Film collections - text overlay bug Topic is solved
Any Opacity skin issues go here
chrisc2r
Post by chrisc2r »
Hello,
I'm using the Opacity skin on a Fire Stick
When films are collected into groups, e.g. "Star Wars collection", opacity displays the release dates and the film titles underneath the poster.
Where the name of the film wraps to the next line, there isn't enough space, so it overlays slightly on the line above.
Then, the collection information text itself scrolls on top of the lot, resulting in an unreadable mess.
It would make most sense to do away with the collection information text (as to be honest, there isn't anywhere that it would fit), and then scroll the film names/years within the collection in the panel below the poster.
If unable to replicate let me know and I'll take a photo of what I mean.
Chris
Re: Film collections - text overlay bug
Snap a quick photo please, you can attach it here
chrisc2r
Post by chrisc2r »
Thanks, the first shows the Star Wars collection, and the other is from the Space Odyssey Series, which illustrates better the collection narrative text overlaying on top of the film titles.
This scrolls up, producing a somewhat messy effect!
On closer inspection, it appears that the longer titles don''t wrap, they just have ... to indicate that the full text isn't shown, which is fine. The issue is definitely the collection narrative text overlaying.
I suspect that the collection year is irrelevant, so probably could be dispensed with to save space.
Ouch :)
Looks like the only way would be to remove it.. I’ll look into it
EDIT: fixed for next TestFlight/Beta/relaease
chrisc2r
Post by chrisc2r »
Thanks for the speedy response, appreciated.
chrisc2r
Post by chrisc2r »
This has deployed this morning and is Resolved, thanks.
