Testing MrMC 3.9.3 - Apple TV
Re: Testing MrMC 3.9.3 - Apple TV
3.9.3 (191210.1231)
- Kodi v18 "Leia" compatible video database
Would be good to get few confirmations that ^^ is okay, works for us obviously but just to be on the safe side.
Thanks!
Waltman
Post by Waltman »
amet wrote: 10 Dec 2019, 14:49 3.9.3 (191210.1231)
Thanks!
I can confirm the kodi v18 leia compatible videodatabase 👍.
SETTOP-BOX :Apple TV 4K
Skin: Ariana
Database: MySQL
NAS: Synolgy DS1513+
TV: LG55OLEDC8
Waltman
Post by Waltman »
Deleted double reaction :D
(Database is kodi 18 compatibel)
Skin: Ariana
Database: MySQL
TV: LG55OLEDC8
I meant from few different users, not 2 from you @Waltman :)
Thanks for the confirmation!!
wodkab
Post by wodkab »
Would be good to get few confirmations ...
I also have seen no issues so far.
I didn't let MRMC do a conversion of the database but connected it to an already existing V18 video database ... works fine :)
DocEagle
Post by DocEagle »
I got trouble with the latest two builds accessing one of my two NAS servers, where my TV episodes are stored. Every time I quit MrMC(or after a system restart) the first access to any selected show lasts about 70 seconds! After playing an episode following accesses to the same show work as expected, but selecting another show same procedure as above.
I can‘t tell if this is a database problem, hope you can find a helpful hint inside the log.
Log:
Content of MrMC Log
11:24:14.447 T:6138195968  NOTICE: special://profile/ is mapped to: special://masterprofile/
11:24:14.448 T:6138195968  NOTICE: -----------------------------------------------------------------------
11:24:14.448 T:6138195968  NOTICE: Starting MrMC (3.9-3 Git:2019-12-09-dad86cc). Platform: TVOS ARM64 64-bit
11:24:14.448 T:6138195968  NOTICE: Using Release MrMC x64 build
11:24:14.448 T:6138195968  NOTICE: MrMC compiled Dec 10 2019 by Clang 11.0.0 (clang-1100.0.33.12) for TVOS ARM64 64-bit version 11.2.0 (110200)
11:24:14.448 T:6138195968  NOTICE: Running on Apple Inc. AppleTV6,2 with TVOS 13.3, kernel: Darwin ARM 64-bit version 19.2.0
11:24:14.448 T:6138195968  NOTICE: Host CPU: arm64 v8, 3 cores available
11:24:14.448 T:6138195968  NOTICE: ARM Features: Neon enabled
11:24:14.448 T:6138195968  NOTICE: special://xbmc/ is mapped to: /private/var/containers/Bundle/Application/BB9C09E3-F0A9-4BF4-A977-9A409EA25057/MrMC.app/AppData/AppHome
11:24:14.448 T:6138195968  NOTICE: special://xbmcbin/ is mapped to: /private/var/containers/Bundle/Application/BB9C09E3-F0A9-4BF4-A977-9A409EA25057/MrMC.app/AppData/AppHome
11:24:14.448 T:6138195968  NOTICE: special://masterprofile/ is mapped to: /var/mobile/Containers/Data/Application/D1E48118-3907-4FFC-A6A0-39ADF81E10AF/Library/Caches/home/userdata
11:24:14.448 T:6138195968  NOTICE: special://home/ is mapped to: /var/mobile/Containers/Data/Application/D1E48118-3907-4FFC-A6A0-39ADF81E10AF/Library/Caches/home
11:24:14.448 T:6138195968  NOTICE: special://temp/ is mapped to: /private/var/mobile/Containers/Data/Application/D1E48118-3907-4FFC-A6A0-39ADF81E10AF/tmp/temp
11:24:14.448 T:6138195968  NOTICE: special://logs/ is mapped to: /var/mobile/Containers/Data/Application/D1E48118-3907-4FFC-A6A0-39ADF81E10AF/Library/Caches/logs/
11:24:14.448 T:6138195968  NOTICE: special://frameworks/ is mapped to: /private/var/containers/Bundle/Application/BB9C09E3-F0A9-4BF4-A977-9A409EA25057/MrMC.app/Frameworks
11:24:14.448 T:6138195968  NOTICE: The executable running is: /private/var/containers/Bundle/Application/BB9C09E3-F0A9-4BF4-A977-9A409EA25057/MrMC.app/MrMC
11:24:14.448 T:6138195968  NOTICE: Local hostname: ATV-4K
11:24:14.448 T:6138195968  NOTICE: Log File is located: special://logs/mrmc.log
11:24:14.449 T:6138195968  NOTICE: -----------------------------------------------------------------------
11:24:14.464 T:6138195968  NOTICE: load settings...
11:24:14.470 T:6138195968 WARNING: CSettingString: unknown options filler "timezonecountries" of "locale.timezonecountry"
11:24:14.470 T:6138195968 WARNING: CSettingString: unknown options filler "timezones" of "locale.timezone"
11:24:14.472 T:6138195968 WARNING: CSettingInt: unknown options filler "audiocdactions" of "audiocds.autoaction"
11:24:14.477 T:6138195968 WARNING: CSetting: duplicate <update> definition for "lookandfeel.soundskin"
11:24:14.477 T:6138195968   ERROR: CSetting: missing <control> tag of "videoscreen.vsync"
11:24:14.477 T:6138195968 WARNING: CSettingGroup: unable to read setting "videoscreen.vsync"
11:24:14.478 T:6138195968  NOTICE: Found 1 Lists of Devices
11:24:14.478 T:6138195968  NOTICE: Enumerated DARWINIOS devices:
11:24:14.478 T:6138195968  NOTICE:     Device 1
11:24:14.478 T:6138195968  NOTICE:         m_deviceName      : default
11:24:14.478 T:6138195968  NOTICE:         m_displayName     : Default
11:24:14.478 T:6138195968  NOTICE:         m_displayNameExtra:
11:24:14.478 T:6138195968  NOTICE:         m_deviceType      : AE_DEVTYPE_HDMI
11:24:14.478 T:6138195968  NOTICE:         m_channels        : FL,FR,FC,LFE,BL,BR
11:24:14.478 T:6138195968  NOTICE:         m_sampleRates     : 44100,48000
11:24:14.478 T:6138195968  NOTICE:         m_dataFormats     : AE_FMT_S16LE,AE_FMT_FLOAT
11:24:14.478 T:6138195968  NOTICE:         m_streamTypes     : No passthrough capabilities
11:24:14.509 T:6138195968  NOTICE: No settings file to load (special://xbmc/system/advancedsettings.xml)
11:24:14.510 T:6138195968  NOTICE: No settings file to load (special://masterprofile/advancedsettings.xml)
11:24:14.510 T:6138195968  NOTICE: Default DVD Player: dvdplayer
11:24:14.510 T:6138195968  NOTICE: Default Video Player: dvdplayer
11:24:14.510 T:6138195968  NOTICE: Default Audio Player: paplayer
11:24:14.510 T:6138195968  NOTICE: Enabled debug logging due to GUI setting (2)
11:24:14.510 T:6138195968  NOTICE: Log level changed to "LOG_LEVEL_DEBUG_FREEMEM"
11:24:14.510 T:6138195968  NOTICE: CMediaSourceSettings: loading media sources from special://masterprofile/sources.xml
11:24:14.510 T:6138195968   DEBUG: found key /userdata/sources.xml
11:24:14.511 T:6138195968  NOTICE: Loading player core factory settings from special://xbmc/system/playercorefactory.xml.
11:24:14.512 T:6138195968   DEBUG: CPlayerCoreConfig::<ctor>: created player DVDPlayer for core 1
11:24:14.512 T:6138195968   DEBUG: CPlayerCoreConfig::<ctor>: created player oldmplayercore for core 1
11:24:14.512 T:6138195968   DEBUG: CPlayerCoreConfig::<ctor>: created player PAPlayer for core 3
11:24:14.512 T:6138195968   DEBUG: CPlayerSelectionRule::Initialize: creating rule: system rules
11:24:14.512 T:6138195968   DEBUG: CPlayerSelectionRule::Initialize: creating rule: hdhomerun/mms/udp
11:24:14.512 T:6138195968   DEBUG: CPlayerSelectionRule::Initialize: creating rule: lastfm/shout
11:24:14.512 T:6138195968   DEBUG: CPlayerSelectionRule::Initialize: creating rule: rtmp
11:24:14.512 T:6138195968   DEBUG: CPlayerSelectionRule::Initialize: creating rule: rtsp
11:24:14.512 T:6138195968   DEBUG: CPlayerSelectionRule::Initialize: creating rule: streams
11:24:14.512 T:6138195968   DEBUG: CPlayerSelectionRule::Initialize: creating rule: aacp/sdp
11:24:14.512 T:6138195968   DEBUG: CPlayerSelectionRule::Initialize: creating rule: mp2
11:24:14.512 T:6138195968   DEBUG: CPlayerSelectionRule::Initialize: creating rule: dvd
11:24:14.512 T:6138195968   DEBUG: CPlayerSelectionRule::Initialize: creating rule: dvdimage
11:24:14.512 T:6138195968   DEBUG: CPlayerSelectionRule::Initialize: creating rule: sdp/asf
11:24:14.512 T:6138195968   DEBUG: CPlayerSelectionRule::Initialize: creating rule: M4V
11:24:14.512 T:6138195968   DEBUG: CPlayerSelectionRule::Initialize: creating rule: nsv
11:24:14.512 T:6138195968   DEBUG: CPlayerSelectionRule::Initialize: creating rule: radio
11:24:14.512 T:6138195968  NOTICE: Loaded playercorefactory configuration
11:24:14.512 T:6138195968   DEBUG: found key /userdata/playercorefactory.xml
11:24:14.512 T:6138195968  NOTICE: Loading player core factory settings from special://masterprofile/playercorefactory.xml.
