Problem accessing NAS after 3.0.4 update
bmiddaugh
Re: Problem accessing NAS after 3.0.4 update
Coolio. Sent.
added, there is already a 3.0.5 testflight series running, minimal changes from 3.0.4. You should get an email invite for it.
I'm building one with some smb related changed reverted. Build take 10-15 mins, push up take 30-45. Then it gets processed. Once that's done, we have to tag to external testing. So maybe 1-2 hours if I can stay away that long.
Also, sorry about the problems. Nothing showed up regarding this during 3.0.4 testflight series.
bmiddaugh
Just installed 3.05.
Doing the same thing.
I'll check the revert smb build in the morning.
EST here.
Thanks for the help.
EST here.
bmiddaugh
One thing I noticed in your debug log.
When it found my nas it had the correct ip.
Then when I tried to actually access it, it showed a completely different incorrect ip.
Not sure if that leads anywhere.
22:48:14 T:6140850176 DEBUG: DllLibDSM:ns_discover_on_entry_added name(CHATEAU-WOO-WOO), address(192.168.0.14)
22:48:17 T:6146011136 DEBUG: getaddrinfo: 'CHATEAU-WOO-WOO' -> '92.242.140.21'
Yea, saw that.bmiddaugh wrote: 27 May 2017, 04:09 One thing I noticed in your debug log.
bmiddaugh
I tried the latest build.
Same issues.
I then went back to previous builds, even all the way back to 3.03 and still the same problems.
Although nothing has changed on my network, I can't figure this one out.
Perhaps an iOS update somewhere although this all worked right up till the update.
Very strange.
Same issues.
Very strange.
bmiddaugh
davilla,
I'm still having the same issue.
I went ahead and bought the MRMC app for touch devices on iOS as an experiment and that, strangely enough, works perfectly with all the default SMB settings.
I think this is some kind of issue with tvOS.
Right now though, MRMC is unusable in my current environment.
Did you try "restore defaults" in smb client window?
Another thing would be to remove and reinstall MrMC but depending on your setup it might erase your library, watched/unwatchwd status and other user settings, files will of course be safe. If you are on MySQL database then all you would need to do is set that up to get it back.
jabohn
FYI - this is exactly what I had reported as well. For me, it started immediately after installing the new test flight though, not the public release.bmiddaugh wrote: 27 May 2017, 03:47 After waiting about 4 minutes, it has returned a login authorization failed with error code 6 error.
With libdsm on.
jabohn wrote: 27 May 2017, 17:18 My shares stopped working after updating to this beta. Using libdsm, connecting to macOS Sierra 10.12.6 beta
I click on the share and it says "working" for a bit and then it pops up the password box. I put the password in but it just repeats the cycle. Everything worked fine last night when I was still running MrMC 3.0.4
