How to request Testflight access: Send an email to [email protected] with the subject "let me in!", include your forum username and email address tied to your AppleTV4/4K. Users that are already in previous testflight series are automatically enrolled into this one.
Warning: If we determine that you have requested entry into Testflight to bypass purchasing MrMC, you will be ejected and banned from the forum.
When reporting issues, please include debuglog (use the new debug log server see https://wiki.mrmc.tv/index.php/Debug_lo ... d%20higher )
For some issues, pictures are very helpful.
3.9.3 (190928.2047)
add support for iPhones 11
fix: ignore @eaDir directories created by Synology
fix: upcoming jellyfin removes WanAddress
tvos: add audio route picker (long hold/center)
3.9.3 (191002.302)
tvos: Play/Pause hold is not possible, refine showAudioRoutePicker handling
tvos: make sure tvOS volume is always VOLUME_MAXIMUM and never muted
add: dump settings into a log before we upload it
emby: connect.mediabrowser.tv changed to connect.emby.media
tvos: add AudioRouteSelector button in skin
3.9.3 (191022.1308)
fix: since we might check for interlaced earler, qualify before using the 2nd check
fix: limit libsmb2 writes to 32k to avoid POLLHUP errors on some smb servers
fix: Build cache filename using just path without options string, PR 16805
trakt: fix scrobble for some show titles that contain ( )
3.9.3 (191126.1646)
- emby: rework emby service startup. we only need network and ping to the emby server to proceed… we should not be checking “connect.emby.media” for local connection
- emby: if uuid is empty(on first connect) load all views
- home: load sections correctly when new service is connected
- plex: if uuid is empty(on first connect) load all views
- handle local art movieset-poster.* and movieset-fanart.* for sets/collections
- metadata.tvdb.com bump to 2.1.0
- bump metadata.themoviedb.org to 4.1.7
- fix metadata.tvshows.themoviedb.org for some missing tvshows
3.9.3 (191129.1516)
- speed up movie library loading
3.9.3 (191210.1231)
- Kodi v18 "Leia" compatible video database
3.9.3 (191215.1643) - Release Candidate
- no major changes from last version, repackaged using latest xcode
Testing MrMC 3.9.3 - Apple TV
- Ted377
Re: Testing MrMC 3.9.3 - Apple TV
tvos: add audio route picker (long hold/center) works great
FW: tvOS 17.4 ()
Front-End: MrMC 3.9.12 ()
Skin: Opacity
NAS: QNAP TS-431P3
Back-End: TVHeadend/PLEX
TUNER: Kathrein EXIP 418
FW: tvOS 17.4 ()
Skin: Opacity
NAS: QNAP TS-431P3
- Montoya
How do we get there when a PVR is active ?
- Ted377
That’s a good question.
FW: tvOS 17.4 ()
Skin: Opacity
NAS: QNAP TS-431P3
FW: tvOS 17.4 ()
Skin: Opacity
NAS: QNAP TS-431P3
- Montoya
Other apps have something like this, so probably, we might get something in OSD.
- Ted377
This consideration is very good. I have often thought of that.
FW: tvOS 17.4 ()
Skin: Opacity
NAS: QNAP TS-431P3
FW: tvOS 17.4 ()
Skin: Opacity
NAS: QNAP TS-431P3
i dont know if i have to post it here..
When i try to pick a subtitle (download via opensubtitles) it only displays english subtitles although i have my language subtitle to greek.
btw 393 is written in xcode?
