Multiple profile mySQL Database connection fails
logan_x50
Re: Multiple profile mySQL Database connection fails
Post by logan_x50 » 10 Oct 2016, 09:22
log file here
pastebin
Steps:-
enabled debug. exit mrmc
launch mrmc
profile 1 loaded aok
logoff profile 1
logon second profile
library not loaded ok
log-off 2nd profile
log-on profile 1
toggle mysql client enable off/on
library for profile loaded ok
Post by amet » 10 Oct 2016, 09:43
Can You look in profiles/kids and see if there is guisettings file in there? If so, what's in it... maybe hide the passwords and send it to me to support@mrmc.tv
I'll try to reproduce on android later today, iOS , tvOS and OSX works fine here
logan_x50
Post by logan_x50 » 10 Oct 2016, 12:16
Hi Amet,
i emailed the guisettings.xml over to you. thanks again
Post by amet » 10 Oct 2016, 13:06
got it, cheers... will check later.
thanks,
Post by amet » 19 Oct 2016, 15:36
are you being impatient @logan_x50 ? :) :)
firetv version is still in processing with Amazon.
