The setting doesn't seem to work on my Plex library after enabling it.
I tried testing it in SPMC with a regular SMB share and it works fine, but since this is for a MrMc/Fire Stick setup I'd rather just use the Plex client so metadata and artwork is stored on my server.
Does Refresh Rate Switching work with the Plex client?
BaconBits
Re: Does Refresh Rate Switching work with the Plex client?
that your media is accessed via plex has nothing to do with refresh rate switching working or not.BaconBits wrote:The setting doesn't seem to work on my Plex library after enabling it.
the developers will have to tell you whether or not the Fire Stick supports switching. If it does and it's not working you might check your display settings in the Fire Stick settings. Resolution has to be set to auto.
BaconBits
It's the new Fire TV stick, but refresh switching works fine with it in SPMC so I assume it would in MrMc too.
badsimian
This is happening with me, I just got my FireTV and installed MrMC, seemed like the ideal solution however my refresh rate is not switching when using it as a Plex client either.
Logs captured here:-
http://pastebin.com/4eSEtauG
http://pastebin.com/v4eVFNSP
09:31:14 T:18446744072291174408 NOTICE: Found resolution 1280 x 720 for display 0 with 1280 x 720 @ 50.000000 Hzbadsimian wrote:This is happening with me, I just got my FireTV and installed MrMC, seemed like the ideal solution however my refresh rate is not switching when using it as a Plex client either.
09:31:14 T:18446744072291174408 NOTICE: Found resolution 1280 x 720 for display 0 with 1280 x 720 @ 60.000000 Hz
09:31:14 T:18446744072291174408 NOTICE: Found resolution 1920 x 1080 for display 0 with 1920 x 1080 @ 50.000000 Hz
09:31:14 T:18446744072291174408 NOTICE: Found resolution 1920 x 1080 for display 0 with 1920 x 1080 @ 60.000000 Hz
Those resolutions and rates are what MrMC found. Your video is 23.976. No match so no switch.
In contrast, this is my Samsung
09:57:05 T:18446744072287948464 NOTICE: Found resolution 1280 x 720 for display 0 with 1280 x 720 @ 50.000000 Hz
09:57:05 T:18446744072287948464 NOTICE: Found resolution 1280 x 720 for display 0 with 1280 x 720 @ 60.000000 Hz
09:57:05 T:18446744072287948464 NOTICE: Found resolution 1920 x 1080 for display 0 with 1920 x 1080 @ 24.000000 Hz
09:57:05 T:18446744072287948464 NOTICE: Found resolution 1920 x 1080 for display 0 with 1920 x 1080 @ 30.000000 Hz
09:57:05 T:18446744072287948464 NOTICE: Found resolution 1920 x 1080 for display 0 with 1920 x 1080 @ 50.000000 Hz
09:57:05 T:18446744072287948464 NOTICE: Found resolution 1920 x 1080 for display 0 with 1920 x 1080 @ 60.000000 Hz
09:57:05 T:18446744072287948464 NOTICE: Found resolution 3840 x 2160 for display 0 with 3840 x 2160 @ 24.000000 Hz
09:57:05 T:18446744072287948464 NOTICE: Found resolution 3840 x 2160 for display 0 with 3840 x 2160 @ 25.000000 Hz
09:57:05 T:18446744072287948464 NOTICE: Found resolution 3840 x 2160 for display 0 with 3840 x 2160 @ 30.000000 Hz
badsimian
So what does this mean then? my TV definitely does do 24p normally, if I run Kodi through a Raspberry Pi for instance it works as does playing a PS4.
badsimian
Okay apologies - my fault. I thought my FireTV had updated itself when I first installed it, turns out it was waiting for a "quiet moment" and was quite out of date. Now I have updated it, it is all switching just fine now.
