I noticed some problems with tone mapping on 4K MKVs I have on my share. It’s only happening sometimes and not with all so I guess that this is codec related.
Colors looking washed out and picture is to bright.
When I play the same file in Infuse 6, colors do look great. But I rather would like to use MrMC instead!
I created a debug log. F6MVO.log
Settings are all default.
Thanks and regards
Christian
Tone Mapping not correct on some files
Re: Tone Mapping not correct on some files
sorry, my bad. Correct Logfile name is F6MVO.log
Also please find media infos attached of 2 files I have problems with.
As said, both are playing fine in fusion 6 pro on the same device!
If you need examples for testing, please let me know!
General
Unique ID : 99918156101413303991536935613328644458 (0x4B2B89711F7018AE1ECAA9EF3431D96A)
Complete name : /Volumes/share/Filme/Mad_Max_Fury_Road.mkv
Format : Matroska
File size : 7.04 GiB
Duration : 2 h 0 min
Overall bit rate : 8 373 kb/s
Encoded date : UTC 2017-09-22T23:51:40Z
Writing application : HandBrake 1.0.7 2017040900
Writing library : Lavf57.7.2
Video
Format : HEVC
Format profile : Main@L5@Main
Codec ID : V_MPEGH/ISO/HEVC
Bit rate : 7 695 kb/s
Width : 3 840 pixels
Height : 1 600 pixels
Display aspect ratio : 2.40:1
Frame rate mode : Constant
Color space : YUV
Chroma subsampling : 4:2:0
Bit depth : 8 bits
Bits/(Pixel*Frame) : 0.052
Stream size : 6.47 GiB (92%)
Writing library : x265 2.1:[Windows][GCC 5.3.1][64 bit] 8bit
Encoding settings : wpp / ctu=64 / min-cu-size=8 / max-tu-size=32 / tu-intra-depth=1 / tu-inter-depth=1 / me=1 / subme=2 / merange=57 / no-rect / no-amp / max-merge=2 / temporal-mvp / no-early-skip / rskip / rdpenalty=0 / no-tskip / no-tskip-fast / strong-intra-smoothing / no-lossless / no-cu-lossless / no-constrained-intra / no-fast-intra / open-gop / no-temporal-layers / interlace=0 / keyint=240 / min-keyint=24 / scenecut=40 / rc-lookahead=20 / lookahead-slices=8 / bframes=4 / bframe-bias=0 / b-adapt=2 / ref=3 / limit-refs=3 / no-limit-modes / weightp / no-weightb / aq-mode=1 / qg-size=32 / aq-strength=1.00 / cbqpoffs=0 / crqpoffs=0 / rd=3 / psy-rd=2.00 / rdoq-level=0 / psy-rdoq=0.00 / log2-max-poc-lsb=8 / no-rd-refine / signhide / deblock=0:0 / sao / no-sao-non-deblock / b-pyramid / cutree / no-intra-refresh / rc=abr / bitrate=8000 / qcomp=0.60 / qpmin=0 / qpmax=69 / qpstep=4 / ipratio=1.40 / pbratio=1.30
Default : Yes
Forced : No
Color range : Limited
Color primaries : BT.2020
Transfer characteristics : PQ
Matrix coefficients : BT.2020 non-constant
Audio
Format : AC-3
Format/Info : Audio Coding 3
Codec ID : A_AC3
Bit rate mode : Constant
Bit rate : 512 kb/s
Channel(s) : 6 channels
Channel positions : Front: L C R, Side: L R, LFE
Sampling rate : 48.0 kHz
Frame rate : 31.250 FPS (1536 SPF)
Bit depth : 16 bits
Compression mode : Lossy
Delay relative to video : 1 ms
Stream size : 441 MiB (6%)
Title : Surround
Language : German
Service kind : Complete Main
Default : Yes
Forced : No
General
Unique ID : 87474527414781131519375548044489192879 (0x41CEFB2E155144CB067E810F507AF5AF)
Complete name : /Volumes/share/Filme/Teenage_Mutant_Ninja_Turtles_Out_of_the_Shadows.mkv
Format : Matroska
File size : 6.22 GiB
Duration : 1 h 52 min
Overall bit rate : 7 938 kb/s
Encoded date : UTC 2017-05-25T16:36:32Z
Video
Format : HEVC
Bit rate : 7 268 kb/s
Height : 1 602 pixels
Color space : YUV
Bit depth : 8 bits
Bits/(Pixel*Frame) : 0.049
Stream size : 5.69 GiB (92%)
Encoding settings : wpp / ctu=64 / min-cu-size=8 / max-tu-size=32 / tu-intra-depth=1 / tu-inter-depth=1 / me=1 / subme=2 / merange=57 / no-rect / no-amp / max-merge=2 / temporal-mvp / no-early-skip / rskip / rdpenalty=0 / no-tskip / no-tskip-fast / strong-intra-smoothing / no-lossless / no-cu-lossless / no-constrained-intra / no-fast-intra / open-gop / no-temporal-layers / interlace=0 / keyint=240 / min-keyint=24 / scenecut=40 / rc-lookahead=20 / lookahead-slices=8 / bframes=4 / bframe-bias=0 / b-adapt=2 / ref=3 / limit-refs=3 / no-limit-modes / weightp / no-weightb / aq-mode=1 / qg-size=32 / aq-strength=1.00 / cbqpoffs=0 / crqpoffs=0 / rd=3 / psy-rd=2.00 / rdoq-level=0 / psy-rdoq=0.00 / log2-max-poc-lsb=8 / no-rd-refine / signhide / deblock=0:0 / sao / no-sao-non-deblock / b-pyramid / cutree / no-intra-refresh / rc=abr / bitrate=7500 / qcomp=0.60 / qpmin=0 / qpmax=69 / qpstep=4 / ipratio=1.40 / pbratio=1.30
Default : Yes
Forced : No
Audio
Format : AC-3
Codec ID : A_AC3
Bit rate : 512 kb/s
Bit depth : 16 bits
Delay relative to video : 1 s 595 ms
Stream size : 411 MiB (6%)
Title : Surround
Language : German
Default : Yes
Forced : No
I feel for you. You've given a log and mediainfo. But I'm not support, just another user.
This could be the old GL issue that cannot be fixed without moving to Metal rendering.
@davilla?
@davilla?
Yes? No? maybe?
Not without ditching OpenGL and moving to metal
