Hi, I use MrMc 3.9.6 on Apple TV 4 (tvOS 13.3.1)
I find there some issue below:
1, can not edit or remove video source sometime, click on the button, but no respond.
2, can not add video to add to favourites, no respond
3, once after click on the any above function button (no respond), then if click any setting button are no respond as well.
I use MrMc for about a year, no problem at the beginning
Any suggestion will be great help, thanks
Can not delete or edit video source
Re: Can not delete or edit video source
sometime I only able to edit once for any video source, then if click to edit other source again will be no respond.
are there anyone have the similar problem ?
Haven’t seen the issue... can you get a debuglog when this happens?
Hi, The log files has been uploaded, files name is 82VSQ.log,
The other problem is, cannot add to favourites
thanks
thanks
The problem is solved:
I found you need to press the Apple TV remote & release a little bit slow then work, if press quick will be no respond. the problem was solved, but wondering before press quick & hear click sound always work? my apple TV touch surface tracking always set to Medium.
You might want to check out iMovie or Adobe Premiere Rush for basic editing on your MacBook. Both are user-friendly and great for university projects. I've been in the editing game for over three years and often lean towards less-known platforms as they often offer more bang for the buck.
On that note, Movavi has been my go-to for over a year. It strikes a nice balance with easy access and a range of editing tools. It includes features like video conversion, screen recording, and more, without being overwhelming.