11:24:14.512 T:6138195968  NOTICE: special://masterprofile/playercorefactory.xml does not exist. Skipping.
11:24:14.513 T:6138195968   DEBUG: found key /userdata/wakeonlan.xml
11:24:14.513 T:6138195968  NOTICE: WakeOnAccess - Load settings :
11:24:14.513 T:6138195968  NOTICE: WakeOnAccess - Enabled:FALSE
11:24:14.513 T:6138195968  NOTICE:   -Network init timeout : [20] sec
11:24:14.513 T:6138195968  NOTICE:   -Network settle time  : [500] ms
11:24:14.514 T:6138195968  NOTICE:   Registering wakeup entry:
11:24:14.514 T:6138195968  NOTICE:     HostName        : 192.168.70.41
11:24:14.514 T:6138195968  NOTICE:     MacAddress      : 00:08:9B:F9:E8:33
11:24:14.514 T:6138195968  NOTICE:     PingPort        : 0
11:24:14.514 T:6138195968  NOTICE:     PingMode        : 0
11:24:14.514 T:6138195968  NOTICE:     Timeout         : 300 (sec)
11:24:14.514 T:6138195968  NOTICE:     WaitForOnline   : 40 (sec)
11:24:14.514 T:6138195968  NOTICE:     WaitForOnlineEx : 40 (sec)
11:24:14.514 T:6138195968  NOTICE:     WaitForServices : 5 (sec)
11:24:14.514 T:6138195968  NOTICE:     HostName        : 192.168.70.44
11:24:14.514 T:6138195968  NOTICE:     MacAddress      : 00:26:2D:01:72:DE
11:24:14.515 T:6138195968   DEBUG: found key /userdata/profiles.xml
11:24:14.515 T:6138195968   DEBUG: Previous line repeats 1 times.
11:24:14.515 T:6138195968   DEBUG: NSUSerDefaults: compressed /userdata/profiles.xml from 941 to 346
11:24:14.516 T:6138195968   DEBUG: found key /userdata/guisettings.xml
11:24:14.517 T:6138195968   DEBUG: Previous line repeats 1 times.
11:24:14.517 T:6138195968   DEBUG: NSUSerDefaults: compressed /userdata/guisettings.xml from 30656 to 6176
11:24:14.517 T:6138195968    INFO: creating subdirectories
11:24:14.517 T:6138195968    INFO: userdata folder: special://masterprofile/
11:24:14.517 T:6138195968    INFO: recording folder:
11:24:14.517 T:6138195968    INFO: screenshots folder:
11:24:14.527 T:6139342848    INFO: CActiveAE::ApplySettings - Forcing samplerate to 48000
11:24:14.527 T:6139916288    INFO: CActiveAESink::OpenSink - initialize sink
11:24:14.527 T:6139916288   DEBUG: CActiveAESink::OpenSink - trying to open device DARWINIOS:default
11:24:14.529 T:6139916288   DEBUG: virtual bool CAESinkDARWINIOS::Initialize(AEAudioFormat &, std::string &): AudioStreamBasicDescription: [lpcm] Mixable Interleaved 6 Channel 32-bit Floating Point LE (48000Hz) pcm
11:24:14.538 T:6139916288  NOTICE: bool CAAudioUnitSink::setupAudio() setting channels 6
11:24:14.538 T:6139916288  NOTICE: bool CAAudioUnitSink::setupAudio() setting samplerate 48000.000000
11:24:14.538 T:6139916288  NOTICE: bool CAAudioUnitSink::setupAudio() setting buffer duration to 0.128000
11:24:16.067 T:6139916288  NOTICE: bool CAAudioUnitSink::setupAudio() total latency = 0.066000
11:24:16.068 T:6139916288  NOTICE: bool CAAudioUnitSink::setupAudio() setup audio format: [lpcm] Mixable Interleaved 6 Channel 32-bit Floating Point LE (48000Hz)
11:24:16.068 T:6139916288  NOTICE: void dumpAVAudioSessionProperties() audio route = HDMIOutput
11:24:16.069 T:6139916288  NOTICE: void dumpAVAudioSessionProperties() sampleRate 48000.000000
11:24:16.069 T:6139916288  NOTICE: void dumpAVAudioSessionProperties() outputLatency 0.034000
11:24:16.069 T:6139916288  NOTICE: void dumpAVAudioSessionProperties() IOBufferDuration 0.032000
11:24:16.069 T:6139916288  NOTICE: void dumpAVAudioSessionProperties() outputNumberOfChannels 6
11:24:16.069 T:6139916288  NOTICE: void dumpAVAudioSessionProperties() maximumOutputNumberOfChannels 6
11:24:16.069 T:6139916288   DEBUG: DumpAudioDescriptions: void dumpAVAudioSessionProperties()
11:24:16.070 T:6139916288   DEBUG: DumpAudioDescriptions: input count = 0
11:24:16.070 T:6139916288   DEBUG: DumpAudioDescriptions: output count = 1
11:24:16.070 T:6139916288   DEBUG: DumpAudioDescriptions : portName, ATV-4K
11:24:16.071 T:6139916288   DEBUG: DumpAudioDescriptions: channelLabel, -1
11:24:16.071 T:6139916288   DEBUG: DumpAudioDescriptions: channelName , ATV-4K 1
11:24:16.071 T:6139916288   DEBUG: DumpAudioDescriptions: channelName , ATV-4K 2
11:24:16.074 T:6139916288   DEBUG: CActiveAESink::OpenSink - DARWINIOS Initialized:
11:24:16.074 T:6139916288   DEBUG:   Output Device : Default
11:24:16.074 T:6139916288   DEBUG:   Sample Rate   : 48000
11:24:16.074 T:6139916288   DEBUG:   Sample Format : AE_FMT_FLOAT
11:24:16.074 T:6139916288   DEBUG:   Channel Count : 6
11:24:16.074 T:6139916288   DEBUG:   Channel Layout: FL,FC,FR,BL,BR,LFE
11:24:16.074 T:6139916288   DEBUG:   Frames        : 1024
11:24:16.074 T:6139916288   DEBUG:   Frame Size    : 24
11:24:16.075 T:6139916288   DEBUG: CActiveAESink::GenerateNoise - noiseFactor = 0.000010
11:24:16.084 T:6137622528   DEBUG: DumpAudioDescriptions: AVAudioSessionRouteChangeReasonCategoryChange
11:24:16.084 T:6138195968  NOTICE: Running database version Addons20
11:24:16.084 T:6138195968   DEBUG: SECTION:LoadDLL(libcpluff.framework/libcpluff)
11:24:16.085 T:6137622528   DEBUG: DumpAudioDescriptions: input count = 0
11:24:16.085 T:6138195968   DEBUG: Loading: /private/var/containers/Bundle/Application/BB9C09E3-F0A9-4BF4-A977-9A409EA25057/MrMC.app/Frameworks/libcpluff.framework/libcpluff
11:24:16.085 T:6137622528   DEBUG: DumpAudioDescriptions: output count = 1
11:24:16.085 T:6137622528   DEBUG: DumpAudioDescriptions : portName, ATV-4K
11:24:16.085 T:6137622528   DEBUG: DumpAudioDescriptions: channelLabel, -1
11:24:16.085 T:6137622528   DEBUG: DumpAudioDescriptions: channelName , ATV-4K 1
11:24:16.085 T:6137622528   DEBUG: DumpAudioDescriptions: channelName , ATV-4K 2
11:24:16.085 T:6137622528   DEBUG: DumpAudioDescriptions: AVAudioSessionRouteChangeReasonCategoryChange
11:24:16.086 T:6137622528   DEBUG: DumpAudioDescriptions: input count = 0
11:24:16.086 T:6137622528   DEBUG: DumpAudioDescriptions: output count = 1
11:24:16.086 T:6137622528   DEBUG: DumpAudioDescriptions : portName, ATV-4K
11:24:16.086 T:6137622528   DEBUG: DumpAudioDescriptions: channelLabel, -1
11:24:16.086 T:6137622528   DEBUG: DumpAudioDescriptions: channelName , ATV-4K 1
11:24:16.086 T:6137622528   DEBUG: DumpAudioDescriptions: channelName , ATV-4K 2
11:24:16.102 T:6138195968    INFO: ADDON: cpluff: 'Could not read plug-in directory /var/mobile/Containers/Data/Application/D1E48118-3907-4FFC-A6A0-39ADF81E10AF/Library/Caches/home/addons: No such file or directory'
11:24:16.235 T:6138195968   DEBUG: ADDON: cpluff: 'Plug-in resource.language.ca_es has been installed.'
11:24:16.235 T:6138195968   DEBUG: ADDON: cpluff: 'Plug-in resource.language.mt_mt has been installed.'
11:24:16.235 T:6138195968   DEBUG: ADDON: cpluff: 'Plug-in resource.language.az_az has been installed.'
11:24:16.235 T:6138195968   DEBUG: ADDON: cpluff: 'Plug-in resource.language.vi_vn has been installed.'
11:24:16.235 T:6138195968   DEBUG: ADDON: cpluff: 'Plug-in resource.language.ja_jp has been installed.'
11:24:16.235 T:6138195968   DEBUG: ADDON: cpluff: 'Plug-in resource.language.eo has been installed.'
11:24:16.235 T:6138195968   DEBUG: ADDON: cpluff: 'Plug-in resource.images.weathericons.default has been installed.'
11:24:16.235 T:6138195968   DEBUG: ADDON: cpluff: 'Plug-in resource.language.pl_pl has been installed.'
11:24:16.235 T:6138195968   DEBUG: ADDON: cpluff: 'Plug-in webinterface.default has been installed.'
