Remember my place
jabohn
Remember my place
Post by jabohn »
If you switch out of MrMC to another app, later when you come back it remembers where you were. Even if I go to another part of the library, say a specific TV show, the selection would be where I was the last time I was there.
All of this is wiped out when the app has been quit and reloads. It's always been this way even with Kodi and XBMC and I've always found it annoying. Is it possible to have MrMC save all this info of where you left off so if the app needs to reload it will be retained? Does that make sense?
Re: Remember my place
Sure, makes sense. Possible it could be remembered but we would have to handle exceptions if the nav'ed location is slow to restore (pvr or native client browse points). To keep this from getting lost, I suggest adding an 'issue' -> https://github.com/MrMC/mrmc/issues .
