG: ADDON: cpluff: 'Plug-in resource.language.sq_al has been installed.'
22:48:02 T:6143717376 DEBUG: ADDON: cpluff: 'Plug-in pvr.wmc has been installed.'
22:48:02 T:6143717376 DEBUG: ADDON: cpluff: 'Plug-in resource.language.ml_in has been installed.'
22:48:02 T:6143717376 DEBUG: ADDON: cpluff: 'Plug-in pvr.hdhomerun has been installed.'
22:48:02 T:6143717376 DEBUG: ADDON: cpluff: 'Plug-in resource.language.cy_gb has been installed.'
22:48:02 T:6143717376 DEBUG: ADDON: cpluff: 'Plug-in kodi.resource has been installed.'
22:48:02 T:6143717376 DEBUG: ADDON: cpluff: 'Plug-in resource.language.af_za has been installed.'
22:48:02 T:6143717376 DEBUG: ADDON: cpluff: 'Plug-in resource.language.uk_ua has been installed.'
22:48:02 T:6143717376 DEBUG: ADDON: cpluff: 'Plug-in resource.language.hy_am has been installed.'
22:48:02 T:6143717376 DEBUG: ADDON: cpluff: 'Plug-in pvr.mythtv has been installed.'
22:48:02 T:6143717376 DEBUG: ADDON: cpluff: 'Plug-in pvr.vuplus has been installed.'
22:48:02 T:6143717376 DEBUG: ADDON: cpluff: 'Plug-in resource.language.it_it has been installed.'
22:48:02 T:6143717376 DEBUG: ADDON: cpluff: 'Plug-in resource.language.lt_lt has been installed.'
22:48:02 T:6143717376 DEBUG: ADDON: cpluff: 'Plug-in resource.language.si_lk has been installed.'
22:48:02 T:6143717376 DEBUG: ADDON: cpluff: 'Plug-in xbmc.core has been installed.'
22:48:02 T:6143717376 DEBUG: ADDON: cpluff: 'Plug-in resource.language.ar_sa has been installed.'
22:48:02 T:6143717376 DEBUG: ADDON: cpluff: 'Plug-in resource.language.mn_mn has been installed.'
22:48:02 T:6143717376 DEBUG: ADDON: cpluff: 'Plug-in resource.language.lv_lv has been installed.'
22:48:02 T:6143717376 DEBUG: ADDON: cpluff: 'Plug-in skin.pm3-hd has been installed.'
22:48:02 T:6143717376 DEBUG: ADDON: cpluff: 'Plug-in resource.language.te_in has been installed.'
22:48:02 T:6143717376 DEBUG: ADDON: cpluff: 'Plug-in xbmc.pvr has been installed.'
22:48:02 T:6143717376 DEBUG: ADDON: cpluff: 'Plug-in pvr.nextpvr has been installed.'
22:48:02 T:6143717376 DEBUG: ADDON: cpluff: 'Plug-in resource.uisounds.amber has been installed.'
22:48:02 T:6143717376 DEBUG: ADDON: cpluff: 'Plug-in metadata.album.universal has been installed.'
22:48:02 T:6143717376 DEBUG: ADDON: cpluff: 'Plug-in resource.language.et_ee has been installed.'
22:48:02 T:6143717376 DEBUG: ADDON: cpluff: 'Plug-in metadata.common.allmusic.com has been installed.'
22:48:02 T:6143717376 DEBUG: ADDON: cpluff: 'Plug-in metadata.tvdb.com has been installed.'
22:48:02 T:6143717376 DEBUG: ADDON: cpluff: 'Plug-in metadata.common.omdbapi.com has been installed.'
22:48:02 T:6143717376 DEBUG: ADDON: cpluff: 'Plug-in metadata.artists.universal has been installed.'
22:48:02 T:6143717376 DEBUG: ADDON: cpluff: 'Plug-in metadata.common.imdb.com has been installed.'
22:48:02 T:6143717376 DEBUG: ADDON: cpluff: 'Plug-in resource.language.he_il has been installed.'
22:48:02 T:6143717376 DEBUG: ADDON: cpluff: 'Plug-in pvr.hts has been installed.'
22:48:02 T:6143717376 DEBUG: ADDON: cpluff: 'Plug-in xbmc.addon has been installed.'