11:24:16.235 T:6138195968   DEBUG: ADDON: cpluff: 'Plug-in skin.ariana has been installed.'
11:24:16.235 T:6138195968   DEBUG: ADDON: cpluff: 'Plug-in resource.language.en_au has been installed.'
11:24:16.235 T:6138195968   DEBUG: ADDON: cpluff: 'Plug-in kodi.audiodecoder has been installed.'
11:24:16.235 T:6138195968   DEBUG: ADDON: cpluff: 'Plug-in resource.language.fr_ca has been installed.'
11:24:16.235 T:6138195968   DEBUG: ADDON: cpluff: 'Plug-in pvr.argustv has been installed.'
11:24:16.235 T:6138195968   DEBUG: ADDON: cpluff: 'Plug-in resource.language.sr_rs has been installed.'
11:24:16.235 T:6138195968   DEBUG: ADDON: cpluff: 'Plug-in metadata.common.ofdb.de has been installed.'
11:24:16.235 T:6138195968   DEBUG: ADDON: cpluff: 'Plug-in resource.language.fa_af has been installed.'
11:24:16.235 T:6138195968   DEBUG: ADDON: cpluff: 'Plug-in metadata.themoviedb.org has been installed.'
11:24:16.235 T:6138195968   DEBUG: ADDON: cpluff: 'Plug-in resource.language.bg_bg has been installed.'
11:24:16.235 T:6138195968   DEBUG: ADDON: cpluff: 'Plug-in xbmc.metadata has been installed.'
11:24:16.235 T:6138195968   DEBUG: ADDON: cpluff: 'Plug-in resource.language.hu_hu has been installed.'
11:24:16.235 T:6138195968   DEBUG: ADDON: cpluff: 'Plug-in pvr.dvblink has been installed.'
11:24:16.235 T:6138195968   DEBUG: ADDON: cpluff: 'Plug-in resource.language.da_dk has been installed.'
11:24:16.235 T:6138195968   DEBUG: ADDON: cpluff: 'Plug-in resource.language.mk_mk has been installed.'
11:24:16.235 T:6138195968   DEBUG: ADDON: cpluff: 'Plug-in resource.language.pt_pt has been installed.'
11:24:16.235 T:6138195968   DEBUG: ADDON: cpluff: 'Plug-in resource.language.nb_no has been installed.'
11:24:16.235 T:6138195968   DEBUG: ADDON: cpluff: 'Plug-in resource.language.is_is has been installed.'
11:24:16.235 T:6138195968   DEBUG: ADDON: cpluff: 'Plug-in resource.language.ms_my has been installed.'
11:24:16.235 T:6138195968   DEBUG: ADDON: cpluff: 'Plug-in resource.language.sv_se has been installed.'
11:24:16.235 T:6138195968   DEBUG: ADDON: cpluff: 'Plug-in resource.language.ru_ru has been installed.'
11:24:16.235 T:6138195968   DEBUG: ADDON: cpluff: 'Plug-in xbmc.gui has been installed.'
11:24:16.235 T:6138195968   DEBUG: ADDON: cpluff: 'Plug-in script.keymap has been installed.'
11:24:16.235 T:6138195968   DEBUG: ADDON: cpluff: 'Plug-in resource.language.os_os has been installed.'
11:24:16.235 T:6138195968   DEBUG: ADDON: cpluff: 'Plug-in script.advanced.wol has been installed.'
11:24:16.235 T:6138195968   DEBUG: ADDON: cpluff: 'Plug-in resource.language.es_mx has been installed.'
11:24:16.235 T:6138195968   DEBUG: ADDON: cpluff: 'Plug-in resource.language.nl_nl has been installed.'
11:24:16.235 T:6138195968   DEBUG: ADDON: cpluff: 'Plug-in metadata.musicvideos.theaudiodb.com has been installed.'
11:24:16.235 T:6138195968   DEBUG: ADDON: cpluff: 'Plug-in resource.language.ta_in has been installed.'
11:24:16.235 T:6138195968   DEBUG: ADDON: cpluff: 'Plug-in resource.language.gl_es has been installed.'
11:24:16.235 T:6138195968   DEBUG: ADDON: cpluff: 'Plug-in pvr.pctv has been installed.'
11:24:16.235 T:6138195968   DEBUG: ADDON: cpluff: 'Plug-in pvr.tvmosaic has been installed.'
11:24:16.235 T:6138195968   DEBUG: ADDON: cpluff: 'Plug-in screensaver.xbmc.builtin.slideshow has been installed.'
11:24:16.235 T:6138195968   DEBUG: ADDON: cpluff: 'Plug-in pvr.iptvsimple has been installed.'
11:24:16.235 T:6138195968   DEBUG: ADDON: cpluff: 'Plug-in skin.blackglassnova has been installed.'
11:24:16.235 T:6138195968   DEBUG: ADDON: cpluff: 'Plug-in skin.opacity has been installed.'
11:24:16.235 T:6138195968   DEBUG: ADDON: cpluff: 'Plug-in resource.language.ko_kr has been installed.'
11:24:16.235 T:6138195968   DEBUG: ADDON: cpluff: 'Plug-in resource.language.fa_ir has been installed.'
11:24:16.235 T:6138195968   DEBUG: ADDON: cpluff: 'Plug-in pvr.njoy has been installed.'
11:24:16.235 T:6138195968   DEBUG: ADDON: cpluff: 'Plug-in resource.language.uz_uz has been installed.'
11:24:16.235 T:6138195968   DEBUG: ADDON: cpluff: 'Plug-in metadata.common.movieposterdb.com has been installed.'
11:24:16.235 T:6138195968   DEBUG: ADDON: cpluff: 'Plug-in resource.language.tg_tj has been installed.'
11:24:16.235 T:6138195968   DEBUG: ADDON: cpluff: 'Plug-in resource.language.my_mm has been installed.'
11:24:16.235 T:6138195968   DEBUG: ADDON: cpluff: 'Plug-in metadata.common.htbackdrops.com has been installed.'
11:24:16.235 T:6138195968   DEBUG: ADDON: cpluff: 'Plug-in pvr.dvbviewer has been installed.'
11:24:16.235 T:6138195968   DEBUG: ADDON: cpluff: 'Plug-in resource.language.en_gb has been installed.'
11:24:16.235 T:6138195968   DEBUG: ADDON: cpluff: 'Plug-in skin.amber has been installed.'
11:24:16.235 T:6138195968   DEBUG: ADDON: cpluff: 'Plug-in metadata.common.port.hu has been installed.'
11:24:16.235 T:6138195968   DEBUG: ADDON: cpluff: 'Plug-in visualization.spectrum has been installed.'
11:24:16.235 T:6138195968   DEBUG: ADDON: cpluff: 'Plug-in pvr.stalker has been installed.'
11:24:16.235 T:6138195968   DEBUG: ADDON: cpluff: 'Plug-in resource.language.hr_hr has been installed.'
11:24:16.235 T:6138195968   DEBUG: ADDON: cpluff: 'Plug-in resource.language.zh_tw has been installed.'
11:24:16.235 T:6138195968   DEBUG: ADDON: cpluff: 'Plug-in metadata.common.musicbrainz.org has been installed.'
11:24:16.235 T:6138195968   DEBUG: ADDON: cpluff: 'Plug-in resource.language.fo_fo has been installed.'
11:24:16.235 T:6138195968   DEBUG: ADDON: cpluff: 'Plug-in resource.language.zh_cn has been installed.'
11:24:16.235 T:6138195968   DEBUG: ADDON: cpluff: 'Plug-in metadata.local has been installed.'
11:24:16.236 T:6138195968   DEBUG: ADDON: cpluff: 'Plug-in xbmc.webinterface has been installed.'
11:24:16.236 T:6138195968   DEBUG: ADDON: cpluff: 'Plug-in resource.language.ro_ro has been installed.'
11:24:16.236 T:6138195968   DEBUG: ADDON: cpluff: 'Plug-in resource.language.fi_fi has been installed.'
11:24:16.236 T:6138195968   DEBUG: ADDON: cpluff: 'Plug-in resource.language.de_de has been installed.'
11:24:16.236 T:6138195968   DEBUG: ADDON: cpluff: 'Plug-in metadata.common.themoviedb.org has been installed.'
11:24:16.236 T:6138195968   DEBUG: ADDON: cpluff: 'Plug-in metadata.common.theaudiodb.com has been installed.'
11:24:16.236 T:6138195968   DEBUG: ADDON: cpluff: 'Plug-in pvr.filmon has been installed.'
11:24:16.236 T:6138195968   DEBUG: ADDON: cpluff: 'Plug-in resource.language.en_nz has been installed.'
11:24:16.236 T:6138195968   DEBUG: ADDON: cpluff: 'Plug-in script.xbmc.unpausejumpback has been installed.'
11:24:16.236 T:6138195968   DEBUG: ADDON: cpluff: 'Plug-in visualization.waveform has been installed.'
11:24:16.236 T:6138195968   DEBUG: ADDON: cpluff: 'Plug-in resource.language.szl has been installed.'
11:24:16.236 T:6138195968   DEBUG: ADDON: cpluff: 'Plug-in resource.language.en_us has been installed.'
11:24:16.236 T:6138195968   DEBUG: ADDON: cpluff: 'Plug-in xbmc.json has been installed.'
11:24:16.236 T:6138195968   DEBUG: ADDON: cpluff: 'Plug-in resource.language.tr_tr has been installed.'
11:24:16.236 T:6138195968   DEBUG: ADDON: cpluff: 'Plug-in metadata.common.fanart.tv has been installed.'
11:24:16.236 T:6138195968   DEBUG: ADDON: cpluff: 'Plug-in xbmc.audioencoder has been installed.'
