Dolby Vision
Grencola
Re: Dolby Vision
Post by Grencola »
yusesope wrote: 21 Jul 2019, 19:20
rhadamants wrote: 21 Jul 2019, 03:28 You converted this sample?
Yep!
May I ask which program you used to put lossless audio into an mp4?? :D
yusesope
Re: Dolby Vision
Post by yusesope »
Grencola wrote: 21 Jul 2019, 22:35haha so what if I'm like 9 years off ;) we can take a single layer dv mp4 from dvdfab and just swap the audio with the lossless one from the disc, minus atmos? I feel like I would have known about this if it worked, as it's always the old ac3, e-ac3, ac4, aac, flac, alac etc..
Grencola wrote: 22 Jul 2019, 19:53 May I ask which program you used to put lossless audio into an mp4?? :D
Right now I'm using some random tools (as needed) from the GPAC SDK and the Bento4 SDK.
I'm playing with the atom structure of the mp4 files and I'm manipulating raw data with the help of a hex editor (like FlexHEX).
mp4muxer (from Dolby), DVDFab (latest trial version) and FFmpeg (latest version) close the circle.
These are experiments, there are no precise steps to follow.
Have you tried the files previously attached?
Do they work?
This is another test:
Dual Layer Dolby Vision (profile 7) + DTS-HD MA
https://pcdn-my.pcloud.com/publink/show ... IU8b1R8mrX
Generale
Nome completo                           : Test_DL_DV_DTS_HD_MA.mp4
Formato                                 : MPEG-4
Profilo formato                         : Base Media / Version 2
ID codec                                : mp42 (mp42/dby1/isom)
Dimensione                              : 112MiB
Durata                                  : 20s 62 ms
Modo bitrate generale                   : Variabile
Bitrate totale                          : 46,8 Mb/s
Data codifica                           : UTC 2019-07-23 12:49:34
Data                                    : UTC 2019-07-23 12:49:34
Video #1
Formato                                 : HEVC
Formato/Informazioni                    : High Efficiency Video Coding
Nome commereciale                       : HDR10
Profilo formato                         : Main [email protected]@High
ID codec                                : hev1
ID codec/Informazioni                   : High Efficiency Video Coding
Durata                                  : 20s 62 ms
Bitrate                                 : 35,0 Mb/s
Larghezza                               : 3.840 pixel
Altezza                                 : 2.160 pixel
Rapporto aspetto visualizzazione        : 16:9
Modalità frame rate                     : Costante
Frame rate                              : 23,976 (24000/1001) FPS
Spazio colore                           : YUV
Croma subsampling                       : 4:2:0 (Type 2)
Profondità bit                          : 10 bit
Bit/(pixel*frame)                       : 0.176
Dimensione della traccia                : 83,8MiB (75%)
Default                                 : No
Data codifica                           : UTC 2019-07-23 12:48:14
Data                                    : UTC 2019-07-23 12:49:35
colour_range                            : Limited
Colori primari                          : BT.2020
Caratteristiche trasferimento           : PQ
Coefficienti matrici                    : BT.2020 non-constant
MasteringDisplay_ColorPrimaries         : Display P3
MasteringDisplay_Luminance              : min: 0.0001 cd/m2, max: 4000 cd/m2
MaxCLL                                  : 3947 cd/m2
MaxFALL                                 : 542 cd/m2
Codec configuration box                 : hvcC
Video #2
Formato                                 : HEVC
Dolby Vision                            : 1.0, dvhe.07.06, EL+RPU
ID codec                                : dvhe
ID codec/Informazioni                   : High Efficiency Video Coding with Dolby Vision
Durata                                  : 20s 62 ms
Bitrate                                 : 6.205 kb/s
Larghezza                               : 1.920 pixel
Altezza                                 : 1.080 pixel
Spazio colore                           : YUV
Bit/(pixel*frame)                       : 0.125
Dimensione della traccia                : 14,8MiB (13%)
Default                                 : No
Codec configuration box                 : hvcC+dvcC
Audio
Formato                                 : DTS XLL
Formato/Informazioni                    : Digital Theater Systems
Nome commereciale                       : DTS-HD Master Audio
ID codec                                : mp4a-A9
Durata                                  : 19s 10 ms
Durata sorgente                         : 19s 595 ms
Modalità bitrate                        : Variabile
Bitrate                                 : 5.713 kb/s
Bitrate massimo                         : 6.547 kb/s
Canali                                  : 8 canali
Channel layout                          : C L R LFE Lb Rb Lss Rss
Frequenza campionamento                 : 48,0 kHz
Frame rate                              : 93,750 FPS (512 SPF)
Profondità bit                          : 24 bit
Modo compressione                       : Senza perdita
Dimensione della traccia                : 12,9MiB (12%)
Dim. flusso sorgente                    : 13,3MiB (12%)
Default                                 : No
AlternateGroup/String                   : 1
Let me know...