22:48:02 T:6143717376 DEBUG: ADDON: cpluff: 'Plug-in xbmc.codec has been installed.'
22:48:02 T:6143717376 DEBUG: ADDON: cpluff: 'Plug-in resource.language.be_by has been installed.'
22:48:02 T:6143717376 DEBUG: ADDON: cpluff: 'Plug-in resource.language.es_es has been installed.'
22:48:02 T:6143717376 DEBUG: ADDON: cpluff: 'Not all directories were successfully scanned.'
22:48:02 T:6143717376 INFO: CKeyboardLayoutManager: loading keyboard layouts from special://xbmc/system/keyboardlayouts...
22:48:02 T:6143717376 DEBUG: CKeyboardLayoutManager: keyboard layout "Arabic QWERTY" successfully loaded
22:48:02 T:6143717376 DEBUG: CKeyboardLayoutManager: keyboard layout "Bulgarian ЯВЕРТЪ" successfully loaded
22:48:02 T:6143717376 DEBUG: CKeyboardLayoutManager: keyboard layout "Bulgarian АБВ" successfully loaded
22:48:02 T:6143717376 DEBUG: CKeyboardLayoutManager: keyboard layout "Chinese BasePY" successfully loaded
22:48:02 T:6143717376 DEBUG: CKeyboardLayoutManager: keyboard layout "Chinese BaiduPY" successfully loaded
22:48:02 T:6143717376 DEBUG: CKeyboardLayoutManager: keyboard layout "Czech QWERTZ" successfully loaded
22:48:02 T:6143717376 DEBUG: CKeyboardLayoutManager: keyboard layout "Danish QWERTY" successfully loaded
22:48:02 T:6143717376 DEBUG: CKeyboardLayoutManager: keyboard layout "English QWERTY" successfully loaded
22:48:02 T:6143717376 DEBUG: CKeyboardLayoutManager: keyboard layout "English AZERTY" successfully loaded
22:48:02 T:6143717376 DEBUG: CKeyboardLayoutManager: keyboard layout "English ABC" successfully loaded
22:48:02 T:6143717376 DEBUG: CKeyboardLayoutManager: keyboard layout "French AZERTY" successfully loaded
22:48:02 T:6143717376 DEBUG: CKeyboardLayoutManager: keyboard layout "German QWERTZ" successfully loaded
22:48:02 T:6143717376 DEBUG: CKeyboardLayoutManager: keyboard layout "Greek QWERTY" successfully loaded
22:48:02 T:6143717376 DEBUG: CKeyboardLayoutManager: keyboard layout "Hebrew QWERTY" successfully loaded
22:48:02 T:6143717376 DEBUG: CKeyboardLayoutManager: keyboard layout "Hebrew ABC" successfully loaded
22:48:02 T:6143717376 DEBUG: CKeyboardLayoutManager: keyboard layout "Hungarian QWERTZ" successfully loaded
22:48:02 T:6143717376 DEBUG: CKeyboardLayoutManager: keyboard layout "Korean ㄱㄴㄷ" successfully loaded
22:48:02 T:6143717376 DEBUG: CKeyboardLayoutManager: keyboard layout "Lithuanian AZERTY" successfully loaded
22:48:02 T:6143717376 DEBUG: CKeyboardLayoutManager: keyboard layout "Lithuanian QWERTY" successfully loaded
22:48:02 T:6143717376 DEBUG: CKeyboardLayoutManager: keyboard layout "Norwegian QWERTY" successfully loaded
22:48:02 T:6143717376 DEBUG: CKeyboardLayoutManager: keyboard layout "Polish QWERTY" successfully loaded
22:48:02 T:6143717376 DEBUG: CKeyboardLayoutManager: keyboard layout "Portuguese (Portugal) QWERTY" successfully loaded
22:48:02 T:6143717376 DEBUG: CKeyboardLayoutManager: keyboard layout "Romanian QWERTY" successfully loaded
22:48:02 T:6143717376 DEBUG: CKeyboardLayoutManager: keyboard layout "Russian ЙЦУКЕН" successfully loaded
22:48:02 T:6143717376 DEBUG: CKeyboardLayoutManager: keyboard layout "Russian АБВ" successfully loaded