11:24:16.236 T:6138195968   DEBUG: ADDON: cpluff: 'Plug-in pvr.vbox has been installed.'
11:24:16.236 T:6138195968   DEBUG: ADDON: cpluff: 'Plug-in resource.uisounds.mrmc has been installed.'
11:24:16.236 T:6138195968   DEBUG: ADDON: cpluff: 'Plug-in metadata.mymovies.dk has been installed.'
11:24:16.236 T:6138195968   DEBUG: ADDON: cpluff: 'Plug-in resource.language.pt_br has been installed.'
11:24:16.236 T:6138195968   DEBUG: ADDON: cpluff: 'Plug-in resource.language.id_id has been installed.'
11:24:16.236 T:6138195968   DEBUG: ADDON: cpluff: 'Plug-in resource.language.th_th has been installed.'
11:24:16.236 T:6138195968   DEBUG: ADDON: cpluff: 'Plug-in resource.language.sk_sk has been installed.'
11:24:16.236 T:6138195968   DEBUG: ADDON: cpluff: 'Plug-in screensaver.xbmc.builtin.black has been installed.'
11:24:16.236 T:6138195968   DEBUG: ADDON: cpluff: 'Plug-in pvr.vdr.vnsi has been installed.'
11:24:16.236 T:6138195968   DEBUG: ADDON: cpluff: 'Plug-in kodi.guilib has been installed.'
11:24:16.236 T:6138195968   DEBUG: ADDON: cpluff: 'Plug-in resource.language.sl_si has been installed.'
11:24:16.236 T:6138195968   DEBUG: ADDON: cpluff: 'Plug-in screensaver.xbmc.builtin.system has been installed.'
11:24:16.236 T:6138195968   DEBUG: ADDON: cpluff: 'Plug-in resource.language.am_et has been installed.'
11:24:16.236 T:6138195968   DEBUG: ADDON: cpluff: 'Plug-in resource.language.fr_fr has been installed.'
11:24:16.236 T:6138195968   DEBUG: ADDON: cpluff: 'Plug-in resource.language.es_ar has been installed.'
11:24:16.236 T:6138195968   DEBUG: ADDON: cpluff: 'Plug-in pvr.mediaportal.tvserver has been installed.'
11:24:16.236 T:6138195968   DEBUG: ADDON: cpluff: 'Plug-in resource.language.eu_es has been installed.'
11:24:16.236 T:6138195968   DEBUG: ADDON: cpluff: 'Plug-in resource.language.bs_ba has been installed.'
11:24:16.236 T:6138195968   DEBUG: ADDON: cpluff: 'Plug-in resource.language.sr_rs@latin has been installed.'
11:24:16.236 T:6138195968   DEBUG: ADDON: cpluff: 'Plug-in metadata.universal has been installed.'
11:24:16.236 T:6138195968   DEBUG: ADDON: cpluff: 'Plug-in resource.language.cs_cz has been installed.'
11:24:16.236 T:6138195968   DEBUG: ADDON: cpluff: 'Plug-in resource.language.mi has been installed.'
11:24:16.236 T:6138195968   DEBUG: ADDON: cpluff: 'Plug-in screensaver.xbmc.builtin.dim has been installed.'
11:24:16.236 T:6138195968   DEBUG: ADDON: cpluff: 'Plug-in service.libraryautoupdate has been installed.'
11:24:16.236 T:6138195968   DEBUG: ADDON: cpluff: 'Plug-in resource.language.sq_al has been installed.'
11:24:16.236 T:6138195968   DEBUG: ADDON: cpluff: 'Plug-in resource.language.el_gr has been installed.'
11:24:16.236 T:6138195968   DEBUG: ADDON: cpluff: 'Plug-in resource.language.hi_in has been installed.'
11:24:16.236 T:6138195968   DEBUG: ADDON: cpluff: 'Plug-in pvr.wmc has been installed.'
11:24:16.236 T:6138195968   DEBUG: ADDON: cpluff: 'Plug-in resource.language.ml_in has been installed.'
11:24:16.236 T:6138195968   DEBUG: ADDON: cpluff: 'Plug-in script.plex has been installed.'
11:24:16.236 T:6138195968   DEBUG: ADDON: cpluff: 'Plug-in pvr.hdhomerun has been installed.'
11:24:16.236 T:6138195968   DEBUG: ADDON: cpluff: 'Plug-in resource.language.cy_gb has been installed.'
11:24:16.236 T:6138195968   DEBUG: ADDON: cpluff: 'Plug-in kodi.resource has been installed.'
11:24:16.236 T:6138195968   DEBUG: ADDON: cpluff: 'Plug-in resource.language.af_za has been installed.'
11:24:16.236 T:6138195968   DEBUG: ADDON: cpluff: 'Plug-in resource.language.uk_ua has been installed.'
11:24:16.236 T:6138195968   DEBUG: ADDON: cpluff: 'Plug-in resource.uisounds.tvos has been installed.'
11:24:16.236 T:6138195968   DEBUG: ADDON: cpluff: 'Plug-in resource.language.hy_am has been installed.'
11:24:16.236 T:6138195968   DEBUG: ADDON: cpluff: 'Plug-in resource.language.lt_lt has been installed.'
11:24:16.236 T:6138195968   DEBUG: ADDON: cpluff: 'Plug-in resource.language.si_lk has been installed.'
11:24:16.236 T:6138195968   DEBUG: ADDON: cpluff: 'Plug-in pvr.vuplus has been installed.'
11:24:16.236 T:6138195968   DEBUG: ADDON: cpluff: 'Plug-in resource.language.it_it has been installed.'
11:24:16.236 T:6138195968   DEBUG: ADDON: cpluff: 'Plug-in pvr.mythtv has been installed.'
11:24:16.236 T:6138195968   DEBUG: ADDON: cpluff: 'Plug-in xbmc.core has been installed.'
11:24:16.236 T:6138195968   DEBUG: ADDON: cpluff: 'Plug-in resource.language.mn_mn has been installed.'
11:24:16.236 T:6138195968   DEBUG: ADDON: cpluff: 'Plug-in resource.language.ar_sa has been installed.'
11:24:16.236 T:6138195968   DEBUG: ADDON: cpluff: 'Plug-in metadata.tvshows.themoviedb.org has been installed.'
11:24:16.236 T:6138195968   DEBUG: ADDON: cpluff: 'Plug-in script.module.requests has been installed.'
11:24:16.236 T:6138195968   DEBUG: ADDON: cpluff: 'Plug-in resource.language.lv_lv has been installed.'
11:24:16.236 T:6138195968   DEBUG: ADDON: cpluff: 'Plug-in resource.language.te_in has been installed.'
11:24:16.236 T:6138195968   DEBUG: ADDON: cpluff: 'Plug-in xbmc.pvr has been installed.'
11:24:16.236 T:6138195968   DEBUG: ADDON: cpluff: 'Plug-in pvr.nextpvr has been installed.'
11:24:16.236 T:6138195968   DEBUG: ADDON: cpluff: 'Plug-in resource.uisounds.amber has been installed.'
11:24:16.236 T:6138195968   DEBUG: ADDON: cpluff: 'Plug-in resource.language.et_ee has been installed.'
11:24:16.236 T:6138195968   DEBUG: ADDON: cpluff: 'Plug-in metadata.album.universal has been installed.'
11:24:16.236 T:6138195968   DEBUG: ADDON: cpluff: 'Plug-in metadata.common.allmusic.com has been installed.'
11:24:16.236 T:6138195968   DEBUG: ADDON: cpluff: 'Plug-in metadata.tvdb.com has been installed.'
11:24:16.236 T:6138195968   DEBUG: ADDON: cpluff: 'Plug-in metadata.common.omdbapi.com has been installed.'
11:24:16.236 T:6138195968   DEBUG: ADDON: cpluff: 'Plug-in metadata.artists.universal has been installed.'
11:24:16.236 T:6138195968   DEBUG: ADDON: cpluff: 'Plug-in xbmc.python has been installed.'
11:24:16.236 T:6138195968   DEBUG: ADDON: cpluff: 'Plug-in resource.language.he_il has been installed.'
11:24:16.236 T:6138195968   DEBUG: ADDON: cpluff: 'Plug-in metadata.common.imdb.com has been installed.'
11:24:16.236 T:6138195968   DEBUG: ADDON: cpluff: 'Plug-in pvr.hts has been installed.'
11:24:16.236 T:6138195968   DEBUG: ADDON: cpluff: 'Plug-in xbmc.addon has been installed.'
11:24:16.236 T:6138195968   DEBUG: ADDON: cpluff: 'Plug-in xbmc.codec has been installed.'
11:24:16.236 T:6138195968   DEBUG: ADDON: cpluff: 'Plug-in resource.language.es_es has been installed.'
11:24:16.236 T:6138195968   DEBUG: ADDON: cpluff: 'Plug-in resource.language.be_by has been installed.'
11:24:16.236 T:6138195968   DEBUG: ADDON: cpluff: 'Not all directories were successfully scanned.'
11:24:16.241 T:6138195968    INFO: CKeyboardLayoutManager: loading keyboard layouts from special://xbmc/system/keyboardlayouts...
