Sorry if I'm opening the topic which is already exist.
I am trying to setup MrMC to play my m3u file. I have enabled PVR IPTV Simple Client and add M3U Play List URL which is link of the m3u as public file in my dropbox. Once I configure this I restart the app and get bellow message.
https://www.dropbox.com/s/wys38zfq893cs ... r.jpg?dl=0
Also on my home screen of MrMC I am unable to get TV section. I am able to run TV because I set up to run TV on startup.
What could be the problem.
Best Regards,
Zec Voislav
No PVR clients have been started yet.
Re: No PVR clients have been started yet.
We need to see the debuglog, http://mrmc.tv/forum/viewtopic.php?f=12&t=373
Please make sure you reproduce the issue before you capture the log
voislav
Thank you for your reply.
I did small test to check if my m3u list is working.
I have install kodi on my laptop and did the same procedure like I did on my apple TV with MrMC. I ended up with same problem. No channel was loaded.
Now I assuming that the m3u list, which I got from my IPTV provider, is faulty.
The strange thing is that this m3u list is working fine with VLC player.
Do you maybe know how can I check if the format of the m3u is proper?
Best Regards,
Zec Voislav
Best Regards,
Zec Voislav
jesus_bs
The link you use to your m3u file must redirect to a raw text file (m3u file)...
I'm not sure you can do this with dropbox...
For instance, You can use pastebin, paste just a few channels (for testing pourpuses) from your m3u playlist. Create the paste, and select the option "RAW". You'll be redirected to a page with only your paste in raw text. in the browser link you'll see a link something similar to this http://pastebin.com/raw/TSQbsf
Copy the link of your paste in the IPTV simple client, and it should work...
Hope it works for you...
Jesus
Jesus
fdzaebel
Hi all,
I have exactly the same problem with a M3U8 list for my Kathrein IPTV Server. I created the list using EyeTV. The list works great with EyeTV and VLC.
Strange: With MrMC the list works sometimes and then zapping around is no problem. But in most cases after MrMC start I got the error from above and the whole app freezes.
Any idea how I could help to solve this problem?
Thanks,
Frank
Thanks,
Frank
would need to see mrmc.log with debug enabled, email to [email protected]. Note v2.4 has an error that disabled all pvr. v2.4.1 is wait apple review.fdzaebel wrote:Hi all,
Thanks,
Frank
fdzaebel
How can I create this log on AppleTV?
Thanks.
Thanks.
nicolaeff
Topic UP
Same issue, I can`t start any of pvr addons. It configured absolutely correct, with 100% working playlist.
Please let us have debuglog so we can see the issue