22:48:02 T:6143717376 DEBUG: CKeyboardLayoutManager: keyboard layout "Spanish QWERTY" successfully loaded
22:48:02 T:6143717376 DEBUG: CKeyboardLayoutManager: keyboard layout "Swedish QWERTY" successfully loaded
22:48:02 T:6143717376 DEBUG: CKeyboardLayoutManager: keyboard layout "Turkish QWERTY" successfully loaded
22:48:02 T:6143717376 DEBUG: CKeyboardLayoutManager: keyboard layout "Ukrainian ЙЦУКЕН" successfully loaded
22:48:02 T:6143717376 DEBUG: CKeyboardLayoutManager: keyboard layout "Ukrainian АБВ" successfully loaded
22:48:02 T:6143717376 DEBUG: Current resolution Screen: 0 with 1920 x 1080
22:48:02 T:6143717376 NOTICE: Found possible resolution for display 0 with 1920 x 1080
22:48:02 T:6143717376 NOTICE: Checking resolution 16
22:48:02 T:6143717376 DEBUG: About to switch to 1920 x 1080 on screen 0
22:48:02 T:6143717376 DEBUG: Found matching mode
22:48:02 T:6143717376 INFO: GLES: Maximum texture width: 2048
22:48:02 T:6143717376 DEBUG: EGL_EXTENSIONS: GL_OES_standard_derivatives GL_KHR_texture_compression_astc_ldr GL_EXT_color_buffer_half_float GL_EXT_debug_label GL_EXT_debug_marker GL_EXT_pvrtc_sRGB GL_EXT_read_format_bgra GL_EXT_separate_shader_objects GL_EXT_shader_framebuffer_fetch GL_EXT_shader_texture_lod GL_EXT_shadow_samplers GL_EXT_texture_filter_anisotropic GL_APPLE_clip_distance GL_APPLE_color_buffer_packed_float GL_APPLE_copy_texture_levels GL_APPLE_rgb_422 GL_APPLE_texture_format_BGRA8888 GL_IMG_read_format GL_IMG_texture_compression_pvrtc
22:48:02 T:6143717376 NOTICE: GL_VENDOR = Apple Inc.
22:48:02 T:6143717376 NOTICE: GL_RENDERER = Apple A8 GPU
22:48:02 T:6143717376 NOTICE: GL_VERSION = OpenGL ES 3.0 Apple A8 GPU - 96.27.1
22:48:02 T:6143717376 NOTICE: GL_SHADING_LANGUAGE_VERSION = OpenGL ES GLSL ES 3.00
22:48:02 T:6143717376 DEBUG: GLES: Extension Support Test - GL_NVX_gpu_memory_info NO
22:48:02 T:6143717376 NOTICE: GL_EXTENSIONS = GL_OES_standard_derivatives GL_KHR_texture_compression_astc_ldr GL_EXT_color_buffer_half_float GL_EXT_debug_label GL_EXT_debug_marker GL_EXT_pvrtc_sRGB GL_EXT_read_format_bgra GL_EXT_separate_shader_objects GL_EXT_shader_framebuffer_fetch GL_EXT_shader_texture_lod GL_EXT_shadow_samplers GL_EXT_texture_filter_anisotropic GL_APPLE_clip_distance GL_APPLE_color_buffer_packed_float GL_APPLE_copy_texture_levels GL_APPLE_rgb_422 GL_APPLE_texture_format_BGRA8888 GL_IMG_read_format GL_IMG_texture_compression_pvrtc
22:48:02 T:6143717376 DEBUG: GLES: Extension Support Test - GL_EXT_texture_format_BGRA8888 NO
22:48:02 T:6143717376 DEBUG: GLES: Extension Support Test - GL_IMG_texture_format_BGRA8888 NO
22:48:02 T:6143717376 DEBUG: GLES: Extension Support Test - GL_APPLE_texture_format_BGRA8888 YES
22:48:02 T:6143717376 DEBUG: GLES: Extension Support Test - GL_EXT_unpack_subimage NO
22:48:02 T:6143717376 DEBUG: GUI Shader [guishader_frag_default.glsl]- Initialise successful : 0x17010d890
22:48:02 T:6143717376 DEBUG: GUI Shader [guishader_frag_texture.glsl]- Initialise successful : 0x17010d9b0
22:48:02 T:6143717376 DEBUG: GUI Shader [guishader_frag_multi.glsl]- Initialise successful : 0x17010da40
22:48:02 T:6143717376 DEBUG: GUI Shader [guishader_frag_fonts.glsl]- Initialise successful : 0x17010dc80