Re: Dolby Vision
yusesope wrote: 21 Jul 2019, 18:26 Today, I'm inspired so I have this for you (the video track and the audio track come from different sources):
Dolby Vision + DTS-HD MA
https://pcdn-my.pcloud.com/publink/show ... jXJbWbCAek
Generale
Nome completo                           : Test_DV_DTS_HD_MA.mp4
Formato                                 : MPEG-4
ID codec                                : isom (isom)
Dimensione                              : 122MiB
Durata                                  : 29s 737 ms
Bitrate totale                          : 34,3 Mb/s
Data codifica                           : UTC 2019-07-21 09:42:46
Data                                    : UTC 2019-07-21 09:42:46
Video
Formato                                 : HEVC
Dolby Vision                            : 1.0, dvhe.05.06, BL+RPU
ID codec                                : dvhe
Durata                                  : 29s 737 ms
Bitrate                                 : 28,7 Mb/s
Bitrate massimo                         : 102 Mb/s
Spazio colore                           : YUV
Bit/(pixel*frame)                       : 0.144
Dimensione della traccia                : 102MiB (84%)
Data codifica                           : UTC 2019-07-19 07:46:14
MaxCLL                                  : 3947 cd/m2
MaxFALL                                 : 542 cd/m2
Audio
Formato                                 : DTS XLL
ID codec                                : mp4a-A9
Durata                                  : 29s 737 ms
Bitrate                                 : 5.538 kb/s
Bitrate massimo                         : 7.330 kb/s
Canali                                  : 8 canali
Dimensione della traccia                : 19,8MiB (16%)
Default                                 : Si
Dolby Vision + DTS:X
https://pcdn-my.pcloud.com/publink/show ... LTnFU6HKty
Generale
Nome completo                           : Test_DV_DTS_X.mp4
Formato                                 : MPEG-4
Dimensione                              : 73,6MiB
Durata                                  : 11s 427 ms
Bitrate totale                          : 54,0 Mb/s
Data codifica                           : UTC 2019-07-21 09:54:07
Data                                    : UTC 2019-07-21 09:54:07
Video
Formato                                 : HEVC
ID codec                                : dvhe
Durata                                  : 11s 427 ms
Bitrate                                 : 47,3 Mb/s
Spazio colore                           : YUV
Bit/(pixel*frame)                       : 0.238
Dimensione della traccia                : 64,5MiB (88%)
MaxCLL                                  : 3947 cd/m2
MaxFALL                                 : 542 cd/m2
Audio
Formato                                 : DTS XLL X
ID codec                                : mp4a-A9
Durata                                  : 11s 422 ms
Bitrate                                 : 6.717 kb/s
Bitrate nominale                        : 6.090 kb/s
Bitrate massimo                         : 9.370 kb/s
Canali                                  : Object Based
Channel layout                          : Object Based
Dimensione della traccia                : 9,15MiB (12%)
Titolo                                  : Surround 7.1
Lingua                                  : Inglese
Default                                 : Si
Do They play fine?
Both play just fine, 8 channel audio too.
Grencola
Re: Dolby Vision
Post by Grencola »
yusesope wrote: 21 Jul 2019, 18:26 Do They play fine?
davilla wrote: 24 Jul 2019, 02:41 both play just fine, 8 channel audio too.
Holy sh*t davilla, it finally happened! Dolby Vision AND HD-Audio together without using a uhd-bd player! <3 MrMC 8-) does it trigger DTS-HD MA properly on your AVR or is it PCM?
yusesope, well done sir - you are my freakin' hero! how difficult would it be to streamline the process (perhaps a script that runs all those programs) of making one of your special mp4's from a disc? a full movie rip with lossless video and audio is soo close! :)
yusesope
Re: Dolby Vision
Post by yusesope »
Cool, thanks for your time.
Grencola wrote: 24 Jul 2019, 03:22yusesope, well done sir - you are my freakin' hero!
Just remember me when someone will copy my efforts and you will have to pay for all of this (...maybe, after three free trials...who knows).
Grencola wrote: 24 Jul 2019, 03:22 how difficult would it be to streamline the process?
It's easy (especially for the "Single Layer" one).
I saw your previous script.
You have the skills to prepare something.
You will do it for all of us (because, after the explenations, I'm out!).
If the Dual Layer file works, you'll have to edit some files at binary level ( Powershell is the way for that or you'll learn some basic stuff in Python)
But first I need to do more tests.
In Primis, did the Dual Layer file cause problems?
is it fine as it is?
