Thanks.
Just run a "adb logcat > whatever.log" while trying to play the file and the shield crashes, then update whatever.log to, e.g, pastebin
Dolby vision for Android
Re: Dolby vision for Android
Ok, here is the logcat, in 3 chunks...
Part 1 https://pastebin.com/3ejvGsEK
Part 2 https://pastebin.com/WbXBt50z
Part 3 (last) https://pastebin.com/f4366LCM
Just edited this post... Part 3 was incorrect, it is now the correct 3rd part of the log.
Good luck, happy hunting!
Ahh, yes, I agree the HDR (10, +, DV, HLG) in general growing pains have been... painful.cosmoxl wrote: ↑17 Nov 2019, 17:52 The problem is that device makers have to worry about two forms of Dolby Vision. The original, and then the sony (low latency) version. Getting everything bug free is apparently a difficult task. Then you have people complaining about their LG TVs not showing bt2020 along with DV ...but the truth is, it shouldn't. The original DV will not result in your TV saying bt2020 along with DV. But, the sony type DV will. So, they apparently are only accustomed to seeing sony DV. Thus, when the shield does original DV they think it's broken because they don't see bt2020. sigh
In another year or so it will all get ironed out - just in time for 8K and whatever new shiny things they will add to that
Ha, yup, and then we get to start all over againJGrana01 wrote: ↑17 Nov 2019, 20:18Ahh, yes, I agree the HDR (10, +, DV, HLG) in general growing pains have been... painful.cosmoxl wrote: ↑17 Nov 2019, 17:52 The problem is that device makers have to worry about two forms of Dolby Vision. The original, and then the sony (low latency) version. Getting everything bug free is apparently a difficult task. Then you have people complaining about their LG TVs not showing bt2020 along with DV ...but the truth is, it shouldn't. The original DV will not result in your TV saying bt2020 along with DV. But, the sony type DV will. So, they apparently are only accustomed to seeing sony DV. Thus, when the shield does original DV they think it's broken because they don't see bt2020. sigh
- koying
At least it is easily reproducible.
Will you forward this to NVidia? If you want, I have a technical contact (Manuel Guzman) that is pretty responsive. I can send him this thread.
- koying
Ok, I just sent part of the post (my 3 test cases) and the logcats to Manuel.
I will let you know if/when he responds.
Thanks!
Thanks!
There is no APK to download, it’s done through Beta program via Google or Amazon