11:24:16.241 T:6138195968   DEBUG: CKeyboardLayoutManager: keyboard layout "Chinese BasePY" successfully loaded
11:24:16.242 T:6138195968   DEBUG: CKeyboardLayoutManager: keyboard layout "Chinese BaiduPY" successfully loaded
11:24:16.242 T:6138195968   DEBUG: CKeyboardLayoutManager: keyboard layout "Lithuanian AZERTY" successfully loaded
11:24:16.242 T:6138195968   DEBUG: CKeyboardLayoutManager: keyboard layout "Lithuanian QWERTY" successfully loaded
11:24:16.243 T:6138195968   DEBUG: CKeyboardLayoutManager: keyboard layout "Russian ЙЦУКЕН" successfully loaded
11:24:16.243 T:6138195968   DEBUG: CKeyboardLayoutManager: keyboard layout "Russian АБВ" successfully loaded
11:24:16.244 T:6138195968   DEBUG: CKeyboardLayoutManager: keyboard layout "Danish QWERTY" successfully loaded
11:24:16.244 T:6138195968   DEBUG: CKeyboardLayoutManager: keyboard layout "French AZERTY" successfully loaded
11:24:16.245 T:6138195968   DEBUG: CKeyboardLayoutManager: keyboard layout "Arabic QWERTY" successfully loaded
11:24:16.246 T:6138195968   DEBUG: CKeyboardLayoutManager: keyboard layout "Czech QWERTZ" successfully loaded
11:24:16.246 T:6138195968   DEBUG: CKeyboardLayoutManager: keyboard layout "Norwegian QWERTY" successfully loaded
11:24:16.247 T:6138195968   DEBUG: CKeyboardLayoutManager: keyboard layout "German QWERTZ" successfully loaded
11:24:16.248 T:6138195968   DEBUG: CKeyboardLayoutManager: keyboard layout "Bulgarian ЯВЕРТЪ" successfully loaded
11:24:16.248 T:6138195968   DEBUG: CKeyboardLayoutManager: keyboard layout "Bulgarian АБВ" successfully loaded
11:24:16.248 T:6138195968   DEBUG: CKeyboardLayoutManager: keyboard layout "Swedish QWERTY" successfully loaded
11:24:16.249 T:6138195968   DEBUG: CKeyboardLayoutManager: keyboard layout "Turkish QWERTY" successfully loaded
11:24:16.250 T:6138195968   DEBUG: CKeyboardLayoutManager: keyboard layout "Hungarian QWERTZ" successfully loaded
11:24:16.250 T:6138195968   DEBUG: CKeyboardLayoutManager: keyboard layout "Romanian QWERTY" successfully loaded
11:24:16.251 T:6138195968   DEBUG: CKeyboardLayoutManager: keyboard layout "Spanish QWERTY" successfully loaded
11:24:16.251 T:6138195968   DEBUG: CKeyboardLayoutManager: keyboard layout "Hebrew QWERTY" successfully loaded
11:24:16.251 T:6138195968   DEBUG: CKeyboardLayoutManager: keyboard layout "Hebrew ABC" successfully loaded
11:24:16.252 T:6138195968   DEBUG: CKeyboardLayoutManager: keyboard layout "Portuguese (Portugal) QWERTY" successfully loaded
11:24:16.253 T:6138195968   DEBUG: CKeyboardLayoutManager: keyboard layout "Greek QWERTY" successfully loaded
11:24:16.253 T:6138195968   DEBUG: CKeyboardLayoutManager: keyboard layout "Polish QWERTY" successfully loaded
11:24:16.254 T:6138195968   DEBUG: CKeyboardLayoutManager: keyboard layout "Korean ㄱㄴㄷ" successfully loaded
11:24:16.255 T:6138195968   DEBUG: CKeyboardLayoutManager: keyboard layout "Ukrainian ЙЦУКЕН" successfully loaded
11:24:16.255 T:6138195968   DEBUG: CKeyboardLayoutManager: keyboard layout "Ukrainian АБВ" successfully loaded
11:24:16.255 T:6138195968   DEBUG: CKeyboardLayoutManager: keyboard layout "English QWERTY" successfully loaded
11:24:16.256 T:6138195968   DEBUG: CKeyboardLayoutManager: keyboard layout "English AZERTY" successfully loaded
11:24:16.256 T:6138195968   DEBUG: CKeyboardLayoutManager: keyboard layout "English ABC" successfully loaded
11:24:16.256 T:6138195968   DEBUG: bool CApplication::CreateGUI()
11:24:16.256 T:6138195968   DEBUG: Current resolution Screen: 0 with 3840 x 2160
11:24:16.256 T:6138195968  NOTICE: Found possible resolution for display 0 with 3840 x 2160
11:24:16.256 T:6138195968  NOTICE: Checking resolution 16
11:24:16.256 T:6138195968   DEBUG: About to switch to 3840 x 2160 on screen 0
11:24:16.256 T:6138195968   DEBUG: Found matching mode
11:24:16.256 T:6138195968    INFO: GLES: Maximum texture width: 2048
11:24:16.256 T:6138195968   DEBUG: EGL_EXTENSIONS: GL_OES_standard_derivatives GL_KHR_texture_compression_astc_ldr GL_EXT_color_buffer_half_float GL_EXT_debug_label GL_EXT_debug_marker GL_EXT_pvrtc_sRGB GL_EXT_read_format_bgra GL_EXT_separate_shader_objects GL_EXT_shader_framebuffer_fetch GL_EXT_shader_texture_lod GL_EXT_shadow_samplers GL_EXT_texture_filter_anisotropic GL_APPLE_clip_distance GL_APPLE_color_buffer_packed_float GL_APPLE_copy_texture_levels GL_APPLE_rgb_422 GL_APPLE_texture_format_BGRA8888 GL_IMG_read_format GL_IMG_texture_compression_pvrtc
11:24:16.256 T:6138195968    INFO: InitRenderSystem: GLES version 300
11:24:16.256 T:6138195968  NOTICE: GL_VENDOR = Apple Inc.
11:24:16.256 T:6138195968  NOTICE: GL_RENDERER = Apple A10X GPU
11:24:16.256 T:6138195968  NOTICE: GL_VERSION = OpenGL ES 3.0 Metal - 66.6
11:24:16.256 T:6138195968  NOTICE: GL_SHADING_LANGUAGE_VERSION = OpenGL ES GLSL ES 3.00
11:24:16.256 T:6138195968   DEBUG: GLES: Extension Support Test - GL_NVX_gpu_memory_info NO
11:24:16.256 T:6138195968  NOTICE: GL_EXTENSIONS = GL_OES_standard_derivatives GL_KHR_texture_compression_astc_ldr GL_EXT_color_buffer_half_float GL_EXT_debug_label GL_EXT_debug_marker GL_EXT_pvrtc_sRGB GL_EXT_read_format_bgra GL_EXT_separate_shader_objects GL_EXT_shader_framebuffer_fetch GL_EXT_shader_texture_lod GL_EXT_shadow_samplers GL_EXT_texture_filter_anisotropic GL_APPLE_clip_distance GL_APPLE_color_buffer_packed_float GL_APPLE_copy_texture_levels GL_APPLE_rgb_422 GL_APPLE_texture_format_BGRA8888 GL_IMG_read_format GL_IMG_texture_compression_pvrtc
11:24:16.256 T:6138195968   DEBUG: GLES: Extension Support Test - GL_EXT_texture_format_BGRA8888 NO
11:24:16.256 T:6138195968   DEBUG: GLES: Extension Support Test - GL_IMG_texture_format_BGRA8888 NO
11:24:16.256 T:6138195968   DEBUG: GLES: Extension Support Test - GL_APPLE_texture_format_BGRA8888 YES
11:24:16.256 T:6138195968   DEBUG: GLES: Extension Support Test - GL_EXT_unpack_subimage NO
11:24:16.273 T:6138195968   DEBUG: GUI Shader [guishader_frag_default.glsl]- Initialise successful : 0x281074090
11:24:16.275 T:6138195968   DEBUG: GUI Shader [guishader_frag_texture.glsl]- Initialise successful : 0x281076370
11:24:16.277 T:6138195968   DEBUG: GUI Shader [guishader_frag_multi.glsl]- Initialise successful : 0x2810765b0
11:24:16.280 T:6138195968   DEBUG: GUI Shader [guishader_frag_fonts.glsl]- Initialise successful : 0x2810767f0
11:24:16.283 T:6138195968   DEBUG: GUI Shader [guishader_frag_texture_noblend.glsl]- Initialise successful : 0x281076a30
11:24:16.286 T:6138195968   DEBUG: GUI Shader [guishader_frag_multi_blendcolor.glsl]- Initialise successful : 0x2810595f0
11:24:16.289 T:6138195968   DEBUG: GUI Shader [guishader_frag_rgba.glsl]- Initialise successful : 0x281076e20
11:24:16.289 T:6138195968   DEBUG: GLES: Extension Support Test - GL_OES_EGL_image_external NO
11:24:16.291 T:6138195968   DEBUG: GUI Shader [guishader_frag_rgba_blendcolor.glsl]- Initialise successful : 0x281077060
11:24:16.293 T:6138195968   DEBUG: GUI Shader [guishader_frag_rgba_bob.glsl]- Initialise successful : 0x2810772a0
11:24:16.293 T:6138195968   DEBUG: GLES: Extension Support Test - GL_OES_EGL_image_external NO
11:24:16.293 T:6138195968   DEBUG: About to switch to 3840 x 2160 on screen 0
11:24:16.293 T:6138195968   DEBUG: Found matching mode
11:24:16.293 T:6138195968    INFO: GLES: Maximum texture width: 16384
11:24:16.372 T:6138195968    INFO: load keymapping
11:24:16.374 T:6138195968    INFO: Loading special://xbmc/system/keymaps/customcontroller.SiriRemote.xml
11:24:16.375 T:6138195968    INFO: Loading special://xbmc/system/keymaps/keyboard.xml
11:24:16.378 T:6138195968    INFO: Loading special://masterprofile/keymaps/customcontroller.SiriRemote.xml
11:24:16.378 T:6138195968   DEBUG: found key /userdata/keymaps/customcontroller.SiriRemote.xml
11:24:16.379 T:6138195968    INFO: Loading special://profile/keymaps/customcontroller.SiriRemote.xml
11:24:16.379 T:6138195968   DEBUG: found key /userdata/keymaps/customcontroller.SiriRemote.xml
11:24:16.379 T:6138195968    INFO: GUI format 3840x2160, Display 3840x2160@ 50.00 - Full Screen
11:24:16.379 T:6138195968   DEBUG: guilib: Fill viewport on change for solving rendering passes
11:24:16.380 T:6138195968   DEBUG: >>> bool CApplication::CreateGUI()
11:24:16.380 T:6138195968    INFO: CLangInfo: loading resource.language.en_gb language information...