(it is important because, in this case, there would be no need to buy any software)
In Secundis, the ALAC codec (instead of TrueHD/ATMOS) could be a problem.
Here are some test files with Linear PCM audio and Logarithmic PCM audio (a-law and μ-law algorithms)
Dolby Vision + LPCM
https://pcdn-my.pcloud.com/publink/show ... OSs8aJj2KX
Generale
Nome completo                           : Test_DV_LPCM.mp4
Formato                                 : MPEG-4
ID codec                                : mp42 (isom/mp42)
Dimensione                              : 124MiB
Durata                                  : 29s 737 ms
Bitrate totale                          : 34,9 Mb/s
Data codifica                           : UTC 2019-07-24 07:59:46
Data                                    : UTC 2019-07-24 07:59:46
Video
Formato                                 : HEVC
ID codec                                : dvhe
Durata                                  : 29s 737 ms
Bitrate                                 : 28,7 Mb/s
Bitrate massimo                         : 100 Mb/s
Spazio colore                           : YUV
Dimensione della traccia                : 102MiB (82%)
Data                                    : UTC 2019-07-24 07:59:47
MaxCLL                                  : 3947 cd/m2
MaxFALL                                 : 542 cd/m2
Audio
Formato                                 : PCM
Impostazioni formato                    : Little / Signed
ID codec                                : in24
Durata                                  : 20s 0 ms
Modalità bitrate                        : Costante
Bitrate                                 : 9.216 kb/s
Canali                                  : 8 canali
Channel layout                          : L R C LFE Ls R Rls Rb
Dimensione della traccia                : 22,0MiB (18%)
Default                                 : Si
Dolby Vision + a-law PCM
https://pcdn-my.pcloud.com/publink/show ... NF1BGOb9S7
Generale
Nome completo                           : Test_DV_ALAW.mp4
Formato                                 : MPEG-4
Dimensione                              : 109MiB
Durata                                  : 29s 737 ms
Bitrate totale                          : 30,7 Mb/s
Data codifica                           : UTC 2019-07-24 08:01:27
Data                                    : UTC 2019-07-24 08:01:27
Video
Formato                                 : HEVC
ID codec                                : dvhe
Durata                                  : 29s 737 ms
Bitrate                                 : 28,7 Mb/s
Spazio colore                           : YUV
Dimensione della traccia                : 102MiB (93%)
Data                                    : UTC 2019-07-24 08:01:28
MaxCLL                                  : 3947 cd/m2
MaxFALL                                 : 542 cd/m2
Audio
Formato                                 : ADPCM
Profilo formato                         : A-Law
ID codec                                : alaw
Durata                                  : 20s 0 ms
Bitrate                                 : 3.072 kb/s
Canali                                  : 8 canali
Channel layout                          : L R C LFE Ls Rs Lsd Rsd
Profondità bit                          : 16 bit
Dimensione della traccia                : 7,32MiB (7%)
Default                                 : Si
Dolby Vision + μ-law PCM
https://pcdn-my.pcloud.com/publink/show ... 7IQbNwAiP7
Generale
Nome completo                           : Test_DV_MULAW.mp4
Formato                                 : MPEG-4
Dimensione                              : 109MiB
Durata                                  : 29s 737 ms
Data codifica                           : UTC 2019-07-24 08:02:28
Data                                    : UTC 2019-07-24 08:02:28
Video
Formato                                 : HEVC
ID codec                                : dvhe
Durata                                  : 29s 737 ms
Bitrate                                 : 28,7 Mb/s
Spazio colore                           : YUV
Data                                    : UTC 2019-07-24 08:02:29
MaxCLL                                  : 3947 cd/m2
MaxFALL                                 : 542 cd/m2
Audio
Formato                                 : ADPCM
Profilo formato                         : U-Law
ID codec                                : ulaw
Durata                                  : 20s 0 ms
Canali                                  : 8 canali
Default                                 : Si
Let me know...
Grencola
Re: Dolby Vision
Post by Grencola »
yusesope wrote: 24 Jul 2019, 09:20
I will absolutely take the reigns on this one, I even know some Python! Hopefully I can make a simple solution for everyone. I'll PM you for a bit more info :)
yusesope
Re: Dolby Vision
Post by yusesope »
Grencola wrote: 24 Jul 2019, 23:05 I'll PM you for a bit more info :)
I cannot reply because "I'm not authorized to use this feature". Don't worry about the "hex stuff". Binary manipulation was useful for understanding how to concatenate the output of one program with the input of another. After that, I simplified the process: right now, a single sequence of bytes must be modified "on the fly".
The downside is that the whole process takes a long time: a file can be manipulated even up to three times (a SSD is usefull in this situation).
At the beginning, I suggest you experiment using 60 seconds cuts.