22:48:02 T:6143717376 DEBUG: GUI Shader [guishader_frag_texture_noblend.glsl]- Initialise successful : 0x17010dd10
22:48:02 T:6143717376 DEBUG: GUI Shader [guishader_frag_multi_blendcolor.glsl]- Initialise successful : 0x17010de30
22:48:02 T:6143717376 DEBUG: GUI Shader [guishader_frag_rgba.glsl]- Initialise successful : 0x17010dda0
22:48:02 T:6143717376 DEBUG: GLES: Extension Support Test - GL_OES_EGL_image_external NO
22:48:02 T:6143717376 DEBUG: GUI Shader [guishader_frag_rgba_blendcolor.glsl]- Initialise successful : 0x17010dec0
22:48:02 T:6143717376 DEBUG: GUI Shader [guishader_frag_rgba_bob.glsl]- Initialise successful : 0x17010df50
22:48:02 T:6143717376 INFO: GLES: Maximum texture width: 8192
22:48:02 T:6143717376 INFO: load keymapping
22:48:02 T:6143717376 INFO: Loading special://xbmc/system/keymaps/joystick.AppleRemote.xml
22:48:02 T:6143717376 INFO: Loading special://xbmc/system/keymaps/keyboard.xml
22:48:02 T:6143717376 INFO: GUI format 1920x1080, Display 1920x1080
22:48:02 T:6143717376 DEBUG: guilib: Fill viewport on change for solving rendering passes
22:48:02 T:6143717376 INFO: CLangInfo: loading resource.language.en_gb language information...
22:48:02 T:6143717376 DEBUG: trying to set locale to en_US.UTF-8
22:48:02 T:6143717376 INFO: global locale set to C
22:48:02 T:6143717376 INFO: CLangInfo: loading resource.language.en_gb language strings...
22:48:02 T:6143717376 DEBUG: POParser: loaded 3740 strings from file resource://resource.language.en_gb/strings.po
22:48:02 T:6146011136 NOTICE: Running database version Addons20
22:48:02 T:6146011136 DEBUG: Initialize, updating databases...
22:48:02 T:6146011136 NOTICE: Running database version ViewModes6
22:48:02 T:6146011136 NOTICE: Running database version Textures13
22:48:02 T:6146011136 NOTICE: Running database version MyMusic60
22:48:02 T:6146011136 NOTICE: Running database version MyVideos107
22:48:02 T:6146011136 NOTICE: Running database version TV29
22:48:02 T:6146011136 NOTICE: Running database version Epg11
22:48:02 T:6146011136 DEBUG: Initialize, updating databases... DONE
22:48:02 T:6143717376 INFO: DPMS: not supported on this platform
22:48:02 T:6143717376 DEBUG: found key /userdata/modulepasswords.xml
22:48:02 T:6143717376 DEBUG: found key /userdata/addon_data/skin.mrmc/settings.xml
22:48:02 T:6143717376 INFO: Unloading old skin ...
22:48:02 T:6143717376 INFO: load skin from: /private/var/containers/Bundle/Application/8621C321-AD60-44D7-80A9-F75B9CCEC037/MrMC.app/AppData/AppHome/addons/skin.mrmc (version: 2.8.7)
22:48:02 T:6143717376 INFO: load fonts for skin...
22:48:02 T:6143717376 INFO: Loading fonts from /private/var/containers/Bundle/Application/8621C321-AD60-44D7-80A9-F75B9CCEC037/MrMC.app/AppData/AppHome/addons/skin.mrmc/720p/Font.xml
22:48:02 T:6143717376 DEBUG: POParser: loaded 150 strings from file /private/var/containers/Bundle/Application/8621C321-AD60-44D7-80A9-F75B9CCEC037/MrMC.app/AppData/AppHome/addons/skin.mrmc/language/resource.language.en_gb/strings.po
22:48:02 T:6143717376 INFO: Loading skin includes from /private/var/containers/Bundle/Application/8621C321-AD60-44D7-80A9-F75B9CCEC037/MrMC.app/AppData/AppHome/addons/skin.mrmc/720p/includes.xml
22:48:03 T:6143717376 INFO: load new skin...