11:24:16.381 T:6138195968   DEBUG: trying to set locale to en_DE.UTF-8
11:24:16.383 T:6138195968    INFO: global locale set to C
11:24:16.383 T:6138195968    INFO: CLangInfo: loading resource.language.en_gb language strings...
11:24:16.389 T:6138195968   DEBUG: POParser: loaded 3893 strings from file resource://resource.language.en_gb/strings.po
11:24:16.389 T:6141063168  NOTICE: Running database version Addons20
11:24:16.389 T:6141063168   DEBUG: Initialize, updating databases...
11:24:16.391 T:6141063168  NOTICE: Running database version ViewModes6
11:24:16.392 T:6141063168  NOTICE: Running database version Textures13
11:24:16.402 T:6141063168    INFO: MYSQL: Connected to version 5.5.60-0+deb7u1
11:24:16.422 T:6141063168  NOTICE: Running database version xbmc_music60
11:24:16.449 T:6141063168  NOTICE: Running database version xbmc_video116
11:24:16.450 T:6141063168  NOTICE: Running database version TV29
11:24:16.451 T:6141063168  NOTICE: Running database version Epg11
11:24:16.451 T:6141063168   DEBUG: Initialize, updating databases... DONE
11:24:16.451 T:6138195968    INFO: DPMS: not supported on this platform
11:24:16.454 T:6138195968   DEBUG: found key /userdata/modulepasswords.xml
11:24:16.460 T:6138195968   DEBUG: Previous line repeats 1 times.
11:24:16.460 T:6138195968   DEBUG: bool CApplication::StartGUI()
11:24:16.461 T:6138195968    INFO: Unloading old skin for reload ...
11:24:16.461 T:6138195968    INFO:   load skin from: /private/var/containers/Bundle/Application/BB9C09E3-F0A9-4BF4-A977-9A409EA25057/MrMC.app/AppData/AppHome/addons/skin.ariana (version: 1.2.4)
11:24:16.461 T:6138195968   DEBUG: found key /userdata/addon_data/skin.ariana/settings.xml
11:24:16.461 T:6138195968    INFO:   load fonts for skin...
11:24:16.463 T:6138195968    INFO: Loading fonts from /private/var/containers/Bundle/Application/BB9C09E3-F0A9-4BF4-A977-9A409EA25057/MrMC.app/AppData/AppHome/addons/skin.ariana/xml/Font.xml
11:24:16.501 T:6138195968   DEBUG: LocalizeStrings: no strings.po file exist at /private/var/containers/Bundle/Application/BB9C09E3-F0A9-4BF4-A977-9A409EA25057/MrMC.app/AppData/AppHome/addons/skin.ariana/language/English, fallback to strings.xml
11:24:16.502 T:6138195968    INFO: Loading skin includes from /private/var/containers/Bundle/Application/BB9C09E3-F0A9-4BF4-A977-9A409EA25057/MrMC.app/AppData/AppHome/addons/skin.ariana/xml/Includes.xml
11:24:16.502 T:6138195968   DEBUG: found key /userdata/addon_data/skin.ariana/Includes_Variables.xml
11:24:16.503 T:6138195968   DEBUG: found key /userdata/addon_data/skin.ariana/defaults.xml
11:24:16.504 T:6138195968   DEBUG: found key /userdata/addon_data/skin.ariana/Includes_Home.xml
11:24:16.505 T:6138195968   DEBUG: found key /userdata/addon_data/skin.ariana/Includes_Views.xml
11:24:16.507 T:6138195968   DEBUG: found key /userdata/addon_data/skin.ariana/View_50.xml
11:24:16.508 T:6138195968   DEBUG: found key /userdata/addon_data/skin.ariana/View_51.xml
11:24:16.508 T:6138195968   DEBUG: found key /userdata/addon_data/skin.ariana/View_52.xml
11:24:16.509 T:6138195968   DEBUG: found key /userdata/addon_data/skin.ariana/View_53.xml
11:24:16.510 T:6138195968   DEBUG: found key /userdata/addon_data/skin.ariana/View_57_58_59_Showcase.xml
11:24:16.512 T:6138195968    INFO:   load new skin...
11:24:16.512 T:6138195968    INFO: Loading user windows, path /private/var/containers/Bundle/Application/BB9C09E3-F0A9-4BF4-A977-9A409EA25057/MrMC.app/AppData/AppHome/addons/skin.ariana/xml
11:24:16.517 T:6138195968   DEBUG: Load Skin XML: 4.81ms
11:24:16.517 T:6138195968    INFO:   initialize new skin...
11:24:16.517 T:6138195968   DEBUG: guilib: Fill viewport on change for solving rendering passes
11:24:16.517 T:6138195968    INFO: Loading skin file: Pointer.xml, load type: LOAD_ON_GUI_INIT
11:24:16.521 T:6138195968   DEBUG: OpenBundle - Opened bundle /private/var/containers/Bundle/Application/BB9C09E3-F0A9-4BF4-A977-9A409EA25057/MrMC.app/AppData/AppHome/addons/skin.ariana/media/Textures.xbt
11:24:16.521 T:6138195968    INFO: Loading skin file: DialogVolumeBar.xml, load type: LOAD_ON_GUI_INIT
11:24:16.522 T:6138195968    INFO: Loading skin file: DialogKaiToast.xml, load type: LOAD_ON_GUI_INIT
11:24:16.524 T:6138195968    INFO: Loading skin file: DialogSeekBar.xml, load type: LOAD_ON_GUI_INIT
11:24:16.525 T:6138195968    INFO: Loading skin file: DialogBusy.xml, load type: LOAD_ON_GUI_INIT
11:24:16.526 T:6138195968    INFO: Loading skin file: DialogExtendedProgressBar.xml, load type: LOAD_ON_GUI_INIT
11:24:16.527 T:6138195968    INFO: Loading resource://resource.uisounds.tvos/sounds.xml
11:24:16.528 T:6138195968    INFO:   skin loaded...
11:24:16.532 T:6138195968   DEBUG: JSONRPC: JSON schema type definition references an unknown type Setting.Details.Setting
11:24:16.532 T:6138195968 WARNING: JSONRPC: Could not parse type "Setting.Details.SettingList"
11:24:16.532 T:6138195968    INFO: JSONRPC: Adding type "Setting.Details.SettingList" to list of incomplete definitions (waiting for "Setting.Details.Setting")
11:24:16.532 T:6138195968    INFO: JSONRPC: Resolving incomplete types/methods referencing Setting.Details.Setting
11:24:16.534 T:6138195968   ERROR: JSONRPC: Missing implementation for method "VideoLibrary.GetInProgressTvShows"
11:24:16.537 T:6138195968    INFO: JSONRPC v6.32.5: Successfully initialized
11:24:16.537 T:6138195968   DEBUG: ADDON: Starting service addons.
11:24:16.537 T:6138195968   DEBUG: Activating window ID: 12999
11:24:16.537 T:6138195968   DEBUG: ------ Window Init (Startup.xml) ------
11:24:16.537 T:6138195968    INFO: Loading skin file: Startup.xml, load type: LOAD_EVERY_TIME
11:24:16.538 T:6141636608    INFO: initializing python engine.
