Movies and shows marked as watched multiple times
Any issues relating to https://trakt.tv service
Dieseldk
Post by Dieseldk »
Hey
Got my trakt account locked, and contacted support, got the answer I have inserted below.
I’m not totally sure the problem is with mrmc I sync with a couple of other apps to trakt, I don’t have a log from mrmc.
I do see movies and shows marked as watched multiple times 30-90, at the time and date, when I log in to the webpage.
I know it’s not much info to work with, maybe others have seen the same problem?
But I just wanted to pass on the info.
Answer from trakt:
Hey Dieseldk,
It looks like MrMC Media Center stuffed your account with 318,722 play history items. Your play history has been deduplicated to the best of our ability, and your API access has been unlocked.
Before using Trakt's API again, make sure to find a fix from this third party applications developer, or disable it entirely.
Re: Movies and shows marked as watched multiple times
Thats a lot of duplicates, do you have it set to upload play history on library update? I can’t see how this would happen , lets see if anyone else has any similar issues
Dieseldk
Post by Dieseldk »
Yes it’s set to push watched status after library scan.
I see the number of watch/plays of some movies has gone from around 90 to close to 200 since my post, and I haven’t been using mrmc since.
So I think it’s a problem with som other app and not mrmc.
debuglog might have some info on it... I see no issues here and i have the same setup
Dieseldk
Post by Dieseldk »
Can't get mrmc to upload debuglog and the log is to big for pastbin :-)
Can I send a dropbox link or something just to keep it a little private :-)
i can see som thing change in the log at first sync, it says added movies 0 and #for plays 1-2
CTraktServices::ServerChat - response {"added":{"movies":0,"episodes":0},"not_f
Later it says added movies 355, a lot of times
CTraktServices::ServerChat - response {"added":{"movies":355,"episodes":0},"not_f
20:21:47.095 T:6163853312 DEBUG: Getting Directory (special://profile/playlists/video)
20:21:47.099 T:6163853312 DEBUG: Getting Directory (special://profile/playlists/mixed)
20:21:47.100 T:6163853312 DEBUG: CMultiPathDirectory::MergeItems, items = 1
20:21:47.101 T:6163853312 DEBUG: CMultiPathDirectory::MergeItems, items = 1, took 0 ms
20:21:47.102 T:6163853312 DEBUG: CGUIWindowHome::SetupStaticHomeButtons()
20:21:47.295 T:6167867392 DEBUG: CurlFile::Open(0x16fa21b00) https://api.trakt.tv/sync/watched/movies
20:21:47.295 T:6167867392 INFO: easy_aquire - Created session to https://api.trakt.tv
20:21:47.536 T:6163853312 DEBUG: ------ Window Deinit (DialogExtendedProgressBar.xml) ------
20:21:49.886 T:6167867392 DEBUG: CTraktServices::GetTraktCVariant https://api.trakt.tv/sync/watched/movie ... ormat=json
20:21:49.888 T:6167867392 DEBUG: CTraktServices::GetTraktCVariant - response [{"plays":2,"last_watched_at":"2020-12-07T21:01:27.000Z","last_updated_at":"2020-12-07T21:01:26.000Z","movie":{"title":"Blade","year":1998,"ids":{"trakt":23293,"slug":"blade-1998","imdb":"tt0120611","tmdb":36647}}},{"plays":1,"last_watched_at":"2018-03-26T17:43:28.000Z","last_updated_at":"2018-03-26T17:43:28.000Z","movie":{"title":"Star Wars","year":1977,"ids":{"trakt":7,"slug":"star-wars-1977","imdb":"tt0076759","tmdb":11}}},{"plays":1,"last_watched_at":"2018-03-26T18:04:48.000Z","last_updated_at":"2018-03-26T18:04:48.000Z","movie":
"number":12,"plays":1,"last_watched_at":"2011-11-30T05:00:00.000Z"},{"number":13,"plays":1,"last_watched_at":"2011-11-30T05:00:00.000Z"}]}]}]
20:21:53.137 T:6167867392 DEBUG: CurlFile::Open(0x16fa21b20) https://api.trakt.tv/sync/history
20:21:53.427 T:6167867392 DEBUG: CTraktServices::ServerChat https://api.trakt.tv/sync/history
20:21:53.427 T:6167867392 DEBUG: CTraktServices::ServerChat - response {"added":{"movies":0,"episodes":0},"not_found":{"movies":[],"shows":[],"seasons":[],"episodes":[{"seasons":[{"episodes":[{"number":42,"watched_at":"2020-10-01T19:14:05Z"}],"number":0}]}],"people":[]}}
20:21:53.428 T:6167867392 DEBUG: CTraktServices::PushWatchedStatus() - Done