22:48:03 T:6143717376 INFO: Loading user windows, path /private/var/containers/Bundle/Application/8621C321-AD60-44D7-80A9-F75B9CCEC037/MrMC.app/AppData/AppHome/addons/skin.mrmc/720p
22:48:03 T:6143717376 DEBUG: Load Skin XML: 17.93ms
22:48:03 T:6143717376 INFO: initialize new skin...
22:48:03 T:6143717376 DEBUG: guilib: Fill viewport on change for solving rendering passes
22:48:03 T:6143717376 INFO: Loading skin file: Pointer.xml, load type: LOAD_ON_GUI_INIT
22:48:03 T:6143717376 DEBUG: OpenBundle - Opened bundle /private/var/containers/Bundle/Application/8621C321-AD60-44D7-80A9-F75B9CCEC037/MrMC.app/AppData/AppHome/addons/skin.mrmc/media/Textures.xbt
22:48:03 T:6143717376 INFO: Loading skin file: DialogVolumeBar.xml, load type: LOAD_ON_GUI_INIT
22:48:03 T:6143717376 INFO: Loading skin file: DialogKaiToast.xml, load type: LOAD_ON_GUI_INIT
22:48:03 T:6143717376 INFO: Loading skin file: DialogMuteBug.xml, load type: LOAD_ON_GUI_INIT
22:48:03 T:6143717376 INFO: Loading skin file: DialogSeekBar.xml, load type: LOAD_ON_GUI_INIT
22:48:03 T:6143717376 INFO: Loading skin file: DialogBusy.xml, load type: LOAD_ON_GUI_INIT
22:48:03 T:6143717376 INFO: Loading skin file: DialogExtendedProgressBar.xml, load type: LOAD_ON_GUI_INIT
22:48:03 T:6143717376 INFO: Loading resource://resource.uisounds.mrmc/sounds.xml
22:48:03 T:6143717376 INFO: skin loaded...
22:48:03 T:6143717376 DEBUG: JSONRPC: JSON schema type definition references an unknown type Setting.Details.Setting
22:48:03 T:6143717376 WARNING: JSONRPC: Could not parse type "Setting.Details.SettingList"
22:48:03 T:6143717376 INFO: JSONRPC: Adding type "Setting.Details.SettingList" to list of incomplete definitions (waiting for "Setting.Details.Setting")
22:48:03 T:6143717376 INFO: JSONRPC: Resolving incomplete types/methods referencing Setting.Details.Setting
22:48:03 T:6143717376 INFO: JSONRPC v6.32.5: Successfully initialized
22:48:03 T:6143717376 DEBUG: ADDON: Starting service addons.
22:48:03 T:6143717376 DEBUG: Activating window ID: 12999
22:48:03 T:6143717376 DEBUG: ------ Window Init (Startup.xml) ------
22:48:03 T:6143717376 INFO: Loading skin file: Startup.xml, load type: LOAD_EVERY_TIME
22:48:03 T:6143717376 NOTICE: ActiveAE DSP - starting
22:48:03 T:6143717376 INFO: removing tempfiles
22:48:03 T:6143717376 NOTICE: initialize done
22:48:03 T:6143717376 NOTICE: Running the application...