11:24:16.538 T:6141636608   DEBUG: TEMP -> /private/var/mobile/Containers/Data/Application/D1E48118-3907-4FFC-A6A0-39ADF81E10AF/tmp/temp/temp
11:24:16.538 T:6141636608   DEBUG: PYTHONHOME -> /private/var/containers/Bundle/Application/BB9C09E3-F0A9-4BF4-A977-9A409EA25057/MrMC.app/AppData/AppHome/system
11:24:16.538 T:6141636608   DEBUG: PYTHONPATH -> /private/var/containers/Bundle/Application/BB9C09E3-F0A9-4BF4-A977-9A409EA25057/MrMC.app/AppData/AppHome/system
11:24:16.538 T:6138195968   DEBUG: Activating window ID: 10000
11:24:16.538 T:6138195968   DEBUG: ------ Window Deinit (Startup.xml) ------
11:24:16.538 T:6138195968   DEBUG: ------ Window Init (Home.xml) ------
11:24:16.538 T:6138195968    INFO: Loading skin file: Home.xml, load type: KEEP_IN_MEMORY
11:24:16.545 T:6138195968   DEBUG: CGUIWindowHome::SetupServices() - serverType(mrmc) ,  serverUUID(mrmc)
11:24:16.580 T:6141636608   DEBUG: CPythonInvoker(0, /private/var/containers/Bundle/Application/BB9C09E3-F0A9-4BF4-A977-9A409EA25057/MrMC.app/AppData/AppHome/addons/script.advanced.wol/autostart.py): start processing
11:24:16.592 T:6141636608   DEBUG: -->Python Interpreter Initialized<--
11:24:16.592 T:6141636608   DEBUG: CPythonInvoker(0, /private/var/containers/Bundle/Application/BB9C09E3-F0A9-4BF4-A977-9A409EA25057/MrMC.app/AppData/AppHome/addons/script.advanced.wol/autostart.py): the source file to load is "/private/var/containers/Bundle/Application/BB9C09E3-F0A9-4BF4-A977-9A409EA25057/MrMC.app/AppData/AppHome/addons/script.advanced.wol/autostart.py"
11:24:16.592 T:6141636608   DEBUG: CPythonInvoker(0, /private/var/containers/Bundle/Application/BB9C09E3-F0A9-4BF4-A977-9A409EA25057/MrMC.app/AppData/AppHome/addons/script.advanced.wol/autostart.py): setting the Python path to /private/var/containers/Bundle/Application/BB9C09E3-F0A9-4BF4-A977-9A409EA25057/MrMC.app/AppData/AppHome/addons/script.advanced.wol:/private/var/containers/Bundle/Application/BB9C09E3-F0A9-4BF4-A977-9A409EA25057/MrMC.app/AppData/AppHome/system:/private/var/containers/Bundle/Application/BB9C09E3-F0A9-4BF4-A977-9A409EA25057/MrMC.app/AppData/AppHome/system/lib/python27.zip:/private/var/containers/Bundle/Application/BB9C09E3-F0A9-4BF4-A977-9A409EA25057/MrMC.app/AppData/AppHome/system/lib/python2.7:/private/var/containers/Bundle/Application/BB9C09E3-F0A9-4BF4-A977-9A409EA25057/MrMC.app/AppData/AppHome/system/lib/python2.7/plat-darwin:/private/var/containers/Bundle/Application/BB9C09E3-F0A9-4BF4-A977-9A409EA25057/MrMC.app/AppData/AppHome/system/lib/python2.7/plat-mac:/private/var/containers/Bundle/Application/BB9C09E3-F0A9-4BF4-A977-9A409EA25057/MrMC.app/AppData/AppHome/system/lib/python2.7/plat-mac/lib-scriptpackages:/private/var/containers/Bundle/Application/BB9C09E3-F0A9-4BF4-A977-9A409EA25057/MrMC.app/AppData/AppHome/system/lib/python2.7/lib-tk:/private/var/containers/Bundle/Application/BB9C09E3-F0A9-4BF4-A977-9A409EA25057/MrMC.app/AppData/AppHome/system/lib/python2.7/lib-old:/private/var/containers/Bundle/Application/BB9C09E3-F0A9-4BF4-A977-9A409EA25057/MrMC.app/AppData/AppHome/system/lib/python2.7/lib-dynload
11:24:16.592 T:6141636608   DEBUG: CPythonInvoker(0, /private/var/containers/Bundle/Application/BB9C09E3-F0A9-4BF4-A977-9A409EA25057/MrMC.app/AppData/AppHome/addons/script.advanced.wol/autostart.py): entering source directory /private/var/containers/Bundle/Application/BB9C09E3-F0A9-4BF4-A977-9A409EA25057/MrMC.app/AppData/AppHome/addons/script.advanced.wol
11:24:16.592 T:6141636608   DEBUG: CPythonInvoker(0, /private/var/containers/Bundle/Application/BB9C09E3-F0A9-4BF4-A977-9A409EA25057/MrMC.app/AppData/AppHome/addons/script.advanced.wol/autostart.py): instantiating addon using automatically obtained id of "script.advanced.wol" dependent on version 2.1.0 of the xbmc.python api
11:24:16.594 T:6141636608   DEBUG: found key /userdata/addon_data/script.advanced.wol/settings.xml
11:24:16.608 T:6141636608   DEBUG: script.advanced.wol: Starting WOL script
11:24:16.609 T:6141636608   DEBUG: found key /userdata/addon_data/script.advanced.wol/settings.xml
11:24:16.609 T:6141636608   DEBUG: script.advanced.wol: WakeOnLan signal sent to MAC-Address 00:26:2D:01:72:DE
11:24:16.609 T:6141636608   DEBUG: LocalizeStrings: no strings.po file exist at /private/var/containers/Bundle/Application/BB9C09E3-F0A9-4BF4-A977-9A409EA25057/MrMC.app/AppData/AppHome/addons/script.advanced.wol/resources/language/English, fallback to strings.xml
11:24:16.647 T:6138195968   DEBUG: CMultiPathDirectory::GetDirectory(multipath://multipath%3a%2f%2fspecial%253a%252f%252fprofile%252fplaylists%252fmusic%2fspecial%253a%252f%252fprofile%252fplaylists%252fmixed%2f/multipath%3a%2f%2fspecial%253a%252f%252fprofile%252fplaylists%252fvideo%2fspecial%253a%252f%252fprofile%252fplaylists%252fmixed%2f/)
11:24:16.647 T:6138195968   DEBUG: Getting Directory (multipath://special%3a%2f%2fprofile%2fplaylists%2fmusic/special%3a%2f%2fprofile%2fplaylists%2fmixed/)
11:24:16.647 T:6138195968   DEBUG: CMultiPathDirectory::GetDirectory(multipath://special%3a%2f%2fprofile%2fplaylists%2fmusic/special%3a%2f%2fprofile%2fplaylists%2fmixed/)
11:24:16.647 T:6138195968   DEBUG: Getting Directory (special://profile/playlists/music)
11:24:16.648 T:6138195968   DEBUG: Getting Directory (special://profile/playlists/mixed)
11:24:16.648 T:6138195968   DEBUG: CMultiPathDirectory::MergeItems, items = 0
11:24:16.648 T:6138195968   DEBUG: Getting Directory (multipath://special%3a%2f%2fprofile%2fplaylists%2fvideo/special%3a%2f%2fprofile%2fplaylists%2fmixed/)
11:24:16.648 T:6138195968   DEBUG: CMultiPathDirectory::GetDirectory(multipath://special%3a%2f%2fprofile%2fplaylists%2fvideo/special%3a%2f%2fprofile%2fplaylists%2fmixed/)
11:24:16.648 T:6138195968   DEBUG: Getting Directory (special://profile/playlists/video)
11:24:16.648 T:6138195968   DEBUG: Previous line repeats 1 times.
11:24:16.648 T:6138195968   DEBUG: CGUIWindowHome::SetupStaticHomeButtons()
11:24:16.648 T:6141063168   DEBUG: CHomeShelfJob::UpdateMusic() - Running HomeShelf screen update
11:24:16.648 T:6138195968   ERROR: Control 9000 in window 10000 has been asked to focus, but it can't
11:24:16.648 T:6138195968    INFO: removing tempfiles
11:24:16.649 T:6138195968   DEBUG: ADDON: Starting service addons.
11:24:16.649 T:6138195968  NOTICE: initialize done
11:24:16.649 T:6138195968  NOTICE: Running the application...
11:24:16.649 T:6138195968   DEBUG: NetworkMessage - Starting network services
11:24:16.649 T:6138195968  NOTICE: starting zeroconf publishing
11:24:16.649 T:6138195968  NOTICE: WebServer: Started the webserver
11:24:16.649 T:6142783488   DEBUG: CZeroconfOSX::doPublishService identifier: servers.webserver type: _http._tcp name:ATV-4K port:8080
11:24:16.649 T:6138195968  NOTICE: starting upnp client
11:24:16.649 T:6144503808   DEBUG: CZeroconfOSX::doPublishService identifier: servers.jsonrpc-http type: _xbmc-jsonrpc-h._tcp name:ATV-4K port:8080
11:24:16.650 T:6138195968    INFO: JSONRPC Server: Successfully initialized
11:24:16.650 T:6147944448  NOTICE: ES: Starting UDP Event server on 127.0.0.1:9777
11:24:16.650 T:6147944448  NOTICE: UDP: Listening on port 9777
11:24:16.650 T:6138195968    INFO: WakeOnLan - Magic packet send to '00:26:2D:01:72:DE'
11:24:16.650 T:6142783488   DEBUG: CZeroconfOSX::doPublishService identifier: servers.jsonrpc-tpc type: _xbmc-jsonrpc._tcp name:ATV-4K port:9090
11:24:16.651 T:6144503808   DEBUG: CZeroconfOSX::doPublishService identifier: servers.eventserver type: _xbmc-events._udp name:ATV-4K port:9777
11:24:16.655 T:6138195968    INFO: GLES: Enabling VSYNC
11:24:16.655 T:6138195968    INFO: GLES: Selected vsync mode 10
11:24:16.674 T:6141063168   DEBUG: GetRecentlyAddedAlbums query: SELECT albumview.*, albumartistview.* FROM (SELECT idAlbum FROM album WHERE strAlbum != '' ORDER BY idAlbum DESC LIMIT 10) AS recentalbums JOIN albumview ON albumview.idAlbum = recentalbums.idAlbum JOIN albumartistview ON albumview.idAlbum = albumartistview.idAlbum ORDER BY albumview.idAlbum desc, albumartistview.iOrder
11:24:16.677 T:6138195968   DEBUG: ------ Window Init (DialogKaiToast.xml) ------
11:24:16.686 T:4389885952   DEBUG: enterActiveDelayed: AVPlayerHDRMode = 2
11:24:16.686 T:6139342848   DEBUG: CActiveAE - device change event
11:24:16.699 T:6141063168   DEBUG: CHomeShelfJob::UpdateVideos() - Running HomeShelf screen update
11:24:16.715 T:6139342848   DEBUG: EnumerateDevices:Device(default)
11:24:16.715 T:6139342848  NOTICE: Found 1 Lists of Devices
11:24:16.715 T:6139342848  NOTICE: Enumerated DARWINIOS devices:
11:24:16.715 T:6139342848  NOTICE:     Device 1
11:24:16.715 T:6139342848  NOTICE:         m_deviceName      : default
11:24:16.715 T:6139342848  NOTICE:         m_displayName     : Default
11:24:16.715 T:6139342848  NOTICE:         m_displayNameExtra:
11:24:16.715 T:6139342848  NOTICE:         m_deviceType      : AE_DEVTYPE_HDMI
11:24:16.715 T:6139342848  NOTICE:         m_channels        : FL,FR,FC,LFE,BL,BR
11:24:16.715 T:6139342848  NOTICE:         m_sampleRates     : 44100,48000
11:24:16.715 T:6139342848  NOTICE:         m_dataFormats     : AE_FMT_S16LE,AE_FMT_FLOAT
11:24:16.715 T:6139342848  NOTICE:         m_streamTypes     : No passthrough capabilities
11:24:16.715 T:6139342848    INFO: CActiveAE::ApplySettings - Forcing samplerate to 48000
11:24:16.716 T:6139916288    INFO: CActiveAESink::OpenSink - initialize sink
11:24:16.716 T:6139916288   DEBUG: CActiveAESink::OpenSink - trying to open device DARWINIOS:default
11:24:16.717 T:6139916288   DEBUG: virtual bool CAESinkDARWINIOS::Initialize(AEAudioFormat &, std::string &): AudioStreamBasicDescription: [lpcm] Mixable Interleaved 6 Channel 32-bit Floating Point LE (48000Hz) pcm
11:24:16.719 T:6139916288  NOTICE: bool CAAudioUnitSink::setupAudio() setting channels 6
11:24:16.720 T:6139916288  NOTICE: bool CAAudioUnitSink::setupAudio() setting samplerate 48000.000000
11:24:16.720 T:6139916288  NOTICE: bool CAAudioUnitSink::setupAudio() setting buffer duration to 0.128000
11:24:16.842 T:6141063168   DEBUG: SECTION:LoadDLL(libdsm.framework/libdsm)
11:24:16.843 T:6141063168   DEBUG: Loading: /private/var/containers/Bundle/Application/BB9C09E3-F0A9-4BF4-A977-9A409EA25057/MrMC.app/Frameworks/libdsm.framework/libdsm
11:24:16.857 T:6141063168   DEBUG: found key /userdata/passwords.xml
11:24:16.857 T:6141063168   DEBUG: Previous line repeats 2 times.