20:22:17.211 T:6163853312 DEBUG: found key /userdata/addon_data/metadata.tvdb.com/settings.xml
20:22:17.336 T:6163853312 DEBUG: ------ Window Init (DialogVideoInfo.xml) ------
20:22:17.336 T:6163853312 INFO: Loading skin file: DialogVideoInfo.xml, load type: KEEP_IN_MEMORY
20:22:19.334 T:6163853312 DEBUG: ------ Window Deinit (DialogVideoInfo.xml) ------
22:18:16.454 T:6159265792 DEBUG: found key /userdata/addon_data/metadata.themoviedb.org/settings.xml
22:18:16.463 T:6159265792 DEBUG: VideoInfoScanner: Skipping dir 'smb://NAS/4K Film/The Bourne Identity/' due to no change (fasthash)
22:18:16.474 T:6165000192 INFO: CActiveAESink::OpenSink - initialize sink
22:18:16.474 T:6165000192 DEBUG: CActiveAESink::OpenSink - trying to open device DARWINIOS:default
22:18:16.475 T:6159265792 DEBUG: found key /userdata/addon_data/metadata.themoviedb.org/settings.xml
22:18:16.476 T:6165000192 ERROR: CActiveAESink::StateMachine - OpenSink failed: 1
22:18:16.476 T:6164426752 ERROR: ActiveAE::InitSink - returned error
22:18:16.483 T:6159265792 DEBUG: VideoInfoScanner: Skipping dir 'smb://NAS/4K Film/The Bourne Legacy/' due to no change (fasthash)
22:18:16.496 T:6159265792 DEBUG: found key /userdata/addon_data/metadata.themoviedb.org/settings.xml
22:18:16.497 T:6162706432 DEBUG: CTraktServices::ServerChat https://api.trakt.tv/sync/history
22:18:16.497 T:6162706432 DEBUG: CTraktServices::ServerChat - response {"added":{"movies":355,"episodes":0},"not_found":{"movies":[],"shows":[],"seasons":[],"episodes":[{"seasons":[{"episodes":[{"number":42,"watched_at":"2020-10-01T19:14:05Z"}],"number":0}]}],"people":[]}}
22:18:16.498 T:6162706432 DEBUG: CTraktServices::PushWatchedStatus() - Done
22:18:16.505 T:6159265792 DEBUG: VideoInfoScanner: Skipping dir 'smb://NAS/4K Film/The Bourne Supremacy/' due to no change (fasthash)
22:18:16.514 T:6159265792 DEBUG: found key /userdata/addon_data/metadata.themoviedb.org/settings.xml
22:18:16.522 T:6159265792 DEBUG: VideoInfoScanner: Skipping dir 'smb://NAS/4K Film/The Bourne Ultimatum/' due to no change (fasthash)
22:48:33.216 T:6161559552 DEBUG: VideoInfoScanner: Scanning dir 'smb://NAS/4K Film/' as not in the database
22:48:33.223 T:6161559552 DEBUG: found key /userdata/addon_data/metadata.themoviedb.org/settings.xml
22:48:33.251 T:6165000192 DEBUG: Previous line repeats 2 times.
22:48:33.251 T:6165000192 INFO: CActiveAESink::OpenSink - initialize sink
22:48:33.252 T:6165000192 DEBUG: CActiveAESink::OpenSink - trying to open device DARWINIOS:default
22:48:33.254 T:6165000192 ERROR: CActiveAESink::StateMachine - OpenSink failed: 1
22:48:33.254 T:6164426752 ERROR: ActiveAE::InitSink - returned error
22:48:33.260 T:6161559552 DEBUG: found key /userdata/addon_data/metadata.themoviedb.org/settings.xml
22:48:33.830 T:6165000192 DEBUG: Previous line repeats 73 times.
22:48:33.831 T:6165000192 INFO: CActiveAESink::OpenSink - initialize sink
22:48:33.831 T:6165000192 DEBUG: CActiveAESink::OpenSink - trying to open device DARWINIOS:default
22:48:33.833 T:6165000192 ERROR: CActiveAESink::StateMachine - OpenSink failed: 1
22:48:33.833 T:6164426752 ERROR: ActiveAE::InitSink - returned error
22:48:33.840 T:6161559552 DEBUG: found key /userdata/addon_data/metadata.themoviedb.org/settings.xml
22:48:33.850 T:6159265792 DEBUG: CTraktServices::ServerChat https://api.trakt.tv/sync/history
22:48:33.850 T:6159265792 DEBUG: CTraktServices::ServerChat - response {"added":{"movies":355,"episodes":0},"not_found":{"movies":[],"shows":[],"seasons":[],"episodes":[{"seasons":[{"episodes":[{"number":42,"watched_at":"2020-10-01T19:14:05Z"}],"number":0}]}],"people":[]}}
22:48:33.850 T:6159265792 DEBUG: CTraktServices::PushWatchedStatus() - Done
22:48:33.851 T:6161559552 DEBUG: found key /userdata/addon_data/metadata.themoviedb.org/settings.xml
22:48:34.139 T:6161559552 DEBUG: Previous line repeats 37 times.
22:48:34.139 T:6161559552 DEBUG: VideoInfoScanner: No (new) information was found in dir smb://NAS/4K Film/
22:48:34.142 T:6161559552 DEBUG: found key /userdata/addon_data/metadata.themoviedb.org/settings.xml
22:48:34.150 T:6161559552 DEBUG: VideoInfoScanner: Scanning dir 'smb://NAS/4K Film/@Recycle/' as not in the database
