Clean Library Progress Bar Topic is solved
In Kodi when you clean your library there is a progress bar to show you how much time is left, when I use the "clean library" function nothing happens it's like it's a dead button.
Re: Clean Library Progress Bar
Same applies for MrMC. AFAIR, there is a setting that needs to be activated to show the clean-up progress within MrMC. Can't remember exactly where this setting is hid. Make sure you activate "Expert" mode for settings when searching for it.
If the library is up to date, you can push the button a billion times. It won't show any progress anyway.
