How to request Testflight access: Send an email to [email protected] with the subject "let me in!", include your forum username and email address tied to your AppleTV4/4K. Users that are already in previous testflight series are automatically enrolled into this one.
Warning: If we determine that you have requested entry into Testflight to bypass purchasing MrMC, you will be ejected and banned from the forum.
When reporting issues, please include debuglog
3.9.7 (200419.950)
- jellyfin: do not mark jellyfin as library item
- MediaService: add year to sort mathod
- jellyfin: default to HTTP
- retry caching the image if it fails
- fix playback of file item that was not scanned in a library and default select action is INFO
- capitalize home strings
- reload RA and in progress items on home after "OnStop"
- jellyfin: more fixes
- opacity: sync github version to makefile
- add Dialog.SetAutoClose(windowID,timeout)
- emby/jellyfin: fallback for season thumbs
- tvos: disableScreenSaver on every keypress
- bump script.plex
3.9.7 (200423.2008)
- epg: check tag before trying to access it
- fix image leak when retry, limit to 10 retrys
- emby: fix rating on Emby server > 4.2
- emby/jelly: sort recently added and in progress
- fix spelling
- disable unused buttons in Video Info dialogue
3.9.7 (200425.1423)
- bump pvr.tvmosaic (fix osd stutter)
3.9.7 (200428.47)
- capitalize System category texts
- bport: fix smi subtitles to use quoted start tags
- bport: settings, add "Dark Grey" subtitles color option
- bport: add subtitle(text) opacity
- Mediaservices: list Shows and seasons from home screen
- jellyfin: not all servers have ServerPropertyLocalAddress
- plex: fix fanart display error
3.9.7 (200504.1049)
- bump pvr.mythtv (api 30)
- add EPG_TIMEFRAME_UNLIMITED, PVR_CHANNEL_INVALID_UID
- plex: hide show year in season listing
- send “UpdateRecentlyAdded" announcement when entering becoming active
- dont stop plex/emby/jf services if we are sent into background, we only communicate with the server on demand
- plex(emby/JF) :fix TopShelf items
- mrmcDB: fix missing season/episode thumbs on TopShelf
- servicesmanager: get GetVideoViewNode for Plex/Emby/JF
3.9.7 (200520.1037)
- emby/JF: limit the number of items collected to 1000 per server hit, server will take time and we will timeout
- services: rework reporting logic
- change episode label format to Sx:Exx
Testing MrMC 3.9.7 - Apple TV
- Waltman
Re: Testing MrMC 3.9.5 - Apple TV
Nothing to report. 3.9.5 is Working as it should.
SETTOP-BOX :Apple TV 4K
Skin: Ariana
Database: MySQL
NAS: Synolgy DS1513+
TV: LG55OLEDC8
Skin: Ariana
Database: MySQL
TV: LG55OLEDC8
- Ted377
Everything works as it should.
FW: tvOS 17.4 ()
Front-End: MrMC 3.9.12 ()
Skin: Opacity
NAS: QNAP TS-431P3
Back-End: TVHeadend/PLEX
TUNER: Kathrein EXIP 418
FW: tvOS 17.4 ()
Skin: Opacity
NAS: QNAP TS-431P3
No problems here either, all working.
working good with the thetvdb fix shows are now being found again
- Waltman
I am experiencing some random crashes, 2 times now in the last three days. I enabled full logging and will post a log when it happens again.
Skin: Ariana
Database: MySQL
TV: LG55OLEDC8
Skin: Ariana
Database: MySQL
TV: LG55OLEDC8
- Montoya
Regenerate thumbnails from cached images is not working anymore with Emby stable server.
Reverted to 3.9.4 and 3.9.3 TF builds and notice now that all those builds were also affected.
emby server should serve that thumb to us, if its not then it might be that something has changed in emby API... which would not surprise me
any chance you have the log for it?
The stuttering video on live TV if the info bar is active still exits. The live TV stops always after ~ 60 sec with an rotating icon in the middle, only a complete restart of the app helps for a while. Other clients like Kodi (Android TV) or the iPad client from TVMosaic working to the same time without problems.
TV: Sony BRAVIA-KDL-50W805B | SB: Bose Soundbar 500 | RC: Logitech Harmony Companion | Player: Apple Tv 4k | TV-Server: Raspbian - HTS Tvheadend 4.2.8-34
- Montoya
I think something else is going on, because MrMC Touch 3.9.5 TF behaves correctly and shows changed cover of a movie, when “Regenerate thumbnails” is executed.
Only Apple TV version won’t delete and refresh cached thumbnails, when a movie cover is changed.
(Tested on stable and current beta Emby server)
