Hi there,
about two days ago the universal movie scraper stopped working. "unable to connect to remote server".
The reason seems to be a change with an imdb subdomain: https://forum.kodi.tv/showthread.php?ti ... pid2938805
Would you please push v2.9.13 (https://forum.kodi.tv/showthread.php?tid=129821), which fixes the problem, to mrmc? Or is there a way to update it myself. My version is v2.9.12 on mrmc 3.9.6
Thanks in advance!
Universal Movie Scraper not working with imdb anymore
Re: Universal Movie Scraper not working with imdb anymore
I am also suffering from this problem and will be appreciative if the Mrmc team could address it or (if it is possible) provide a workaround.
Best regards,
Kris
Best regards,
Kris
fix in mrmc 3.9.7 (in testflight only right now)
Many thanks davilla.
Kris
Kris
Thanks for the update!
Any update on when the update will get released, it's getting somewhat annoying.
We are finalising it, there is a Beta for Android and a TestFlight for Apple TV that you could use until it’s releasedensignvorik wrote: ↑27 Apr 2020, 19:11 Any update on when the update will get released, it's getting somewhat annoying.
Thanks for the quick reply. I will put up with it for now as nowhere near getting close to running out of things to watch, just annoying having to press yes to the continue searching prompt about 6 times each time on launch (otherwise TV shows don't get added either)amet wrote: ↑27 Apr 2020, 19:14We are finalising it, there is a Beta for Android and a TestFlight for Apple TV that you could use until it’s releasedensignvorik wrote: ↑27 Apr 2020, 19:11 Any update on when the update will get released, it's getting somewhat annoying.
If no update in the next week, I'll look into the testflight. How do I get on that?
Is there an ETA on the release or when new beta invites are beeing sent out?
