Testing MrMC 3.9.3 - Apple TV
DocEagle
Re: Testing MrMC 3.9.3 - Apple TV
Post by DocEagle »
Here you see the conversion process:
14:13:27.598 T:6104199168  NOTICE: Running database version Addons20
14:13:27.598 T:6104199168   DEBUG: Initialize, updating databases...
14:13:27.599 T:6104199168  NOTICE: Running database version ViewModes6
14:13:27.601 T:6104199168  NOTICE: Running database version Textures13
14:13:27.611 T:6104199168    INFO: MYSQL: Connected to version 5.5.60-0+deb7u1
14:13:27.633 T:6104199168  NOTICE: Running database version xbmc_music60
14:13:27.650 T:6104199168   ERROR: Unable to open database: xbmc_video116 [1049](Unknown database 'xbmc_video116')
14:13:27.664 T:6104199168   ERROR: Unable to open database: xbmc_video115 [1049](Unknown database 'xbmc_video115')
14:13:27.679 T:6104199168   ERROR: Unable to open database: xbmc_video114 [1049](Unknown database 'xbmc_video114')
14:13:27.693 T:6104199168   ERROR: Unable to open database: xbmc_video113 [1049](Unknown database 'xbmc_video113')
14:13:27.708 T:6104199168   ERROR: Unable to open database: xbmc_video112 [1049](Unknown database 'xbmc_video112')
14:13:27.722 T:6104199168   ERROR: Unable to open database: xbmc_video111 [1049](Unknown database 'xbmc_video111')
14:13:27.737 T:6104199168   ERROR: Unable to open database: xbmc_video110 [1049](Unknown database 'xbmc_video110')
14:13:27.751 T:6104199168   ERROR: Unable to open database: xbmc_video109 [1049](Unknown database 'xbmc_video109')
14:13:27.769 T:6104199168   ERROR: Unable to open database: xbmc_video108 [1049](Unknown database 'xbmc_video108')
14:13:27.793 T:6104199168  NOTICE: Old database found - updating from version 107 to 116
14:15:35.313 T:6104199168  NOTICE: Attempting to update the database xbmc_video116 from version 107 to 116
14:15:49.621 T:6104199168    INFO: CreateAnalytics - creating indicies
14:16:45.417 T:6104199168    INFO: CreateAnalytics - creating triggers
14:16:45.827 T:6104199168    INFO: create episode_view
14:16:45.876 T:6104199168    INFO: create tvshowcounts
14:16:45.901 T:6104199168    INFO: create tvshowlinkpath_minview
14:16:45.924 T:6104199168    INFO: create tvshow_view
14:16:45.967 T:6104199168    INFO: create season_view
14:16:46.019 T:6104199168    INFO: create musicvideo_view
14:16:46.058 T:6104199168    INFO: create movie_view
14:16:46.143 T:6104199168    INFO: Update to version 116 successful
14:16:46.151 T:6104199168  NOTICE: Running database version TV29
14:16:46.158 T:6104199168  NOTICE: Running database version Epg11
14:16:46.159 T:6104199168   DEBUG: Initialize, updating databases... DONE
14:16:46.164 T:6101331968    INFO: DPMS: not supported on this platform
Set-Top-Box: Apple TV 4K
FW: tvOS 16.2
Front-End: MrMC 3.9.12 (210507.625)
Skin: Ariana
Database: MySQL
NAS: QNAP TS-451+
DocEagle
Post by DocEagle »
Another notice:
Under System info > summary and System info > Network the real values ot the IP address and subnet mask are not shown, the output instead is just 0.0.0.0.
FW: tvOS 16.2
Skin: Ariana
Database: MySQL
NAS: QNAP TS-451+
DocEagle wrote: 11 Dec 2019, 14:02 Another notice:
And does it show its connected to internet?
It’s strange, we get that info from Apple TV and it shows fine here
DocEagle
Post by DocEagle »
I never noticed this before, but it's the same on my 2nd ATV on which still is running MrMC v3.9.2.
Link and Internet are connected.
Maybe there is problem around ipv6? I toggled the switch to enable/disable ipv6, but without any effect.
FW: tvOS 16.2
Skin: Ariana
Database: MySQL
NAS: QNAP TS-451+
DocEagle wrote: 11 Dec 2019, 13:19 No, that‘s the wrong one.
I added a third log later on, where you find another try against the TV-server.
Meanwhile I dropped the video databases 112 and 116. The conversion took place, but the waiting time still happens.
ok, I see whats happening....
on my side is a bit slow but not alarming, issue is with the new Kodi database and call that was introduced there: "SELECT * FROM season_view WHERE season_view.idShow"
19:25:17.498 T:6183104512   DEBUG: RunQuery took 5001 ms for 9 items query: SELECT * FROM season_view  WHERE season_view.idShow = 387
as you can see, it takes 5 seconds here... I searched for it a bit and the issue is definitely with Kodi database. -> https://forum.kodi.tv/showthread.php?tid=340340
suggested fix is here -> https://forum.libreelec.tv/thread/13990 ... post108409
# * Query Cache Configuration
query_cache_limit	= 2M (was 1)
query_cache_size = 32M (was 16)
I have added it to my qnap MySQL (MariaDB) server and it seems to help a lot
19:56:22.590 T:6112096256   DEBUG: RunQuery took 1 ms for 9 items query: SELECT * FROM season_view  WHERE season_view.idShow = 387
if we want kodi database compatibility, this is what it takes ...
DocEagle
Post by DocEagle »
I am one step further. The waiting problem must be associated to the handling of TV shows. All my movies (on a separate NFS connected NAS) play as expected without any remarkable pause. Two of my shows are stored on this ‚movies-NAS‘ as well, and the same effect occurs here.
FW: tvOS 16.2
Skin: Ariana
Database: MySQL
NAS: QNAP TS-451+
DocEagle wrote: 11 Dec 2019, 16:29 I am one step further. The waiting problem must be associated to the handling of TV shows. All my movies (on a separate NFS connected NAS) play as expected without any remarkable pause. Two of my shows are stored on this ‚movies-NAS‘ as well, and the same effect occurs here.
yes, its tvshow related and only effects listing of TV Shows.
DocEagle
Post by DocEagle »
amet wrote: 11 Dec 2019, 16:02
Yes, I can confirm that this is the clue, the response time is down to 5 seconds now. I would suggest you mention this in the release notes for the mysql users.
Maybe it‘s even better to check the necessary indices and/or reindex the database.
FW: tvOS 16.2
Skin: Ariana
Database: MySQL
NAS: QNAP TS-451+
I am not sure it has to do with indexing the database, it’s more of the server cache limit if I understood correctly.
DocEagle wrote: 11 Dec 2019, 15:19 I never noticed this before, but it's the same on my 2nd ATV on which still is running MrMC v3.9.2.
Is apple tv getting ipv6 address from the router? If so, we don’t currently support that, but it’s on the to-do list
