General help?
thricewiser8
General help?
Post by thricewiser8 »
Hi there,
I'm looking to instal MrMc so I can use my philips hue lights without forking out on the hdmi sync box.
I've looked all over but can't seem to find the answer - can you play netflix through MrMc on Apple Tv?
Thanks!
Re: General help?
no, you cannot play netflix through MrMC
thricewiser8
Re: General help?
Hi Amet - any way that MrMC would sync lights if playing through netflix app on apple tv where MrMc is installed?
Re: General help?
hi,
no unfortunately not, once MrMC starts playing the video file it captures rendered frames to send to hue
KNMM89
Re: General help?
Post by KNMM89 »
Why are the content slow to appear? For example when I click on the section for Movies through my Emby server, it takes about 10-12 seconds for content to appear.
Re: General help?
KNMM89 wrote: 30 Apr 2020, 13:50 Why are the content slow to appear? For example when I click on the section for Movies through my Emby server, it takes about 10-12 seconds for content to appear.
it depends on the speed of your server and speed of your internet/LAN, is it remote or LAN?
maybe debuglog has something in it