22:48:03 T:6143717376 DEBUG: Activating window ID: 10000
22:48:03 T:6143717376 INFO: GLES: Enabling VSYNC
22:48:03 T:6143717376 INFO: GLES: Selected vsync mode 10
22:48:03 T:6143717376 DEBUG: ------ Window Deinit (Startup.xml) ------
22:48:03 T:6143717376 DEBUG: ------ Window Init (Home.xml) ------
22:48:03 T:6143717376 INFO: Loading skin file: Home.xml, load type: KEEP_IN_MEMORY
22:48:03 T:6146011136 DEBUG: CHomeShelfJob::UpdateMusic() - Running HomeShelf screen update
22:48:03 T:6143717376 DEBUG: NetworkMessage - Starting network services
22:48:03 T:6143717376 NOTICE: starting zeroconf publishing
22:48:03 T:6143717376 NOTICE: WebServer: Started the webserver
22:48:03 T:6143717376 NOTICE: starting upnp client
22:48:03 T:6146011136 DEBUG: CHomeShelfJob::UpdateVideos() - Running HomeShelf screen update
22:48:03 T:6146584576 DEBUG: CZeroconfOSX::doPublishService identifier: servers.webserver type: _http._tcp name:MrMC (Living-Room) port:8080
22:48:03 T:6146584576 DEBUG: CZeroconfOSX::doPublishService identifier: servers.jsonrpc-http type: _xbmc-jsonrpc-h._tcp name:MrMC (Living-Room) port:8080
22:48:03 T:6143717376 INFO: JSONRPC Server: Successfully initialized
22:48:03 T:6152794112 NOTICE: ES: Starting UDP Event server on 127.0.0.1:9777
22:48:03 T:6143717376 DEBUG: CTCPServer: increasing thread stack to 1048576
22:48:03 T:6152794112 NOTICE: UDP: Listening on port 9777
22:48:03 T:6146584576 DEBUG: CZeroconfOSX::doPublishService identifier: servers.jsonrpc-tpc type: _xbmc-jsonrpc._tcp name:MrMC (Living-Room) port:9090
22:48:03 T:6146584576 DEBUG: CZeroconfOSX::doPublishService identifier: servers.eventserver type: _xbmc-events._udp name:MrMC (Living-Room) port:9777
22:48:03 T:6146011136 DEBUG: CHomeShelfJob::UpdateTotal() - Running HomeShelf home screen update
22:48:03 T:6146011136 DEBUG: CHomeShelfJob::UpdateTotal() - Finished
22:48:03 T:6146584576 DEBUG: CHomeShelfJob::UpdateTotal() - Running HomeShelf home screen update
22:48:03 T:6146584576 DEBUG: CHomeShelfJob::UpdateTotal() - Finished
22:48:03 T:6144290816 DEBUG: CActiveAE - device change event
22:48:03 T:6144290816 DEBUG: EnumerateDevices:Device(default)
22:48:03 T:6144290816 NOTICE: Found 1 Lists of Devices
22:48:03 T:6144290816 NOTICE: Enumerated DARWINIOS devices:
22:48:03 T:6144290816 NOTICE: Device 1
22:48:03 T:6144290816 NOTICE: m_deviceName : default
22:48:03 T:6144290816 NOTICE: m_displayName : Default
22:48:03 T:6144290816 NOTICE: m_displayNameExtra:
22:48:03 T:6144290816 NOTICE: m_deviceType : AE_DEVTYPE_HDMI
22:48:03 T:6144290816 NOTICE: m_channels : FL,FR,FC,LFE,BL,BR
22:48:03 T:6144290816 NOTICE: m_sampleRates : 44100,48000
22:48:03 T:6144290816 NOTICE: m_dataFormats : AE_FMT_RAW,AE_FMT_S16LE,AE_FMT_FLOAT
22:48:03 T:6144290816 NOTICE: m_streamTypes : STREAM_TYPE_AC3,STREAM_TYPE_EAC3,STREAM_TYPE_DTS_512,STREAM_TYPE_DTS_1024,STREAM_TYPE_DTS_2048,STREAM_TYPE_DTSHD_CORE
22:48:03 T:6144864256 INFO: CActiveAESink::OpenSink - initialize sink
22:48:03 T:6144864256 DEBUG: CActiveAESink::OpenSink - trying to open device DARWINIOS:default
22:48:03 T:6144864256 DEBUG: virtual bool CAESinkDARWINIOS::Initialize(AEAudioFormat &, std::string &): AudioStreamBasicDescription: [lpcm] Mixable Interleaved 2 Channel 32-bit Floating Point LE (48000Hz) pcm
