Testing MrMC 3.5.1
RewNex
Re: Testing MrMC 3.5.1
New to TestFlight, I feel even dumber but is the latest build that adds python supposed to look like the recent "teaser" image @davilla posted some days back?
https://mrmc.tv/forum/viewtopic.php?f=1 ... 110#p15874RewNex wrote: 18 Mar 2018, 02:26 New to TestFlight, I feel even dumber but is the latest build that adds python supposed to look like the recent "teaser" image @davilla posted some days back?
This post has all the info you need.
- Montoya
An Emby addon in MrMC would be very very appreciateddavilla wrote: 17 Mar 2018, 13:41 Emby addon is under internal discussion, we might release without it initially but add it later.
So looking forward to that, after the Plex addon is fine tuned and released in stable MrMC version, if you guys have made up your mind about an Emby addon in MrMC
To me, Emby development is much further than Plex, concerning Live TV, ease of use to set up/maintain and to customize. Only their Apple TV client sucks concerning format support when you mostly have embedded subs in content (Emby server always has to transcode content with embedded subs, for their Apple TV client....) and that's why I use MrMC
RewNex
Thank you.cosmoxl wrote: 18 Mar 2018, 02:32https://mrmc.tv/forum/viewtopic.php?f=1 ... 110#p15874RewNex wrote: 18 Mar 2018, 02:26 New to TestFlight, I feel even dumber but is the latest build that adds python supposed to look like the recent "teaser" image @davilla posted some days back?
This post has all the info you need.![]()
I was using MrMC skin which didn't have that setting only when I change to Opacity I could enable Plex.
- Montoya
Since I have been using MrMC (since release of Apple TV 4K) and in Testflight since then, I always have problems using different profiles. The master profile is the one where I have my Live TV from the DVBLink PVR and my local movie library (metadata managed by Emby server). Next to that, I have separate MrMC profiles for my strm movie libraries (also metadata managed by Emby server), with online VOD content from my iptv providers.davilla wrote: 18 Mar 2018, 01:35 Reminder to those in Testflight, we really depend on your input to gauge the overall stability of MrMC. So please make the effort to report all issues and even post if MrMC is working well for you. Please also give a little description of how you are using MrMC, it helps us as there are many, many pathways and ways to use MrMC. Thanks![]()
Loading the master profile always works, but when I have used the master profile and want to load another profile, MrMc always crashes to the ATV Home screen. Loading another profile than only works when I have restarted the Apple TV. So far I haven't found the cause of this. Seems that making new profiles isn't completely bug free.
If you can guide me what to check and what to provide, than I will test this to solve this issue, because this profile problem is present, since I have been starting to use MrMC. And if it is easier to follow up on this subject, I can make a separate topic of this, in a forum section you describe.
RewNex
Had a quick spin with Plex for Kodi.
1. Search: Standing on the search field and enter, go's to the apple search screen writing a movie name don't return back to the search field of Plex for Kodi.
2. While playback: go to settings choose Kodi video or audio settings crashes the app back to home screen.
Hope the team can improve the scrubbing, make it look and field as good as non-Plex for Kodi using the MrMC skin.
Seems a bit laggy moving around the artwork/content but so far very happy.
SUPERBIF
I've also asked for this earlier. It would be excellent if you could save the subtitle with the correct name and in the same folder ad the video. Hopefully now the Direct Plex is available it perhaps can be possible. It works in Kodi when you use PlexKodiConnect (Plex addon). It would make things much easier.cosmoxl wrote: 17 Mar 2018, 22:45davilla wrote: 17 Mar 2018, 04:57 Enable it (subtitle download) in plex settings. Then the button (OSD, far right) will be enabled.
Still tweaking things, kodi refs will get rebranded, never fear![]()
OK, when searching for subtitles to download can you code things such that the actual file name is shown so we can better match the subtitle to the file? When using MrMC directly this is the behavior. When in Plex add-on only a generic name of file.mkv or file.mp4 is shown above the subtitle search GUI.
Then, Is there a way to force the plex add-on to see the subtitle that's downloaded? Once it's downloaded and playing it still isn't shown as a possible subtitle by plex. But, it is listed by "kodi" audio settings.![]()
its a bit difficult, all direct play files are called file.mkv so we would need to come up with a different way of matching the names... I will look into is at some point after all the python mess is doneSUPERBIF wrote: 18 Mar 2018, 06:55 ...
- zeroq26
With MrMc that includes python now Does this mean we can install kodi add-ons
nope, and it never willzeroq26 wrote: 18 Mar 2018, 09:31 With MrMc that includes python now Does this mean we can install kodi add-ons