11:24:16.857 T:6141063168   DEBUG: CPasswordManager:AuthenticateURL hasUserPass(1), path(smb://USERNAME:[email protected]/XBMC/TV/Legends (2014)/Season 2/Legends (2014) S02E01-thumb.jpg)
11:24:17.616 T:6141636608   DEBUG: script.advanced.wol: Closing WOL script
11:24:17.617 T:6141636608    INFO: CPythonInvoker(0, /private/var/containers/Bundle/Application/BB9C09E3-F0A9-4BF4-A977-9A409EA25057/MrMC.app/AppData/AppHome/addons/script.advanced.wol/autostart.py): script successfully run
11:24:17.622 T:6141636608    INFO: Python script stopped
11:24:17.647 T:6139916288  NOTICE: bool CAAudioUnitSink::setupAudio() total latency = 0.066000
11:24:17.647 T:6139916288  NOTICE: bool CAAudioUnitSink::setupAudio() setup audio format: [lpcm] Mixable Interleaved 6 Channel 32-bit Floating Point LE (48000Hz)
11:24:17.656 T:6139916288  NOTICE: void dumpAVAudioSessionProperties() audio route = HDMIOutput
11:24:17.657 T:6139916288  NOTICE: void dumpAVAudioSessionProperties() sampleRate 48000.000000
11:24:17.657 T:6139916288  NOTICE: void dumpAVAudioSessionProperties() outputLatency 0.034000
11:24:17.659 T:6139916288  NOTICE: void dumpAVAudioSessionProperties() IOBufferDuration 0.032000
11:24:17.659 T:6139916288  NOTICE: void dumpAVAudioSessionProperties() outputNumberOfChannels 6
11:24:17.660 T:6139916288  NOTICE: void dumpAVAudioSessionProperties() maximumOutputNumberOfChannels 6
11:24:17.660 T:6139916288   DEBUG: DumpAudioDescriptions: void dumpAVAudioSessionProperties()
11:24:17.664 T:6139916288   DEBUG: DumpAudioDescriptions: input count = 0
11:24:17.667 T:6139916288   DEBUG: DumpAudioDescriptions: output count = 1
11:24:17.667 T:6139916288   DEBUG: DumpAudioDescriptions : portName, ATV-4K
11:24:17.667 T:6139916288   DEBUG: DumpAudioDescriptions: channelLabel, -1
11:24:17.667 T:6139916288   DEBUG: DumpAudioDescriptions: channelName , ATV-4K 1
11:24:17.667 T:6139916288   DEBUG: DumpAudioDescriptions: channelName , ATV-4K 2
11:24:17.691 T:6137622528   DEBUG: DumpAudioDescriptions: AVAudioSessionRouteChangeReasonCategoryChange
11:24:17.695 T:6139916288   DEBUG: CActiveAESink::OpenSink - DARWINIOS Initialized:
11:24:17.695 T:6139916288   DEBUG:   Output Device : Default
11:24:17.695 T:6139916288   DEBUG:   Sample Rate   : 48000
11:24:17.695 T:6139916288   DEBUG:   Sample Format : AE_FMT_FLOAT
11:24:17.695 T:6139916288   DEBUG:   Channel Count : 6
11:24:17.695 T:6139916288   DEBUG:   Channel Layout: FL,FC,FR,BL,BR,LFE
11:24:17.695 T:6139916288   DEBUG:   Frames        : 1024
11:24:17.695 T:6139916288   DEBUG:   Frame Size    : 24
11:24:17.696 T:6139916288   DEBUG: CActiveAESink::GenerateNoise - noiseFactor = 0.000010
11:24:17.697 T:6139342848   DEBUG: CActiveAE::ClearDiscardedBuffers - buffer pool deleted
11:24:17.707 T:6137622528   DEBUG: DumpAudioDescriptions: input count = 0
11:24:17.708 T:6137622528   DEBUG: DumpAudioDescriptions: output count = 1
11:24:17.708 T:6137622528   DEBUG: DumpAudioDescriptions : portName, ATV-4K
11:24:17.708 T:6137622528   DEBUG: DumpAudioDescriptions: channelLabel, -1
11:24:17.708 T:6137622528   DEBUG: DumpAudioDescriptions: channelName , ATV-4K 1
11:24:17.708 T:6137622528   DEBUG: DumpAudioDescriptions: channelName , ATV-4K 2
11:24:17.709 T:6137622528   DEBUG: DumpAudioDescriptions: AVAudioSessionRouteChangeReasonCategoryChange
11:24:17.709 T:6137622528   DEBUG: DumpAudioDescriptions: input count = 0
11:24:17.710 T:6137622528   DEBUG: DumpAudioDescriptions: output count = 1
11:24:17.710 T:6137622528   DEBUG: DumpAudioDescriptions : portName, ATV-4K
11:24:17.710 T:6137622528   DEBUG: DumpAudioDescriptions: channelLabel, -1
11:24:17.710 T:6137622528   DEBUG: DumpAudioDescriptions: channelName , ATV-4K 1
11:24:17.710 T:6137622528   DEBUG: DumpAudioDescriptions: channelName , ATV-4K 2
11:24:20.378 T:6138195968   DEBUG: Activating window ID: 10025
11:24:20.489 T:6138195968   DEBUG: ------ Window Deinit (Home.xml) ------
11:24:20.524 T:6138195968   DEBUG: ------ Window Init (MyVideoNav.xml) ------
11:24:20.524 T:6138195968    INFO: Loading skin file: MyVideoNav.xml, load type: KEEP_IN_MEMORY
11:24:20.526 T:6138195968 WARNING: Skin has invalid include: ContentFade
11:24:22.509 T:6138195968 WARNING: Previous line repeats 4 times.
11:24:22.509 T:6138195968   DEBUG: ------ Window Deinit (DialogKaiToast.xml) ------
11:24:26.085 T:6138195968   DEBUG: ------ Window Init (DialogBusy.xml) ------
11:24:27.660 T:6138195968    INFO: Python, unloading python shared library because no scripts are running anymore
11:25:38.689 T:6138195968   DEBUG: WindowVideoNav::GetDirectory
11:25:39.411 T:6138195968   DEBUG: ------ Window Deinit (DialogBusy.xml) ------
Set-Top-Box: Apple TV 4K
FW: tvOS 16.2
Front-End: MrMC 3.9.12 (210507.625)
Skin: Ariana
Database: MySQL
NAS: QNAP TS-451+
That’s odd, I can’t see that 70 sec delay in a debuglog.
Can you post a log( on pastebin, preferably not here ) that shows the issue please.
Other thing to try is to drop database version 112 and 116, 112 was created in the previous version and 116 in this version. Maybe upgrade from v107 that is in release version would be reveal some issues. We would need that log and log.old as well to see it.
DocEagle
Post by DocEagle »
Here we go. I'm not quite sure if the logs last back far enough.
log:
https://pastebin.com/iQPCkSBY
log.old:
https://pastebin.com/e8SpewW5
Additionally the log file with the latest try:
https://pastebin.com/8RR8CxmF
FW: tvOS 16.2
Skin: Ariana
Database: MySQL
NAS: QNAP TS-451+
DocEagle wrote: 11 Dec 2019, 11:52 Here we go. I'm not quite sure if the logs last back far enough.
log:
log.old:
first thing I see is NFS issue
11:36:37.494 T:6177107968   ERROR: NFS: Failed to stat(Filme/NMT/MKV/Anonymous (2011)/Anonymous (2011)-poster.jpg) stat call failed with "NFS: Lookup of /NMT/MKV/Anonymous (2011)/Anonymous (2011)-poster.jpg failed with NFS3ERR_ACCES(-13)
is that the server that's giving you issues?
but I still don't see the issue of 70 second hang, nowhere in the log does it show that. could you replicate the issue and post the new one.
DocEagle
Post by DocEagle »
No, that‘s the wrong one.
I added a third log later on, where you find another try against the TV-server.
Meanwhile I dropped the video databases 112 and 116. The conversion took place, but the waiting time still happens.
FW: tvOS 16.2
Skin: Ariana
Database: MySQL
NAS: QNAP TS-451+