22:48:03 T:6144864256 NOTICE: bool CAAudioUnitSink::setupAudio() setting channels 2
22:48:03 T:6144864256 NOTICE: bool CAAudioUnitSink::setupAudio() setting samplerate 48000.000000
22:48:03 T:6144864256 NOTICE: bool CAAudioUnitSink::setupAudio() setting buffer duration to 0.021333
22:48:03 T:6144864256 NOTICE: bool CAAudioUnitSink::setupAudio() total latency = 0.042708
22:48:03 T:6144864256 NOTICE: bool CAAudioUnitSink::setupAudio() setup audio format: [lpcm] Mixable Interleaved 2 Channel 32-bit Floating Point LE (48000Hz)
22:48:03 T:6144864256 NOTICE: void dumpAVAudioSessionProperties() audio route = HDMIOutput
22:48:03 T:6144864256 NOTICE: void dumpAVAudioSessionProperties() sampleRate 48000.000000
22:48:03 T:6144864256 NOTICE: void dumpAVAudioSessionProperties() outputLatency 0.000042
22:48:03 T:6144864256 NOTICE: void dumpAVAudioSessionProperties() IOBufferDuration 0.021333
22:48:03 T:6144864256 NOTICE: void dumpAVAudioSessionProperties() outputNumberOfChannels 2
22:48:03 T:6144864256 NOTICE: void dumpAVAudioSessionProperties() maximumOutputNumberOfChannels 6
22:48:03 T:6144864256 DEBUG: DumpAudioDescriptions: void dumpAVAudioSessionProperties()
22:48:03 T:6144864256 DEBUG: DumpAudioDescriptions: input count = 0
22:48:03 T:6144864256 DEBUG: DumpAudioDescriptions: output count = 1
22:48:03 T:6144864256 DEBUG: DumpAudioDescriptions : portName, HDMI
22:48:03 T:6144864256 DEBUG: DumpAudioDescriptions: channelLabel, 1
22:48:03 T:6144864256 DEBUG: DumpAudioDescriptions: channelName , HDMI 1
22:48:03 T:6144864256 DEBUG: DumpAudioDescriptions: channelLabel, 2
22:48:03 T:6144864256 DEBUG: DumpAudioDescriptions: channelName , HDMI 2
22:48:03 T:6144864256 DEBUG: CActiveAESink::OpenSink - DARWINIOS Initialized:
22:48:03 T:6144864256 DEBUG: Output Device : Default
22:48:03 T:6144864256 DEBUG: Sample Rate : 48000
22:48:03 T:6144864256 DEBUG: Sample Format : AE_FMT_FLOAT
22:48:03 T:6144864256 DEBUG: Channel Count : 2
22:48:03 T:6144864256 DEBUG: Channel Layout: FL,FR
22:48:03 T:6144864256 DEBUG: Frames : 1024
22:48:03 T:6144864256 DEBUG: Frame Size : 8
22:48:03 T:6144864256 DEBUG: CActiveAESink::GenerateNoise - noiseFactor = 0.000010
22:48:03 T:6144290816 DEBUG: CActiveAE::ClearDiscardedBuffers - buffer pool deleted
22:48:04 T:6154579968 DEBUG: Got rss feed: https://mrmc.tv/feed/
22:48:04 T:6154579968 DEBUG: RSS feed encoding: UTF-8
22:48:04 T:6154579968 DEBUG: Parsed rss feed: https://mrmc.tv/feed/
22:48:08 T:6143717376 DEBUG: Keyboard: scancode: 0x00, sym: 0x0114, unicode: 0x0000, modifier: 0x0
22:48:08 T:6143717376 DEBUG: OnKey: left (0xf082) pressed, action is Left
22:48:09 T:6143717376 DEBUG: Keyboard: scancode: 0x00, sym: 0x000d, unicode: 0x0000, modifier: 0x0
22:48:09 T:6143717376 DEBUG: OnKey: return (0xf00d) pressed, action is Select
22:48:09 T:6143717376 DEBUG: Activating window ID: 10002
22:48:09 T:6143717376 DEBUG: ------ Window Deinit (Home.xml) ------
22:48:09 T:6143717376 DEBUG: ------ Window Init (MyPics.xml) ------
22:48:09 T:6143717376 INFO: Loading skin file: MyPics.xml, load type: KEEP_IN_MEMORY
22:48:10 T:6143717376 DEBUG: Keyboard: scancode: 0x00, sym: 0x000d, unicode: 0x0000, modifier: 0x0
22:48:10 T:6143717376 DEBUG: OnKey: return (0xf00d) pressed, action is Select
