Testing MrMC 3.5.1
x64Man
Re: Testing MrMC 3.5.1
Post by x64Man »
"We are pushing hard to get this out."
Nice, looking forward to the release, it is great to see other app developers giving us Plex integration. Thanks.
Itzme1234
Post by Itzme1234 »
I feel dumb for having to ask but I can’t find where to set the Plex Open at Start.
Itzme1234
Post by Itzme1234 »
"Plex’s Rotten Tomato review snippets and TV theme songs?", later :)
Top
When I was growing up and asked my mother for something, she often replied, “We’ll see”. That was code for “no”. Took me awhile to learn that. So when you say “later” I’m skeptical ;)
Itzme1234
Post by Itzme1234 »
Movie detail page, the 3 dot icon, Go to Movies. It sends me to a highlighted Movie icon on the main page, but I’m oddly locked into having to pree the button, I can’t navigate away from that button. If I do press it send me back to the Movie detail page. Somethings not as intended with all that.
Everbrave
Post by Everbrave »
Itzme1234 wrote: 17 Mar 2018, 15:28 I feel dumb for having to ask but I can’t find where to set the Plex Open at Start.
in the pull-down menu under your login name you will find Settings.
Itzme1234
Post by Itzme1234 »
Thank you. I didn’t know that settings menu was there. I checked Advanced>Start Plex on Kodi Startup. Then when I exited and re-entered I believe it went right into Plex ( as expected). But now as I test more it hangs in my opacity main menu, with Plex highlighted.
When I manually proceed from there it moves through programs, Plex and finally onto the Plex main screen.
A force close of MrMc fixes everything, but only for the first entry, then I have to force close again to achieve a Plex startup on entry
yes/no/maybe ?
Itzme1234
Post by Itzme1234 »
davilla wrote: 17 Mar 2018, 19:47yes/no/maybe ?
Mom? :o
Post by cosmoxl »
davilla wrote: 17 Mar 2018, 04:57 Enable it (subtitle download) in plex settings. Then the button (OSD, far right) will be enabled.
Still tweaking things, kodi refs will get rebranded, never fear :)
OK, when searching for subtitles to download can you code things such that the actual file name is shown so we can better match the subtitle to the file? When using MrMC directly this is the behavior. When in Plex add-on only a generic name of file.mkv or file.mp4 is shown above the subtitle search GUI.
Then, Is there a way to force the plex add-on to see the subtitle that's downloaded? Once it's downloaded and playing it still isn't shown as a possible subtitle by plex. But, it is listed by "kodi" audio settings. :)
Reminder to those in Testflight, we really depend on your input to gauge the overall stability of MrMC. So please make the effort to report all issues and even post if MrMC is working well for you. Please also give a little description of how you are using MrMC, it helps us as there are many, many pathways and ways to use MrMC. Thanks :)
