External Audio File Support
MajorT
Post by MajorT »
So I have a file with built in French audio and I do not want to modify the original.
I obtained a dubbed soundtrack and in Kodi 18.9 I can add it to the directory in the following format.
Show.mkv
Show_eng,mka
When I play this file in Kodi, it will give me the option to switch to the external audio file, but in MrMC I do not get this option.
Does MrMC support this and I am not setting up the files correctly? If this is unsupported can it be added into the next release?