22:48:10 T:6143717376 INFO: Loading skin file: DialogMediaSource.xml, load type: KEEP_IN_MEMORY
22:48:10 T:6143717376 DEBUG: ------ Window Init (DialogMediaSource.xml) ------
22:48:11 T:6143717376 DEBUG: Keyboard: scancode: 0x00, sym: 0x0113, unicode: 0x0000, modifier: 0x0
22:48:11 T:6143717376 DEBUG: OnKey: right (0xf083) pressed, action is Right
22:48:12 T:6143717376 DEBUG: Keyboard: scancode: 0x00, sym: 0x000d, unicode: 0x0000, modifier: 0x0
22:48:12 T:6143717376 DEBUG: OnKey: return (0xf00d) pressed, action is Select
22:48:12 T:6143717376 INFO: Loading skin file: FileBrowser.xml, load type: KEEP_IN_MEMORY
22:48:12 T:6143717376 DEBUG: found key /userdata/mediasources.xml
22:48:12 T:6143717376 DEBUG: ------ Window Init (FileBrowser.xml) ------
22:48:13 T:6143717376 DEBUG: Keyboard: scancode: 0x00, sym: 0x0112, unicode: 0x0000, modifier: 0x0
22:48:13 T:6143717376 DEBUG: OnKey: down (0xf081) pressed, action is Down
22:48:14 T:6143717376 DEBUG: Keyboard: scancode: 0x00, sym: 0x0112, unicode: 0x0000, modifier: 0x0
22:48:14 T:6143717376 DEBUG: OnKey: down (0xf081) pressed, action is Down
22:48:14 T:6143717376 DEBUG: Keyboard: scancode: 0x00, sym: 0x000d, unicode: 0x0000, modifier: 0x0
22:48:14 T:6143717376 DEBUG: OnKey: return (0xf00d) pressed, action is Select
22:48:14 T:6146584576 DEBUG: SECTION:LoadDLL(libdsm.framework/libdsm)
22:48:14 T:6146584576 DEBUG: Loading: /var/containers/Bundle/Application/8621C321-AD60-44D7-80A9-F75B9CCEC037/MrMC.app/Frameworks/libdsm.framework/libdsm
22:48:14 T:6140850176 DEBUG: DllLibDSM:ns_discover_on_entry_added name(TV-COMPUTER), address(192.168.0.251)
22:48:14 T:6140850176 DEBUG: DllLibDSM:ns_discover_on_entry_added name(WOO-WOO-AIRPORT), address(192.168.0.111)
22:48:14 T:6140850176 DEBUG: DllLibDSM:ns_discover_on_entry_added name(BRETTS-IMAC-2), address(192.168.0.95)
22:48:14 T:6140850176 DEBUG: DllLibDSM:ns_discover_on_entry_added name(BRETT-MAC-PRO), address(192.168.0.199)
22:48:14 T:6140850176 DEBUG: DllLibDSM:ns_discover_on_entry_added name(CHATEAU-WOO-WOO), address(192.168.0.14)
22:48:15 T:6143717376 DEBUG: Keyboard: scancode: 0x00, sym: 0x0112, unicode: 0x0000, modifier: 0x0
22:48:15 T:6143717376 DEBUG: OnKey: down (0xf081) pressed, action is Down
22:48:16 T:6143717376 DEBUG: Keyboard: scancode: 0x00, sym: 0x0112, unicode: 0x0000, modifier: 0x0
22:48:16 T:6143717376 DEBUG: OnKey: down (0xf081) pressed, action is Down
22:48:16 T:6143717376 DEBUG: Keyboard: scancode: 0x00, sym: 0x000d, unicode: 0x0000, modifier: 0x0
22:48:16 T:6143717376 DEBUG: OnKey: return (0xf00d) pressed, action is Select
22:48:16 T:6146011136 DEBUG: found key /userdata/passwords.xml
22:48:17 T:6146011136 DEBUG: Previous line repeats 1 times.
22:48:17 T:6146011136 DEBUG: getaddrinfo: 'CHATEAU-WOO-WOO' -> '92.242.140.21'
22:48:17 T:6143717376 DEBUG: ------ Window Init (DialogBusy.xml) ------
22:48:18 T:6146011136 DEBUG: CDSMSession: Failed to resolve netbios name, using hostname
bmiddaugh
Post by bmiddaugh »
I see no way to force quit mrmc on the appletv. I did do a restart of the appletv several times enabling and disabling libdsm.
it's still enabled. uncheck the checkbox and do not check it again.
https://www.howtogeek.com/232960/how-to ... -apple-tv/
