Testing MrMC 3.9.12 - Apple TV
Re: Testing MrMC 3.9.12 - Apple TV
great, thanks for letting us know!
- Waltman
The fresh install of MrMC 3.9.12 (210514.621) is working perfect with what it should do: playing, pausing, sync, nfs And all mrmc
But it just lost log uploading function again. E-mail send to amet with the log details inside. (No old log because it was still fresh and active) But it’s still the same error.
- Just a observation I lost contact with the webserver when getting the log on my computer, I had to move to a button on main to get acces again.
- Also I clicked on upload log a few times before this one refused. Is there a buffer that is full ?
12:27:33.413 T:6107738112 ERROR: CCurlFile::FillBuffer - Failed: HTTP returned error 413
12:27:33.414 T:6107738112 ERROR: UploadLogs: Failed to upload log - O2PHQ.log to http://log.mrmc.tv
SETTOP-BOX :Apple TV 4K
Skin: Ariana
Database: MySQL
NAS: Synolgy DS1513+
TV: LG55OLEDC8
Skin: Ariana
Database: MySQL
TV: LG55OLEDC8
Not fixed for me. I was on the same version when the problem happened to me (above) and I reported here.Waltman wrote: ↑15 May 2021, 09:15all nfs issues / playback / sync / chrash issues are fixed on MrMC 3.9.12 (210514.621).jabohn wrote: ↑15 May 2021, 03:05This is still not fixed. It just happened to me again. I couldn't upload the log. It just says "log not uploaded" no matter what I do.
This time it was a bit different. It appeared to happen just as I was starting a new video. A split second into the video and it froze. I used the remote to go back which took a few seconds to respond. From then on, clicking on any media would result in nothing happening. Going to the share to browse manually then resulted in the authentication error. Quit and restart and it's back to normal.
Only the log not uploaded is now a random issue on my main system. I just reinstalled this TestFlight version fresh on my main system so figure out why the log upload issue is present here but not on my second system.
I will report back tomorrow after some more testing.
- Waltman
[/quote]
[/quote]
The log file size seems to be limited, server has a limit of 100MB per file upload, if you disable component logging and/or video logging it should be below 100MB…
amet is looking at why this has changed with the hosting provider.
[/quote]
Skin: Ariana
Database: MySQL
TV: LG55OLEDC8
Skin: Ariana
Database: MySQL
TV: LG55OLEDC8
- Waltman
Log file is not fixed for me either. It’s now randomly working, but some progress:
Amet discovered The log file size seems to be limited, server has a limit of 100MB per file upload, if you disable component logging and/or video logging it should be below 100MB…
[/quote]
[/quote]
Skin: Ariana
Database: MySQL
TV: LG55OLEDC8
Skin: Ariana
Database: MySQL
TV: LG55OLEDC8
- Waltman
Waltman wrote: ↑17 May 2021, 06:27 Log file is not fixed for me either. It’s now randomly working, but some progress:
Investigation on why this has changed with the hosting provider is underway.
Skin: Ariana
Database: MySQL
TV: LG55OLEDC8
Skin: Ariana
Database: MySQL
TV: LG55OLEDC8
- Waltman
Skin: Ariana
Database: MySQL
TV: LG55OLEDC8
Skin: Ariana
Database: MySQL
TV: LG55OLEDC8
I was talking about the sharing issues.Waltman wrote: ↑17 May 2021, 06:25
- Waltman
Ah sorry I misunderstood.jabohn wrote: ↑17 May 2021, 16:29I was talking about the sharing issues.Waltman wrote: ↑17 May 2021, 06:25
Are you using MrMC 3.9.12 (210514.621) ?
And are you using a MySQL on a (synology) NAS. I had some user rights issues that I needed to adjust manually on my synology NAS.
See also
https://mrmc.tv/forum/viewtopic.php?f=15&t=5675
Does that help you ?
Skin: Ariana
Database: MySQL
TV: LG55OLEDC8
Skin: Ariana
Database: MySQL
TV: LG55OLEDC8
Yes I'm on .621 and no, none of that other stuff applies to me. It's just MySQL on my Mac. It's fine for the longest time, and randomly just stops. Quitting and restarting MrMC fixes it for the time being.Waltman wrote: ↑17 May 2021, 17:41 Ah sorry I misunderstood.
See also
