Transcoding Surround speaker issue in 2.2.0
brians
Re: Transcoding Surround speaker issue in 2.2.0
Post by brians »
Seems to be fixed but now notice another version 160604.1257 this morning again so I will test again later.
afawaz
Post by afawaz »
I have bought mrmc and have the same issue !
how can I update to the last testflight ?
should I need to wait until the next appstore update ?
Thx for support.
afawaz wrote:Hi,
Thx for support.
send email to [email protected], include the email address connected to your apple id.
afawaz
Post by afawaz »
davilla wrote: send email to [email protected], include the email address connected to your apple id.
Done, Thx.
Just a little more question, do you know if this fix will be integrated to pre-alpha Kodi 17 ?
Done, Thx.
its up to kodi devs to pull as they please from our public repo
bigbonobo
Post by bigbonobo »
Hi.
I have an issue with the latest version on the Apple TV 4. I have the Apple TV set to best quality in settings and 5.1 speakers. In MrMc I have all the default audio settings but speakers set to 5.1. I'm hoping to get uncompressed multichannel audio from files with DTS-HD MA so to achieve this I have passthrough audio turned off. Unfortunately I'm getting dialogue through the left speaker rather than the centre. Is this a known problem? In other apps like Netflix I'm now getting Multichannel audio instead of DD (a result of changing to best quality in the ATV4 settings I assume) but the dialogue does come from the centre channel.
Seemed like there were issues in the past but they had been sorted?
bigbonobo wrote:Hi.
As far as we know, audio channel mapping is working as it should. As MrMC/tvOS is our daily viewer, my wife would kill me if dialog was not coming out of the center channel.
a debuglog might help us reproduce the issue.
bigbonobo
Post by bigbonobo »
http://pastebin.com/syjp2xLp
Log attached. Hopefully what you were asking for.
At the moment I have passthrough enabled but "DTS capable" turned off. This means for DD that works perfectly (passthrough) but for all DTS and DTS MA tracks I get the dialogue through the left speaker. I get the same result with passthrough turned off.
Just as an aside playing the DTS MA should give me much improved sound over having the DTS core being passed through instead?
Thanks!
bigbonobo
Post by bigbonobo »
So after a little more testing with some DTS HD and DD HD channel test files (with passthrough turned off) I get the same result for both DD HD and DTS HD in that the channels are as follows:
Left channel is correct
Centre Channel is right speaker.
Right channel is the Sub.
Right Surround and Right Rear are the Left Surround
Left Surround and Left Rear are the Centre Channel
I've run the same files through a raspberry pi with OSMC and the channels are correct with passthrough disabled and DTS MA decoding turned on.
The Channels are also correct when passthrough is tuned on in MrMc so I get the core DTS track instead.
Not sure there is much else I should check, I will try with a different amp but the raspberry pi test suggests this may be a MrMc issue for me?
bigbonobo
Post by bigbonobo »
So I tried the Apple TV on another amp and it worked perfectly... So it seems its an issue limited to my Amp which is a Onkyo HTX-22HDX. Very annoying.