Before explaining everything, we wait for davilla to confirm the correct functioning of the "Dual Layer" file and PCM audio.
It would be useless to pass you incorrect information. It would only create confusion.
Re: Dolby Vision
Test_DV_ALAW.mp4 plays fine, 8 channels.
Test_DV_MULAW.mp4 also plays fine, 8 channels.
Test_DV_LPCM.mp4 plays but audio is just 8 channels of static noise.
Test_DL_DV_DTS_HD_MA.mp4 plays, can't say anything about the 2nd video stream as MrMC only handles one right now.
yusesope
Re: Dolby Vision
Post by yusesope »
yusesope wrote: 23 Jul 2019, 14:35 Dual Layer Dolby Vision (profile 7) + DTS-HD MA
davilla wrote: 26 Jul 2019, 00:05 Test_DL_DV_DTS_HD_MA.mp4 plays, can't say anything about the 2nd video stream as MrMC only handles one right now.
My bad! I should have read the previous posts! Sorry!
It is worth testing anyway (I appeal to the owners of LG, Vizio, Sony, etc...).
Volunteers?
davilla wrote: 26 Jul 2019, 00:05 Test_DV_LPCM.mp4 plays but audio is just 8 channels of static noise.
No, it's not static noise!
Listen carefully, it's Tim who is whispering:
shush!show respect!we're the shiny Apple!we're shrewd.should we care?shame on you.
shush!show reshct!we'sh the shiny shApple!we'sh shresh.should sh care?shame on shh.
shush!shah shshct!we'sh sh shshy sh Ashle!we'sh shshsh.shoshd sh cshe?shshe sh shh.
shshshshshhhshshshcshshshhhshshshshhshshshshshshshshshhshshdshshshshshshshh.
Hodor!...nay,APPLE!
Maybe, the little-endian order is not welcome.
You should try the "big" one:
Dolby Vision + LPCM (24bit big-endian)
https://pcdn-my.pcloud.com/publink/show ... 5KfjfgGwOX
Generale
Nome completo                           : Test_DV_LPMC_BigEnd.mp4
Formato                                 : MPEG-4
Dimensione                              : 130MiB
Durata                                  : 29s 737 ms
Bitrate totale                          : 36,7 Mb/s
Data codifica                           : UTC 2019-07-26 08:46:47
Data                                    : UTC 2019-07-26 08:46:47
Video
Formato                                 : HEVC
ID codec                                : dvhe
Durata                                  : 29s 737 ms
Bitrate                                 : 28,7 Mb/s
Spazio colore                           : YUV
Dimensione della traccia                : 102MiB (78%)
MaxCLL                                  : 3947 cd/m2
MaxFALL                                 : 542 cd/m2
Audio
Formato                                 : PCM
Impostazioni formato                    : Big / Signed
ID codec                                : in24
Durata                                  : 26s 0 ms
Canali                                  : 8 canali
Dimensione della traccia                : 28,6MiB (22%)
Default                                 : Si
while we're at it, this is a sample with FLAC audio:
Dolby Vision + FLAC
https://pcdn-my.pcloud.com/publink/show ... CXH0xzjmUk
Generale
Nome completo                           : Test_DV_FLAC.mp4
Formato                                 : MPEG-4
Dimensione                              : 111MiB
Durata                                  : 29s 737 ms
Bitrate totale                          : 31,3 Mb/s
Data codifica                           : UTC 2019-07-26 08:49:27
Data                                    : UTC 2019-07-26 08:49:27
Video
Formato                                 : HEVC
ID codec                                : dvhe
Durata                                  : 29s 737 ms
Bitrate                                 : 28,7 Mb/s
Spazio colore                           : YUV
Dimensione della traccia                : 102MiB (91%)
Data                                    : UTC 2019-07-26 08:49:28
MaxCLL                                  : 3947 cd/m2
MaxFALL                                 : 542 cd/m2
Audio
Formato                                 : fLaC
ID codec                                : fLaC
Durata                                  : 26s 413 ms
Bitrate                                 : 3.003 kb/s
Bitrate massimo                         : 3.739 kb/s
Canali                                  : 8 canali
Dimensione della traccia                : 9,46MiB (9%)
Titolo                                  : [email protected]
Data codifica                           : UTC 2019-07-26 08:49:28
As always, let me know...
Silergo
Re: Dolby Vision
Post by Silergo »
yusesope wrote: 26 Jul 2019, 09:34 Test_DV_LPCM
Dolby Vision + FLAC
All play, but no sound (but I guess it's TV, because it play only EAC3 with DV). Also tried to created own single-layer video with dvdfab, but it kills my TV: black screen after start and then TV turn off and don't turn on until plug it out/in from socket.
